LSP_Kevin Posted September 6, 2015 Author Share Posted September 6, 2015 Kev Same here. On my end of the screen, the wings look brilliants and smooth as can be. Keep 'em coming Peter Thanks, Peter. I just wasn't happy with the finish or my surface preparation on close inspection. I thought they looked pretty good too, at first! They'll be much better the second time around, I think. Kev Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 13, 2015 Author Share Posted September 13, 2015 Well folks, it's taken me long enough, but I've finally been able to refinish these damned wings! Ironically they don't look that much different in the photo, let alone better, but the difference to the naked eye is obvious. I used Micromesh pads on this one, and I really must get some of the cloths, as the pads have edges that can catch on surfaces, and that's what they did here. Again, you can't tell in the photo, but there are some micro scratches on the surface, plus one really big, nasty one! It doesn't matter now, as I'm done with this phase - I'm not doing them again! But please, remind to get some Micromesh polishing cloths before I tackle this kind of finish again. Kev LSP_Ron 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted September 13, 2015 Share Posted September 13, 2015 Kev On my end the wings look absolutely perfect. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
FunkyZeit Posted September 15, 2015 Share Posted September 15, 2015 Wicked stuff Kev! Justin Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 15, 2015 Share Posted September 15, 2015 Looking good, Kev. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 15, 2015 Author Share Posted September 15, 2015 Thanks, lads. I'm hoping to get back to it shortly. Just trying to push on with my Corsair cockpit at the moment (plus yet more reviews). Kev Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 24, 2015 Author Share Posted September 24, 2015 Well, another token update chaps, thanks to my glacial build rate! I even have this week off work, but with plenty of chores and other sundry duties to attend to (tax, car service, etc), I've found that any plans I had for extended time at the workbench have evaporated. I did at least make some headway with the Corsair. Anyway, I got the wings glued on this one: I deliberately left the cockpit window part off so that I could check the alignment of the tabs on each wing, which are supposed to interlock inside the fuselage. Is OK I think. My next job is to add some weight in the nose before adding the glassware. Before that, though, I have some ugly gaps to deal with at the wing roots. This one is typical: Out with the Milliput! I bought a new pack, too, just for the occasion. Kev Girlscanplay2, Lars Befring, Derek B and 1 other 4 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 24, 2015 Share Posted September 24, 2015 Well isnt that a treat! I always have had such an aversion to painting before assembly, but so many of you guys are doing it with great results, I just may have to give it a shot again. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 24, 2015 Author Share Posted September 24, 2015 Thanks, Brian. I normally don't do it either, but in this case, I decided I'd never be able to produce a decent NMF on the insides of the inboard engine nacelles once the wings were glued in place. There's hardly any room to get an airbrush down there. Originally I was planning to only paint those areas prior to assembly, but ended up doing each wing entirely. Not even sure why! Still, once I've dealt with those gaps, I'm going to have to repaint those areas. The lower fuselage up to the wing root is NMF too, so I'll need to blend it all very carefully! Kev Out2gtcha 1 Link to comment Share on other sites More sharing options...
HL-10 Posted September 24, 2015 Share Posted September 24, 2015 Just caught up with this build. Some very nice work going on, very impressive Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 24, 2015 Author Share Posted September 24, 2015 Thanks, Angelo! This was meant to be a quick'n'easy build to give me something less...challenging...than the Corsair, but unfortunately it hasn't turned out to be that way. Oh well. Kev Link to comment Share on other sites More sharing options...
Guest Peterpools Posted September 24, 2015 Share Posted September 24, 2015 Kev Nice progress on the Stratocruiser and those surely are some nasting looking gaps at the wing roots. Nothing like a quick build where the kit just falls together. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 24, 2015 Author Share Posted September 24, 2015 Thanks, Peter. I was really surprised when I did my test fit, at just how bad they are for such a small kit. Still, a bit of Milliput should sort them out. Kev Link to comment Share on other sites More sharing options...
Girlscanplay2 Posted September 26, 2015 Share Posted September 26, 2015 Looking great Kevin! Milliput, and Mr. Surfacer are my friends! Very nice job so far! Teresa Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 26, 2015 Author Share Posted September 26, 2015 Thanks, Teresa! As it happens, I changed my mind about using Milliput, and went with some of the Perfect Plastic Putty instead. I'm hoping to post some photos a bit later on. Kev Link to comment Share on other sites More sharing options...
