ChuckT
569 -
Posts posted by ChuckT
I want to order Achim Engels PDF book on the Fokker Dr.I and have sent him an email. He says on his webpage that he doesnt use banks, so I'm woundering if anyone on here has ordered one of his PDF books and what the process was like?
Thanks.
I agree, evergreen is good stuff, but I need a diameter of .01" (.26mm). The smallest evergreen offers is .02" (.5mm)
Thanks though.
I need a consistent thin thickness that I cant achieve with styrene.
Very sharp as usual Wolf. Looking forward to further updates, Chuck.
Thanks guys for the info. I though I was going to have to straighten the wire out, but it sounds like its going to be fine.
Stay safe, Chuck.
I have some .013” (.33mm) piano wire coming in the mail that I want to use to simulate push rods on a radial engine. The wire is made from spring steel but it comes in a roll which I believe imparts a bit of a curve to the wire when cut into short sections.
Has anyone out there had success straightening piano wire? If so, can you share your technique?
Thanks.
Looks great!
- Dennis7423, mpk and Martinnfb
- 3
10 hours ago, 109 said:
Hi Chuck,
I used the fast drying alkyd oils from Winsor & Newton over a flat tan colored underpainting. Used van Dyke brown and umber.
1. Apply flat tan colored base coat, e.g. good old Tamiya buff (see below)
2. Apply a coat of oils and let drying begin. Alkyds dry fast, some 20 mins and they start to dry. Do a test in advance!
3. Remove exessive oils while they are starting to dry with a flat brush to reveal the base coat.
4. Apply scratches and scuffs with a tooth pick.
5. Apply a dark wash around the cushions.
For the base coat I tried the new Humbrol enamels and they are a pain in the a__. Way off the old quality enamels :-(
HTH!
A couple more questions if you don't mind.
- Do you use raw umber or burnt umber?
- Do you apply one of the oil colours over the entire seat/remove excess, then apply the other oil?
Thanks again.
Looking sharp Chuck. Great job!
Sorry to hear about your job but glad to see you back to posting on here.
Looking forward to the next update (and welcome back!),
Chuck.
- Wolf Buddee and williamj
- 2
Thanks for the confirmation.
C.
Thin aluminum foil source?
in Construction & Scratch-building
Has anyone come across thin aluminum foil? I’m looking for something like the foil you find in a cigarette pack. I though about aluminum leaf, but that’s just too thin.
Any ideas?
Thanks.
