LSP_Kevin Posted September 11, 2010 Posted September 11, 2010 looks like he's texting someone!! Isn't it! Kev
Allok Posted September 11, 2010 Posted September 11, 2010 Looks Great Dave. looks like he's texting someone!! Isn't it! Kev He, like, totally does. Isn't it! You guys are funny
DaveJ Posted September 13, 2010 Author Posted September 13, 2010 Here's another small update... Some of you may know that I've recently departed from my primary interest and have been attempting to build some armor. Fun stuff but it requires a different approach to some things. Mainly I want to get better at weathering and scale effects. The reason I bring that up is because I decided to play around with some Mig filters on this. I used some on the interior fuselage walls and am rather tickled with how it came out. First, just some pre-shading and paint: Then some very light filters added. Can't see much of an effect yet: Afterwards. Please note that, while it looks kinda goofy and overdone in the macro lens, to the Mk.I Eyeball it has an entirely different effect. It's also going inside a closed fuselage only to be seen from an angle. It has a multi-tonal effect then that is pretty cool. A first for me. From more of a distance you can hopefully get a better idea. Should have a bit more to show in a couple of hours....
LSP_Ron Posted September 13, 2010 Posted September 13, 2010 Looking good Dave. Not a bad kit over all eh?
DaveJ Posted September 16, 2010 Author Posted September 16, 2010 Looking good Dave. Not a bad kit over all eh? Thanks, Ron. It is a pretty decent kit so far, no real issues. Yet. I got the fuselage closed up the other night. There is a small gap at the base of the tail on top, but nothing a small amount of filler won't take care of. When I test-fitted the bottom part of the fuselage I noticed that there was going to be a step. Maybe I glued the two halves together to well, not sure, but the fix I used was a piece of sprue to spread the halves just a tiny bit. This was as close as I could get it. It resulted in one or two places where the sides overlapped the bottom just a tiny bit but some careful sanding remedied that without losing any of the raised fastener detail. I then added the fairing for the tail wheel: Due to there being more than one rudder and tail wheel assembly molded with this kit, PCM chose to have a separate lower portion of the rudder rather than have two different, complete rudders. This would not have been my choice if I were engineering the kit since it leaves a join that needs to be dealt with. That join bisects a fabric-covered surface and so will involve some care not to have it visible when painted. Shouldn't be too bad though. Next up will be the main landing gear bay and the wing! Thanks for looking....
LSP_Ron Posted September 16, 2010 Posted September 16, 2010 Looking good, I had exactly the same small issue areas on mine. Don't forget to fill the large sink holes on tail wheel flaring.
DaveJ Posted September 17, 2010 Author Posted September 17, 2010 Looking good, I had exactly the same small issue areas on mine. Don't forget to fill the large sink holes on tail wheel flaring. Those are sink holes??? Thanks for the heads-up!
ColinR Posted September 23, 2010 Posted September 23, 2010 Yup Sinkholes, but nothing that Superglue won't cure.. ! this trhead looks a lot like my workroom over the last few weeks, I'm working through my Metal Wing Hurricane at the moment - in fact I just finished spraying the green yesterday evening - which markings are you using? , in deference to my country of origin , mine will be finished at Archie MCkellar's 605 Sq aircraft , hey he's got a lion rampant on the fusalage - I can't pass that up! I look fordward to seeing your Hurricane completed
DaveJ Posted September 25, 2010 Author Posted September 25, 2010 which markings are you using? , in deference to my country of origin , mine will be finished at Archie MCkellar's 605 Sq aircraft , hey he's got a lion rampant on the fusalage - I can't pass that up! I look fordward to seeing your Hurricane completed Thanks, Mate. I'm still not sure which markings I'll be using. Guess I need to decide soon since it's about time to start on the prop.... The main landing gear bay is a nicely cast bit of resin with nice detail throughout: As is usually the case with resin, a substantial amount of material needs to be removed to get it to fit inside the wing: Note that I almost went through the bay roof in a few spots. Don't remove that much material... After a base coat of aluminum, the details were picked out. Then a coat of Future and a wash with Mig Pigments dark wash. Lovely stuff, that. I'm aware that the tank shouldn't be yellow, I just wanted a splash of color in there to liven things up a bit. It also doesn't look the very best under the harsh eye of the macro lens. After it's been installed in the wing and viewed from a more realistic distance. I'm happy enough with how it looks here, it just needs a flat coat which will come at the end along with the rest of the model. Thats it for now.... As always, thanks for looking!
nmayhew Posted September 26, 2010 Posted September 26, 2010 Dave i like the look of the wheel well hadn't realised the way they engineered the tail - that is a bit crap isn't it? still, these things are sent here to test us aren't they?! thanks for sharing Nick
DougN Posted September 27, 2010 Posted September 27, 2010 This was as close as I could get it. It resulted in one or two places where the sides overlapped the bottom just a tiny bit but some careful sanding remedied that without losing any of the raised fastener detail. Not trying to hijack, but in case you (or anyone else building this kit) are interested, I could not find any photos of the real thing with those fasteners on the bottom. You do need to add the (drain/attachment I beleive) holes inside the panel lines. 3 on each side of the panel, one on each end, and one in the middle. Unfortunately, it appears that the strake itself is a bit too short, as it goes to the middle panel line in the photos I examined. The only other bit for this area is that the strake has a panel line that separates it into two parts, one part being from the wheel attachment back and the other the forward bit. If you put the line in the strake where it is supposed to be, it should align perfectly with the back panel line of the ribbed underside panels, which is does not (it's off by a mm or two). I just extended the panel line on the fuselage back so that it aligned properly on the fabric wing build I have going. Here is a pic I scanned that shows what I am on about: Looking good thus far, looking forward to the next installment! Cheers, Doug
