tomprobert Posted February 14 Share Posted February 14 (edited) @zeusbheld Early D models had the narrower chord props - I believe the diameter was the same as the paddle blades, however. In short, check references. It wouldn’t be too tricky to sand/file the early, narrower, prop from the paddle blade later version if push came to shove. EDIT. Here’s some pics. Early: Late: Edited February 14 by tomprobert Dennis7423, easixpedro, zeusbheld and 7 others 7 3 Link to comment Share on other sites More sharing options...
zeusbheld Posted February 15 Share Posted February 15 10 hours ago, tomprobert said: @zeusbheld Early D models had the narrower chord props - I believe the diameter was the same as the paddle blades, however. In short, check references. It wouldn’t be too tricky to sand/file the early, narrower, prop from the paddle blade later version if push came to shove. EDIT. Here’s some pics. Early: Late: fantastic photos, looks like either way the Quickboost props are the best solution currently available. it's between Quickboost and Quickboost thinned for me then. haven't picked a ship yet, most likely 90th BG but might do Sandman (Ploesti) if a do a different Ploesti ship in 1/72. next point of confusion: can't find any info on wheels. from aftermarket it looks like only the front changed from 8 to 9 spokes? also i don't see a lot of 'dust covers' in reference photos, but my stack of books from Amazon is in transit. Link to comment Share on other sites More sharing options...
armor fiend Posted February 16 Share Posted February 16 (edited) Iain, given how much work it's been to force the wings into compliance, might it not be easier to 3d print new wings? Edited February 16 by armor fiend Link to comment Share on other sites More sharing options...
Iain Posted February 16 Author Share Posted February 16 1 hour ago, armor fiend said: Iain, given how much work it's been to force the wings into compliance, might it not be easier to 3d print new wings? No, not in any way, shape, or form! Believe me - I've gone through ALL the options... If I can get the inserts to work it will result in a light/strong structure that keeps existing surface detail, most of the existing kit parts - and is relatively simple. This route will also be cheaper and take an awful lot less design effort. The wings are too large for complete resin prints - and if I could get a printer large enough - the results would be too heavy and relatively brittle. If printed on the FDM printer as complete wings you'd end up having to do a lot more work - and have to surface prep and engrave all external surfaces. I've been really busy elsewhere, but I will get back to looking at the CAD models at some point in the future. Iain MicroShket, MikeC, zeusbheld and 2 others 3 2 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted February 20 Share Posted February 20 On 2/16/2024 at 2:01 PM, Iain said: No, not in any way, shape, or form! Believe me - I've gone through ALL the options... If I can get the inserts to work it will result in a light/strong structure that keeps existing surface detail, most of the existing kit parts - and is relatively simple. This route will also be cheaper and take an awful lot less design effort. The wings are too large for complete resin prints - and if I could get a printer large enough - the results would be too heavy and relatively brittle. If printed on the FDM printer as complete wings you'd end up having to do a lot more work - and have to surface prep and engrave all external surfaces. I've been really busy elsewhere, but I will get back to looking at the CAD models at some point in the future. Iain Also wonder the cost in resin to print a wing, it isn't cheap and getting higher here in the States. With that, and the insane cost to ship large items, will it be possible to buy the print file? Link to comment Share on other sites More sharing options...
zeusbheld Posted February 20 Share Posted February 20 On 2/17/2024 at 5:01 AM, Iain said: No, not in any way, shape, or form! Believe me - I've gone through ALL the options... If I can get the inserts to work it will result in a light/strong structure that keeps existing surface detail, most of the existing kit parts - and is relatively simple. This route will also be cheaper and take an awful lot less design effort. The wings are too large for complete resin prints - and if I could get a printer large enough - the results would be too heavy and relatively brittle. If printed on the FDM printer as complete wings you'd end up having to do a lot more work - and have to surface prep and engrave all external surfaces. I've been really busy elsewhere, but I will get back to looking at the CAD models at some point in the future. Iain if you start a kickstarter or patreon for this wing fix i'll be the first one in... MicroShket 1 Link to comment Share on other sites More sharing options...
MicroShket Posted February 21 Share Posted February 21 18 hours ago, zeusbheld said: i'll be the first one in... Many would like to be. But this project has been going on for almost 6 years... :с Link to comment Share on other sites More sharing options...
Iain Posted February 23 Author Share Posted February 23 Hi all, I'm temporarily locking this thread at the present time. Recent interest is lovely to see, and really appreciated, but has been a catalyst to some self-imposed pressure/stress/anxiety which I could really do without at present, as I've been really busy on other things. However, I have been honing my 3D design skills so, as soon as I can find some time to sit down and focus on the Liberator again, I'll hopefully have something closer to a solution. And when I'm there I'll post here... Thank you, Iain Out2gtcha, Astro32, CharmyDown and 10 others 13 Link to comment Share on other sites More sharing options...
