amurray 504 Posted August 19, 2014 Author Share Posted August 19, 2014 (edited) I promised myself that I would resist detailing this kit. But after I painted them the sparse wheel wells and the absolutely barren speed brake wells screamed for attention. I did not buy the resin wheel well and speed brake wells from True Details. Instead I used scrap plastic, Evergreen strip, solder and electrical wire. I also detailed the ejection seats with solder and plastic and then washed them with oils thinned with turpenoid. I have to re-paint the parts as I had painted the wells before deciding to detail them but the contrast shows the detail. Edited February 1 by amurray Update Derek B, Harold, daveculp and 1 other 4 Link to post Share on other sites
amurray 504 Posted August 23, 2014 Author Share Posted August 23, 2014 (edited) The intakes are coming along but they are a pain! I sprayed primer on them to identify the remaining problem areas and then sanded them. I'll have to do some additional minor filling, sanding and some re-scribing. BTW the plastic on my kit is VERY soft. That makes sanding and filing easy but it also causes surface detail to disappear in a hurry. It also makes re-scribing easy. The toothpick shim under one of the wing fairings (see a previous post above) did not work as I had hoped because the tension was too great. When I removed the toothpick the part sprang back to its original shape and the glue and putty cracked. The filled gap was too wide and wasn't strong enough to hold across the two parts. To correct the problem I placed a plastic shim under the intake at the wing fairing and applied ample liquid glue. This time I'll leave the shim in place permanently. I will trim the shim after the glue sets and then add filler again. I'll probably use super glue in the gap this time instead of putty. It should hold. While I was waiting for paint to dry I removed the rear section of the wing at the fuselage join as suggested by others. Edited March 7 by amurray Update Derek B, Landrotten Highlander and daveculp 3 Link to post Share on other sites
LSP_Ron 14,130 Posted August 23, 2014 Share Posted August 23, 2014 Looks great Link to post Share on other sites
amurray 504 Posted August 24, 2014 Author Share Posted August 24, 2014 (edited) Time to scribe the scratchbuilt tail sections. I used the paper parts as templates. This time, though, I made many copies and cut out the parts by sections. Notice I had to add hinges for the horizontal stabilizer. Also, I can't see any trim tabs on any of the three reference photos so I'll omit those. There is also one horizontal line in the center section that I'll omit. I'll also use the templates to mark the locations of the horizontal stabilizer where it meets the vertical tail sections. Edited February 1 by amurray Update Harold, Landrotten Highlander and Out2gtcha 3 Link to post Share on other sites
amurray 504 Posted August 28, 2014 Author Share Posted August 28, 2014 (edited) There is one area depicted in all three photos that I debated tackling but decided to take it on. It is the area under the fuselage under the tail. It is prominent in all three reference photos. It is a recessed area with perforations. Aft of it is a package that looks like a parachute with a tripwire to deploy the chute. But I scratch my head over the recessed panel itself. I can only guess that maybe the enlarged tail section attached to the fuselage would not dissipate heat from the engine sufficiently so thinning the panel and perforating it may have been a quickfix. Any of your thoughts on the matter are appreciated. At first I thought about removing the area and putting a thin plastic sheet or piece of metal in its place. I decided not to cut it out but to thin the area instead because the locator for the tailpipe is there inside the fuselage and would have been obliterated. Also, the resulting section at the end of the fuselage would be very fragile. I have started thinning the panel with metal files and a sanding Flex-I-file. Edited February 2 by amurray Update Derek B and daveculp 2 Link to post Share on other sites
Lee White 3,131 Posted August 28, 2014 Share Posted August 28, 2014 Looks like an Ercoupe on Steroids!! Iain 1 Link to post Share on other sites
Shawn M 9,542 Posted August 28, 2014 Share Posted August 28, 2014 my guess is the detail at the rear is for the recovery chute used during spin testing daveculp 1 Link to post Share on other sites
amurray 504 Posted August 28, 2014 Author Share Posted August 28, 2014 my guess is the detail at the rear is for the recovery chute used during spin testing Interesting! Any idea how that would work in practice? I see the chute itself at the tail but what is the function of the perforated panel? Link to post Share on other sites
amurray 504 Posted August 29, 2014 Author Share Posted August 29, 2014 (edited) My decision to shape the recessed panels versus cutting and replacing worked well. I delved into my tool box and found all the tools necessary, save one - a large square file. The file I found at Harbor Freight for $3. These tools made very quick work of the project. A little finishing sanding and all will be well. The perforations are irregular as shown in the photos. The tools: Scriber (not shown) Large file Dremel and two stock attachments: small sanding drum and stone polisher Diamond-tipped Dremel accessories Flex-i-file Stainless Steel INCRA Rule Finger drill Edited February 2 by amurray Update Landrotten Highlander and Derek B 2 Link to post Share on other sites
Loic 1,928 Posted August 29, 2014 Share Posted August 29, 2014 That's some fine work Derek B 1 Link to post Share on other sites
Shawn M 9,542 Posted August 29, 2014 Share Posted August 29, 2014 my guess is the perforated panel would be a stiffener plate of some sort Link to post Share on other sites
amurray 504 Posted August 29, 2014 Author Share Posted August 29, 2014 That's some fine work Thanks! Link to post Share on other sites
amurray 504 Posted August 29, 2014 Author Share Posted August 29, 2014 my guess is the perforated panel would be a stiffener plate of some sort How does a stiffner plate work? Link to post Share on other sites
amurray 504 Posted August 29, 2014 Author Share Posted August 29, 2014 (edited) The AMS Resin tailpipe and engine set are a must unless you scratchbuild your own tailpipe. The kit tailpipe is much too short. The AMS Resin engine part needs some simple sanding/thinning of the upper lip of the piece. It is too large and visible when the two pieces are mated thus giving a reverse telescoping effect. It is a simple fix. The AMS tailpipe part fits perfectly IF one aligns it properly in the slot inside the fuselage. The mounting flange on the tailpipe is oval, not circular. Be sure you align the oval correctly with the inside of the fuselage. Edited February 2 by amurray Update Derek B and Harold 2 Link to post Share on other sites
amurray 504 Posted August 31, 2014 Author Share Posted August 31, 2014 (edited) As I continue with sub-assemblies I now have to deal with one of the inexplicable engineering problems with this kit. The axles on the wing gear struts are........1/32 of an inch! The receiving part of the wheel hub (resin) is the same. I bought the Scale Aircraft Conversions white metal set ostensibly to better support the weight of the model with metal. It is simply an exact metal copy of the Plastic kit part. I suspect 1/32 of an inch won't support much for long even using 2-part epoxy. Should I solder a metal extension onto the white metal part? Epoxy a plastic extension onto the metal part? Or, use the kit plastic part and glue a plastic extension on the axle? Edited March 7 by amurray Update Derek B and Landrotten Highlander 2 Link to post Share on other sites
