BloorwestSiR Posted March 18, 2016 Author Share Posted March 18, 2016 You're absolutely right Shaka. It definitely simplifies the build and lets me leave out a lot of painting and assembly. I figure I've two already with fully painted and assembled engines so I'd save myself some work. A small update for the moment. I've cleaned up the inside of the fuselage in the cockpit area of ejector pin marks and started painting the various cockpit pieces. I've given them a quick wash and after a dry brush, I'll start the detail painting. Shaka HI, mozart, geedubelyer and 3 others 6 Link to comment Share on other sites More sharing options...
Shaka HI Posted March 19, 2016 Share Posted March 19, 2016 Nice, very crispy paint/detail work! geedubelyer 1 Link to comment Share on other sites More sharing options...
dmthamade Posted March 19, 2016 Share Posted March 19, 2016 Nice fix on the wing bulges!! Just a heads up, i've repaired holes using this method, found the repaired area shrunk and caused a sink mark long after it appeared hard. Those movable surfaces reminded me of the early Trumpeter kits, was suprised to see them on a Tamiya kit. Interested to see how the engine/panel assembly fits to the fuselage. Dob BloorwestSiR 1 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 19, 2016 Share Posted March 19, 2016 Nice work Carl. Omitting the engine or rather, closing it in, certainly helps the build progress. I did the same on a P-51D a while ago. Nice job on the cockpit components. Cheers. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 19, 2016 Author Share Posted March 19, 2016 Nice fix on the wing bulges!! Just a heads up, i've repaired holes using this method, found the repaired area shrunk and caused a sink mark long after it appeared hard. Those movable surfaces reminded me of the early Trumpeter kits, was suprised to see them on a Tamiya kit. Interested to see how the engine/panel assembly fits to the fuselage. Dob Don, thanks for the heads up on the possible shrinkage. I'll keep an eye on it. Hopefully since the styrene blank i glued in was mostly flush, there won't be any shrinkage or very little. Nice work Carl. Omitting the engine or rather, closing it in, certainly helps the build progress. I did the same on a P-51D a while ago. Nice job on the cockpit components. Cheers. Guy, it has certainly accelerated the build quite a bit. I'm still working on the cockpit but once it's done, I think it'll go even faster. Carl dmthamade and geedubelyer 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 25, 2016 Author Share Posted March 25, 2016 Thanks Maru! I've made more progress on the build. I assembled the rest of the cockpit components starting with the seat bulkhead. I used fabric belts made by Wako. The instructions were a bit unclear but after reading the ones included with their deluxe set, I was able to figure them out. I then built the IP bulkhead and side panels. All together: MikeC, sandokan, geedubelyer and 2 others 5 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 25, 2016 Author Share Posted March 25, 2016 Which meant it was time to close up the fuselage halves. After this dried, I gave the seams a quick sanding. There are a couple small gaps to fill but Mr Surfacer 500 well take care of them nicely. The fuselage bone is connected to the wing bone... ...and it's starting to look like a Spitfire. sandokan, geedubelyer, MikeC and 1 other 4 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 25, 2016 Author Share Posted March 25, 2016 On a slightly unrelated note, has anyone used the Masterdetails pilot figure in their Spitfire build? I'm concerned about the pilot's size, in particular his height. Here's the torso compared to the Tamiya kit pilot: The chute pack is shaped to fit into the kit seat but when you do so, he's still quite a bit taller. Masterdetails pilot: Tamiya pilot: Any thoughts? Should I trim the chute pack and/or seat down a bit and get him to sit lower? Or will he fit OK? Carl MikeC, geedubelyer, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
dennismcc Posted March 25, 2016 Share Posted March 25, 2016 See if he fits with his head on and the canopy in place ? Cheers Dennis Link to comment Share on other sites More sharing options...
mozart Posted March 25, 2016 Share Posted March 25, 2016 I'd be tempted to trim the parachute pack till he fits well, but it depends on which is the better figure from the moulding point of view; the crisper the moulding to easier the figure is to paint in my experience. Max Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 25, 2016 Author Share Posted March 25, 2016 Dennis, so I tried with his head on and the canopy won't close. So I guess I'll have to do some trimming. Max, the Masterdetails figure is in tropical dress and will be for a MK VIII build. As well, the detail is quite nice and better than the Tamiya one. I was just surprised by the size difference. Carl Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 25, 2016 Share Posted March 25, 2016 Carl Terrific work on the front office. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Shaka HI Posted March 26, 2016 Share Posted March 26, 2016 Confused? Build will include pilot? What about those wonderful belts? Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 26, 2016 Author Share Posted March 26, 2016 Carl Terrific work on the front office. Keep 'em coming Peter Thanks Peter! I've definitely been able to doesn't sound good at the bench today so I'll post an update shortly. Confused? Build will include pilot? What about those wonderful belts? Hi Shaka, the pilot is for another build. I had this one together so I thought I would check the fit of the pilot before I tackle that build. I have a Tamiya Mk VIII I want to build in-flight. Since I plan to do it as Grey Nurse,a pilot figure in tropical flight gear is more appropriate which the Masterdetails one is. So I'm just thinking ahead. Sorry to confuse you. Carl Shaka HI 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 26, 2016 Author Share Posted March 26, 2016 So, while waiting for the fuselage and wings to dry, I put together the tailplanes,rudder and prop. I then attached the rudder and tailplanes to the fuselage. Again, I just glued them directly on and eliminated the PE hinges and rods. For the first time,I ended up with some fit issues regarding the engine cowls. I'm not sure what happened so I decided the best approach was to start with the lower cowl. This has the most positive mount to the fuselage so I glued that on first. MikeC and sandokan 2 Link to comment Share on other sites More sharing options...
