B-17 Posted July 13, 2020 Share Posted July 13, 2020 Iain, That is a terrific idea. I really hope that you still plan on marketing these. I would gladly pay to compensate your efforts and improve the wings on my two kits. Watching eagerly... Link to comment Share on other sites More sharing options...
Julian Farian Posted July 17, 2020 Share Posted July 17, 2020 Hello Iain, I am building the 1/32 D model as crashed in GuadalCanal in 1942, and I have damaged the fuselage to replicate Aa damage And other damage. I hate the airfoil, and am wondering if you would recommend doing something similar to what you’ve done. I am not very good with power tools, but I think I would be able to thin the plastic like you did. Are there any other ways you think I could fix the airfoil? Thanks I really appreciate it! Have a great day! Uncarina 1 Link to comment Share on other sites More sharing options...
Iain Posted July 21, 2020 Author Share Posted July 21, 2020 Hi Julian, Feel free to print off the airfoil sections I posted earlier. If you use them to cut the shapes in something like 2mm sheet styrene you should have something you can then bend the wing around. You could then use brass rod through the centre section of the kit spar (with the outer sections that fit inside the wings removed). The cross section is correctable without altering the thrust line of the engines if you are careful and bond the formers at the leading edge first - give lots of time for the bond to fdry - and then bending the upper wing around the formers. You will need to remove/reduce a lot of the wing's internal structure as moulded. Would love to see some photos of your project! Iain mozart and Out2gtcha 2 Link to comment Share on other sites More sharing options...
mozart Posted July 22, 2020 Share Posted July 22, 2020 On 7/17/2020 at 1:38 PM, Julian Farian said: Hello Iain, I am building the 1/32 D model as crashed in GuadalCanal in 1942, and I have damaged the fuselage to replicate Aa damage And other damage. I hate the airfoil, and am wondering if you would recommend doing something similar to what you’ve done. I am not very good with power tools, but I think I would be able to thin the plastic like you did. Are there any other ways you think I could fix the airfoil? Thanks I really appreciate it! Have a great day! Welcome to LSP Julian! Enjoy your time here, there’s always lots to learn and people here who will freely give you advice. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 22, 2020 Share Posted July 22, 2020 Sounds like a wonderful plan Iain! Link to comment Share on other sites More sharing options...
Julian Farian Posted July 23, 2020 Share Posted July 23, 2020 Hi Iain, I appreciate your response! Btw everyone before I get corrected, After much research my diorama is being changed to Peleliu due to historical inaccuracies. I will share a link to my YouTube video I made of my work so far. Also Iain, do you think it’s worth the extra effort to change the airfoil? Thanks, also I might try to do what you’ve already done in this forum. Should I just print the image you shared of all the plastic arc prices with the cut out paper ( with lines and percents) and scale it correctly and cut it out? Thank you very much, I really appreciate it. I’m sorry if something doesn’t make sense, I’m not an expert on airfoils! https://youtu.be/eE3JO5u8vq0 https://youtu.be/0cOFMxZ8wMA Link to comment Share on other sites More sharing options...
Julian Farian Posted July 23, 2020 Share Posted July 23, 2020 Also what page of this forum is the picture of all the airfoil things to print? thank you very much! Link to comment Share on other sites More sharing options...
SimonCornes Posted July 27, 2020 Share Posted July 27, 2020 On 7/23/2020 at 6:17 PM, Julian Farian said: Also what page of this forum is the picture of all the airfoil things to print? thank you very much! Try page 18? Link to comment Share on other sites More sharing options...
Julian Farian Posted July 29, 2020 Share Posted July 29, 2020 On 7/27/2020 at 7:44 AM, SimonCornes said: Try page 18? Thanks! Link to comment Share on other sites More sharing options...
Julian Farian Posted July 29, 2020 Share Posted July 29, 2020 On 7/21/2020 at 7:22 AM, Iain said: Hi Julian, Feel free to print off the airfoil sections I posted earlier. If you use them to cut the shapes in something like 2mm sheet styrene you should have something you can then bend the wing around. You could then use brass rod through the centre section of the kit spar (with the outer sections that fit inside the wings removed). The cross section is correctable without altering the thrust line of the engines if you are careful and bond the formers at the leading edge first - give lots of time for the bond to fdry - and then bending the upper wing around the formers. You will need to remove/reduce a lot of the wing's internal structure as moulded. Would love to see some photos of your project! Iain Thanks for the advice! Do you think it’s worth the extra effort to fix the airfoil? I will send pictures soon. Thanks Link to comment Share on other sites More sharing options...
MikeMaben Posted July 29, 2020 Share Posted July 29, 2020 Hi Julian , your build looks pretty good Link to comment Share on other sites More sharing options...
Iain Posted July 29, 2020 Author Share Posted July 29, 2020 Profiles not on page 18 - but a page earlier... These are pretty definitive profiles - ignore inner cut lines for the spar. You'll also need to remove/reduce a lot of the internal re-enforcement - and thin the flaps, ailerons and wing tips accordingly - but I'm not at a stage where I can illustrate all of that yet. And, yes, worth doing IMHO. Iain patricksparks and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Julian Farian Posted July 29, 2020 Share Posted July 29, 2020 7 hours ago, MikeMaben said: Hi Julian , your build looks pretty good Thank you! I really appreciate it! I will post recent photos later MikeMaben 1 Link to comment Share on other sites More sharing options...
Julian Farian Posted July 29, 2020 Share Posted July 29, 2020 53 minutes ago, Iain said: Profiles not on page 18 - but a page earlier... These are pretty definitive profiles - ignore inner cut lines for the spar. You'll also need to remove/reduce a lot of the internal re-enforcement - and thin the flaps, ailerons and wing tips accordingly - but I'm not at a stage where I can illustrate all of that yet. And, yes, worth doing IMHO. Iain Hello Lain, I would just like to check that the following is a correct summary of what You’ve done and I will do. print ( print to scale) the image you posted earlier with the 1/32 airfoils on it. ( the big red draft) Then glue it on to a sheet of plastic. 1.5 or 2mm thick. Then cut out and make fine smooth edges. After that use a dremal or something to remove the unneeded support plastic in the wings and the wing root support thingy. Also thin down the wing root plastic. ( name has lost my mind) Then, like you did in previous posts glue the plasticard pieces in the same spots you did previously. Then glue on the other wing half and attach to plane. Is that a basic idea of what I should do? Thanks! Link to comment Share on other sites More sharing options...
Julian Farian Posted August 4, 2020 Share Posted August 4, 2020 On 7/29/2020 at 9:14 AM, Iain said: Profiles not on page 18 - but a page earlier... These are pretty definitive profiles - ignore inner cut lines for the spar. You'll also need to remove/reduce a lot of the internal re-enforcement - and thin the flaps, ailerons and wing tips accordingly - but I'm not at a stage where I can illustrate all of that yet. And, yes, worth doing IMHO. Iain Hello!not trying to rush you, but I’m at the point in my build where the info I asked for previously would be very helpful! Thank you very much, have a great day! Link to comment Share on other sites More sharing options...
