thierry laurent Posted January 23, 2021 Posted January 23, 2021 2 hours ago, Stevepd said: Here are the JP233s’ from the above link on ebay. They are substantial bits of resin with engraved panel lines. I think a lot will be lost when you have to fit the 2 parts together and the obvious curvature will have to be made flat. Couldn’t work out how to post images so just did the links: Side profile Top view Front section Rear section Alas all links loop back to the top of this page. Stevepd 1
Stevepd Posted January 23, 2021 Posted January 23, 2021 (edited) 37 minutes ago, thierry laurent said: Alas all links loop back to the top of this page. Ah flip.. How on earth do you link to flicker? Edited January 23, 2021 by Stevepd
RichG Posted January 23, 2021 Posted January 23, 2021 (edited) Some beautiful 1000lb'ers from Videoaviation... Retard & Freefall Thanks to @onosendai https://www.videoaviation.com/product/1-32-raf-1000lb-bombs-retarded-tail/ https://www.videoaviation.com/product/1-32-raf-1000lb-bombs-free-fall-tail/S Edited January 23, 2021 by RichG onosendai 1
Dave Williams Posted January 23, 2021 Posted January 23, 2021 ResKit CPU-123s https://reskit.com.ua/index.php?route=product/product&path=59&product_id=589&mfp=12-scale[1/32] Armory wheels https://www.scalemates.com/kits/armory-aw32501b-panavia-tornado-wheels-w-tires-type-2--1169229
RichG Posted January 23, 2021 Posted January 23, 2021 (edited) On 1/21/2021 at 4:27 PM, Confusionreigns178 said: If you don't mind adding older aftermarket to the list, there's always the resin Aires cockpit tubs. IIRC correctly they are all designed to go in the REVELL kits and are getting pretty hard to find now. I'm not sure they are hard to find as I purchased one from Hannants last month (a recently released early GR.1 version). Quick check of their website shows 3 versions available all in reasonable quantity. They are however expensive but I agree the detail is equisite. I tried a test fit on the Italeri and the fit was reasonable (I've had worse on kits Aries ARE designed for) but that was without the nose wheel bay fitted and which interlocks with the kit cockpit. I suspect it may be necessary to remove the resin front floor. As the Italeri pit is itself well detailed, I have decided to detail & display the Aries cockpit alongside (rather than risk wrecking two very pricy models). Here is what can be achieved with it using ANYZ Models detailing products https://anyz.io/assets/images/tornado.jpg Rich Edited January 23, 2021 by RichG Mark M 1
RichG Posted January 23, 2021 Posted January 23, 2021 (edited) 55 minutes ago, Mark M said: anyone know of any AIM-132? Eduard No. 632165 - 1:32 AIM-132 ASRAAM (due for release Jan / Feb 2021 - if not already available) Image c/o https://www.super-hobby.co.uk https://www.scalemates.com/kits/eduard-632165-aim-132-asraam--1322425 Hope that helps Rich Edited January 23, 2021 by RichG
Mark M Posted January 23, 2021 Posted January 23, 2021 cheers rich, not out yet, well i cant find any but hopefully soon then
Smokey Posted January 25, 2021 Posted January 25, 2021 Hi all. Great thread and I just bought the 1/32 Italeri GR.4 and since I don't know much about them hope more companies come out more eye popping decal schemes.
cch4530 Posted January 25, 2021 Posted January 25, 2021 Couldn't find the JP233s in the ebay shop Have sent a message asking about them though
Mark M Posted January 25, 2021 Posted January 25, 2021 2 hours ago, cch4530 said: Couldn't find the JP233s in the ebay shop Have sent a message asking about them though Jim's asked me to message you check your pm
otis252 Posted January 25, 2021 Posted January 25, 2021 Hopefully we can now get a triple launcher with Brimstone missiles. Also there's the CAM seats, they're still in stock at SB. Chuck Mark M 1
Mark M Posted January 25, 2021 Posted January 25, 2021 42 minutes ago, Luca said: JP233 only for GR.1 I think jp233 is basically a mini cluster bomb and land mines, so when they blow up a runway its difficult to repair it as there are landmines everywhere so when the world banned landmines in 1997 (land mine treaty) these were withdrawn from service. So as the first flight of a GR4 was in 1997 they wernt used. However...... in 1998 there were several sorties and testing carried out using empty but weighted jp233 canisters, im not sure why but they happened Luca 1
