LSP_Ron Posted May 16, 2017 Share Posted May 16, 2017 Very nice Link to comment Share on other sites More sharing options...
Martinnfb Posted May 16, 2017 Share Posted May 16, 2017 Utterly beautiful work Mike. Link to comment Share on other sites More sharing options...
seiran01 Posted May 16, 2017 Author Share Posted May 16, 2017 Thanks guys! That prop really does look stunning...wanna paint mine??LOL LOL... no, you can do this one yourself Link to comment Share on other sites More sharing options...
seiran01 Posted May 27, 2017 Author Share Posted May 27, 2017 Somewhere in here there's a real update, but the last 8 hours of build time yesterday/today was simply spent removing, cleaning up, and painting the interplane struts and control horns. Now that they're clear-coated, I can start attaching them and prepare to rig the tail surfaces. Need to figure out how to do some gentle post-shading first, I've never really played with effects after the paint is down (minus some staining and simple washes). Any suggestions? Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted May 28, 2017 Share Posted May 28, 2017 Mike I find that variations on the base coat works best. Extremely thinned lighter and darker versions sprayed over the top. No problem if you make a mistake as the paint is so thin you wont see it. Glosscoat to seal and personally I find the Vallejo washes work best for me. Note though the order of things staining the paint. Not that I need to tell you anything....I have a lot to learn from you! Cheers Anthony Link to comment Share on other sites More sharing options...
seiran01 Posted May 29, 2017 Author Share Posted May 29, 2017 Alrighty, progress worth sharing! One side of tail surfaces rigged and exhaust painted and attached. Exhaust was painted Tamiya semi-gloss black and sprayed with Aclad exhaust manifold, burnt metal, jet exhaust and gunmetal (overkill?), and finished with a light "painting" of AK track rust pigment in strategic areas using an old brush. One thing to note is that you need to attach the front left rigging wire and cabane strut before adding the exhaust. Struts and water tank are not attached and will be left loose until joining of the upper wing. Too many moving parts to be certain of alignment by adding the top center wing at this point. Lothar, Anthony in NZ and KiwiZac 3 Link to comment Share on other sites More sharing options...
Wolf Buddee Posted May 29, 2017 Share Posted May 29, 2017 Gorgeous progress Mike! What a beast of a plane eh? What are you using for rigging material? Cheers, Wolf Link to comment Share on other sites More sharing options...
seiran01 Posted May 29, 2017 Author Share Posted May 29, 2017 Thanks! Yup she's pretty big for a single engine bipe. Rigging is black EZ Line Link to comment Share on other sites More sharing options...
seiran01 Posted June 3, 2017 Author Share Posted June 3, 2017 Phew! Wings and ailerons are finally painted. Masking for preshade took a good two hours with 1mm masking tape and painting has taken probably 3.5 hours. Still needs a gloss coat before cockade decals. Side note - my phone autocorrected "gloss coat" to "blood coat," should I be worried that it has alternate intents for the finish on the plane? I used Mr Paint Clear Dope Linen Variant 2 (MRP-258) for the undersides to give some variation to the tamiya buff -painted center wing and tail surfaces. Top side remains Mr Paint PC-10 Late (MRP-253). The large top wing balances nicely on the unglued cabane struts! A good sign for when it comes to attach everything at the end. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
OldTroll Posted June 3, 2017 Share Posted June 3, 2017 Looks absolutely marvelous! I love the subtle weathering/pre-shading touches. Keep on keeping on, mate. Link to comment Share on other sites More sharing options...
Gazzas Posted June 3, 2017 Share Posted June 3, 2017 Wow! Love the way it looks and especially the the way the wood framing shows under the canvass. Link to comment Share on other sites More sharing options...
seiran01 Posted June 4, 2017 Author Share Posted June 4, 2017 Wing dry fit - alignment was trickier than the gotha! Leap of faith followed - fuselage rigging lines attached and top center wing glued in and weighted. And finally, top wing is glued and drying! I ended up using the kit-recommended "jig" of laying the plane in the box on front of wings to set the alignment. Worked perfectly. Tape on back of wings to help ensure rear struts remain tight as glue sets. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted June 5, 2017 Share Posted June 5, 2017 SUPER AWESOME! Wish it was mine! Link to comment Share on other sites More sharing options...
seiran01 Posted June 11, 2017 Author Share Posted June 11, 2017 8 hours work this weekend and all I have to show for it is completed/attached wheels, windscreens, bomb sight and gun ring. I know, the black bar is upside down on the gun ring but photos show the plane with no Lewis gun attached so I'm not fussed. Anthony in NZ 1 Link to comment Share on other sites More sharing options...
