airscale Posted August 25, 2016 Posted August 25, 2016 Ho Lee Sheet... this will teach me not to look in on jet builds - this is some outstanding modelling - that cockpit is one of the best I have seen bravo & will definately be tuned in from here on in Peter Babs 1
thewizardofaz Posted August 29, 2016 Posted August 29, 2016 Good jobs on all the parts Babs. Did you ever look at the F-15I conversion kits available from IsraCast (32019) and Wolfpack (32022) ? I haven't decided which to use in my E to I conversion. What I need to do is sit down and count the pieces of each, then compare them to see which I want to use The Wolfpack kit has a lot more pieces. We have no way of knowing what the I cockpits really look like other than the use of black as the interior color. They report it went to black to cut back on spurious shiny flashes when night flying. One other major (?) difference are the twin rear booms at the back jutting out from the fuselage..back by the twin tails. Those two booms have different shapes and sizes than the E version kits and have to be cut off and replaced for accuracy.There's also a couple of pieces that the IsraCast kit has to update the front landing hear. I;m going to use the fatter Northstar wheel/tire set on the I and then I'm not sure what I will use on the D when I get to it.
Babs Posted August 30, 2016 Author Posted August 30, 2016 Hello Rick, I do not have the IsraCast kit, is it still available? I had initially the Wolfpack kit and the old cutting edge (that I bought at very good prices). I know the Wolfpack is still available, you should take advantage because tomorrow ??? I have already used parts of two sets by choosing the best for me. If parts I do not like in the two sets? I try to remake them or improve in scratch. As the tail boom and the Shimmy dampener on the nose gear. Thank you.
Babs Posted October 2, 2016 Author Posted October 2, 2016 (edited) Hello, a small up after a break. I do not know if it is noticed by the assemblers of the F-15 Tamiya but there are four holes must be reseal near the air intakes. It is never mentioned in the different WIP. So, here it is corrected with plastic card. Edited October 8, 2017 by Babs Starfighter, Marcel111 and F`s are my favs 3
Babs Posted October 2, 2016 Author Posted October 2, 2016 (edited) The windshield poses an adjustment problem, I have often noticed on other constructions that this step had posed finishing problems as the windscreen joined to the fuselage. I decided to reproduce the framework of windshield as on the photos. The plastic card also makes it easy to reproduce the different rivets, the difficulty is not to place the glue accidentally on transparant part. Edited October 8, 2017 by Babs Shaka HI, Starfighter, NavyF4s and 2 others 5
F`s are my favs Posted October 2, 2016 Posted October 2, 2016 Nice updt! The cockpit is awesome with these all-black colors. Btw the holes around the intakes, if I remember justly, the huge piece behind the canopy covers exactly the holes from the upper holes. While the ones from the lower sides are really pretty nasty. It's a great benefit to cover them that way! Awesome!
jmel Posted October 2, 2016 Posted October 2, 2016 I really look forward to your progress reports. Such attention to detail and clean work is inspiring! Jake Babs 1
Babs Posted October 2, 2016 Author Posted October 2, 2016 Nice updt! The cockpit is awesome with these all-black colors. Btw the holes around the intakes, if I remember justly, the huge piece behind the canopy covers exactly the holes from the upper holes. While the ones from the lower sides are really pretty nasty. It's a great benefit to cover them that way! Awesome! Thanks F' are my favs, the huge part behind the cockpit does not entirely mask the hole, but I still added a larger plastic piece as needed. F`s are my favs 1
Marcel111 Posted February 4, 2017 Posted February 4, 2017 (edited) Beautiful work on that canopy framing! Marcel Edited February 4, 2017 by Marcel111
ClumsyDude Posted February 4, 2017 Posted February 4, 2017 Super stuff Babs! How did you glue that plastic to the clear without any fogging or distortion? It looks brilliant. Jim
