docdodj01 Posted December 10, 2019 Posted December 10, 2019 The old revell P-51B is a better point to start a correction, short of owning the Jerry Rutman one. Trumpeter is way off. Even if you graft the resin nose to the Trumpy kit, you still have a problem with the wing shape. I already compared the new revell P-51D as a quick comparison of the accuracy of the lines. Literally, even if the old P-51B had raised lines, they fall almost exactly to the panel lines in the P-51D. I initially considered grafting the revell D nose to the B, but chickened out in trying to destroy a really nice kit.
109ace Posted December 10, 2019 Posted December 10, 2019 My nose has been engineered using a reproduction of the Revell P-51D Early upper cowl and has been grafted on to the P-51B lower nose at the midpoint of the exhaust outlets. The resin nose has a smooth featureless surface. For one simple reason. The update can not be done without rescribing the whole model. Rescribing is a very personal thing for modelers and everybody has their techniques. Me? I prefer deeper lines. Others prefer lighter. some prefer pencil. I can go on, but you get the point. I would only be frustrating the builder who would have to fill my recessed lines in before doing it their way. coogrfan 1
MikeMaben Posted December 10, 2019 Posted December 10, 2019 Hi Kevin, are you selling the parts individually ?
109ace Posted December 10, 2019 Posted December 10, 2019 3 hours ago, MikeMaben said: Hi Kevin, are you selling the parts individually ? Sure Mike! I do have three ala'carte sets listed. One for all the clear parts, one gives you just the nose with exhausts, and prop/spinner, and the third set gives you the fuel tanks, pylons, and wheels. if there is a specific part you need, I'm happy to fill that outside of Ebay as a direct sale. One member has asked if he can buy using the classic method of check in the mail. Message me if this is your preferred manner of purchase. MikeMaben 1
109ace Posted December 10, 2019 Posted December 10, 2019 (edited) 9 hours ago, docdodj01 said: The old revell P-51B is a better point to start a correction, short of owning the Jerry Rutman one. Trumpeter is way off. Even if you graft the resin nose to the Trumpy kit, you still have a problem with the wing shape. I already compared the new revell P-51D as a quick comparison of the accuracy of the lines. Literally, even if the old P-51B had raised lines, they fall almost exactly to the panel lines in the P-51D. I initially considered grafting the revell D nose to the B, but chickened out in trying to destroy a really nice kit. It's a little more complicated then grafting a P-51D nose to the B kit. The windscreens are different. I adapted my one piece cowl to the B kit windscreen/instrument coaming. Hence the reason for the cuts being made behind the coaming down through the forward wingroots. It's the least destructive manner. Edited December 10, 2019 by 109ace docdodj01 1
Rick Griewski Posted December 10, 2019 Posted December 10, 2019 54 minutes ago, 109ace said: It's a little more complicated then grafting a P-51D nose to the B kit. The windscreens are different. I adapted my one piece cowl to the B kit windscreen/instrument coaming. Hence the reason for the cuts being made behind the coaming down through the forward wingroots. It's the least destructive manner. All this is part of the fun! chrish and MikeMaben 2
docdodj01 Posted December 10, 2019 Posted December 10, 2019 2 hours ago, 109ace said: It's a little more complicated then grafting a P-51D nose to the B kit. The windscreens are different. I adapted my one piece cowl to the B kit windscreen/instrument coaming. Hence the reason for the cuts being made behind the coaming down through the forward wingroots. It's the least destructive manner. I know. I was actually had a crazy thought to cut up the Revell D and B, similar to how the Revell D parts would be like. Especially the wheel wells of the D. The wings of the new D is a drop fit to the B fuselage, with the exception of wing root parts since the D model had a extension. But like you mentioned I realized I couldn’t massacre a new tool kit to update an old one. It would be a waste on a well done, brand new D kit.
Rick Griewski Posted December 11, 2019 Posted December 11, 2019 I am in the process of kit bashing a new Revell P-51D and a P-51A. So I have good idea of the effort.
Pete G. Posted December 28, 2020 Posted December 28, 2020 Does anyone know if Kevin is still producing this set?
Pete G. Posted December 28, 2020 Posted December 28, 2020 Yep. Tried. Doesn't look like he has been on in awhile. E-mailed as well. Thought I would ask the general forum in case someone knows. Thanks
Dennis7423 Posted December 28, 2020 Posted December 28, 2020 He's still pretty active on Hyperscale, so I imagine he's still kicking around. Might try reaching out to him there. - Dennis S. Thornton, CO USA
Pete G. Posted December 28, 2020 Posted December 28, 2020 Thanks Dennis, Reached out through that forum as well. Regards, Pete
