Hi,
my new project is a Trumpeter P-40B/Tomahawk in African RAF colors:
Photo of my plane:
It will be mostly from the box. Now i'm doing the cockpit. I found an easy way to correct it's too high position. I cutted the support for floor and i putted it under the back plate:
After this i added an rib extension to cover a hole which appeared:
I know that this is not entirely correct but for me it's good enough.
Edited by shadowmare
Guest Peterpools
Terrific subject and looking forward to following your progress
Keep 'em coming
Peter
the pit sidewalls are looking quite good. The color of the Interior Green paint and the associated weathering really does look dead on. The detail spring and cables for the tail wheel assembly is something we don't get to see very often.  Looking forward to your next update.
Joel
Thanks!
Now it's time for making surface suitable for painting. I don't like this stage.
   Not many of us like all the putty and sanding work either, but it's the key to a great paint job for sure. As the pros say: It's 90% of the painting process.
Joel
Joel
In my case painting process may last longer than build  :D
I decided to buy Master Set with gun barrels and pitot tube - beautiful thing. More info:
http://www.master-model.pl/product/am-32-098.html
I will use Techmod decals for Spitfire because they contains decals with X needed for my scheme.
Looking good, I think that this kit was the first Trumpeter kit that I built and I thoroughly enjoyed it.
Cheers
Dennis
Looks like you have exceeded your limit. No pics.......Harv
Photobucket blocked hosting for me, but i think that photos will be available next month. Last photos which i posted here:
