Shaka HI Posted February 14, 2016 Author Share Posted February 14, 2016 (edited) Slight step in front of the cockpit (accentuated by the angle/lighting). No gaps, even in the wing roots/attachment points in the underbelly. There's a "pin" in that area that I should've removed before closing it up I think -- it would've provided me a little more wiggle room to even that area up during cementing (or rushing and NOT heeding a warning given to me about removing paint completely due to the precision of these kits!!): ..on a slight tangent, while the moving surfaces is novel, I doubt the real aircraft had gaps like this when an aileron's in the up position? Edited February 14, 2016 by Shaka HI dmthamade and geedubelyer 2 Link to comment Share on other sites More sharing options...
mozart Posted February 14, 2016 Share Posted February 14, 2016 In my experience ailerons rarely moved that much, only a very slight movement is required to start inducing a turn. Max Shaka HI 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 15, 2016 Author Share Posted February 15, 2016 Almost complete with detail painting of the Engine components....while I wait for the glue to dry... Testor's Metallic Silver and Copper..is there anything better? Such awesome paints! geedubelyer and dmthamade 2 Link to comment Share on other sites More sharing options...
Guest Posted February 15, 2016 Share Posted February 15, 2016 That is a nice copper.....Harv Link to comment Share on other sites More sharing options...
dennismcc Posted February 15, 2016 Share Posted February 15, 2016 That copper takes me back to all the plumbing jobs that I used to do, most realistic. Cheers Dennis geedubelyer 1 Link to comment Share on other sites More sharing options...
dmthamade Posted February 15, 2016 Share Posted February 15, 2016 Are you going to add any additional plumbing or wiring to the engine? Don Link to comment Share on other sites More sharing options...
Shaka HI Posted February 15, 2016 Author Share Posted February 15, 2016 Are you going to add any additional plumbing or wiring to the engine? Don It just seems to beg for it doesn't it? I've been studying the builds of other members this morning -- and while the detail work is admirable, I'm not sure if it's for me because I know I won't particularly enjoy it. For example, I started the Zero build and decided to try some scratch building of the ignition ring/wiring(I have no clue what this is actually called) with aluminum tubing/solder/bead wire. Didn't particularly enjoy it, but it's so visible, it seems incomplete without it: I didn't plan to wire up the Spitfire's engine..but we'll see. dmthamade and geedubelyer 2 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 15, 2016 Author Share Posted February 15, 2016 (edited) Couple of hours to correct the screw up....sanding very carefully, but detail lost is inevitable, unfortunately, the raised area in front of the windscreen had most of it sanded off -- I used a scribing tool to mimic the raised panels and I suppose it doesn't look too bad. Whatever rivet detail was replaced with a beading tool. CA was also used to completely seal the area..I'll brush some primer to see how it looks a little later, but viewed from a low angle with a light source in front shows that it's fairly smooth. Lastly, any advise on actually gluing the control surfaces? (Edit: I also test fitted the windscreen and it still fits like a champ!) Edited February 15, 2016 by Shaka HI dmthamade and geedubelyer 2 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 16, 2016 Author Share Posted February 16, 2016 LOL..thanks Maru! More detailed painting on the engine components. I picked out all the bolts with silver and I'll probably go back and re-do all of them to have them stand out a bit more. Not sure how accurate it is, but it adds detail and interest. I had to stop because my eyes were starting to get crossed-eyed. I know it doesn't seem like much has changed, but I've been at it for a good 6 hours today, even foregoing my usual chores! It's been a productive weekend. dmthamade and geedubelyer 2 Link to comment Share on other sites More sharing options...
mozart Posted February 16, 2016 Share Posted February 16, 2016 Lovely work throughout Shaka, keep it up! What sort of advice are you wanting regarding control surfaces? Max Link to comment Share on other sites More sharing options...
Shaka HI Posted February 16, 2016 Author Share Posted February 16, 2016 Hey Max, I want to glue the control surfaces in place and wonder if there's a better option to using liquid cement -- a potential disaster in the making for me. I think I'll drill holes in the right places and use some stiff wire to keep them in place in the desired positions, but I'm concerned that the wire may show a bit. Link to comment Share on other sites More sharing options...
monthebiff Posted February 16, 2016 Share Posted February 16, 2016 Looking good, your engine bay is coming on nicely. Regards. Andy Link to comment Share on other sites More sharing options...
geedubelyer Posted February 16, 2016 Share Posted February 16, 2016 Hi Shaka, this update is excellent. The paintwork is beautifully crisp. Good job. That copper looks superb and appears as close to polished metal as I can ever remember seeing. The whole engine cradle and bulkhead looks marvellously busy and convincing. Keep it up. Cheers. Link to comment Share on other sites More sharing options...
Shaka HI Posted February 19, 2016 Author Share Posted February 19, 2016 Not much of an update......in the middle of cleaning up the rest of the seams for priming -- hopefully this weekend. More detailed painting/drybrush of the engine...Heavier slush wash using thinned Future (I like the subtle effect it produces), then a flat coat for the engine framing/firewall...that's about it for the rest of the week. geedubelyer 1 Link to comment Share on other sites More sharing options...
Shoggz Posted February 19, 2016 Share Posted February 19, 2016 Fabulous! geedubelyer 1 Link to comment Share on other sites More sharing options...
