seiran01 Posted May 6, 2017 Author Share Posted May 6, 2017 Finally, noteworthy progress! In between work travel and what not, I've been tackling seams, blending the upper fuselage to a prefect fit, rescribing, priming, and finally today, painting. First try with Mr. Paint for the PC-10 and I'm quite impressed with the quality. Engine, nose and top left cowl are now glued in place, also. Anthony in NZ, KiwiZac and tucohoward 3 Link to comment Share on other sites More sharing options...
OldTroll Posted May 6, 2017 Share Posted May 6, 2017 Lovely, Mike. Is that PC-10 a mix? Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 6, 2017 Share Posted May 6, 2017 MIke awesome progress. The engine detailing and weathering looks terrific and the fuselage now all buttoned up looks the part. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 6, 2017 Share Posted May 6, 2017 Ron Thanks for pointing out the MRP Paint in the photo. I've been using MRP paints and they are fantastic but I didn't realize they carried WWI colors. Will need to do some checking tonight Peter Link to comment Share on other sites More sharing options...
seiran01 Posted May 6, 2017 Author Share Posted May 6, 2017 Peter, they have a line of PC8/10/12, richtofen red, a few doped linens and wood tones, possibly a handful more at this point too. Ron - Mr Paint is airbrush only unfortunately, they're as thin as Alclad but spray beautifully. The pigment starts to separate quite quickly once shaken up in the bottle so you need to work somewhat quickly. Link to comment Share on other sites More sharing options...
seiran01 Posted May 6, 2017 Author Share Posted May 6, 2017 And thanks guys! Fuselage roundels and serials are on and drying; I've got Solvaset on the roundels to get them to settle over the raised nail heads. It seems my decal sheet is quite brittle and my normal technique of rolling on MicroSol with a Q-tip seemed to be cracking them. Link to comment Share on other sites More sharing options...
seiran01 Posted May 7, 2017 Author Share Posted May 7, 2017 Another first for me, something I should have been doing from the start! Guitar string reinforcement of control surfaces. #80 drill bit in my dremel now that I finally have a chuck for it. Remember to work slowly when doing this as the plastic can start to melt around the drill bit. Comes off easily but gives you a larger diameter hole than you may want. Anthony in NZ, Whitey and tucohoward 3 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted May 7, 2017 Share Posted May 7, 2017 MIke Thanks for the MRP paint info and I'll be order a the colors. Great idea about using guitar strings for reinforcing the control surfaces, especially the rudder. Even though the Roland is my first go at WNW kits again, I've knocked off the rudder and elevators now a few times. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
seiran01 Posted May 13, 2017 Author Share Posted May 13, 2017 Current state of the DH.9 - loving this thing right now! Control surfaces, gear/skid, and cabana struts are only pressed into position in the last photo. Whitey, Alburymodeler, Anthony in NZ and 2 others 5 Link to comment Share on other sites More sharing options...
LDSmodeller Posted May 13, 2017 Share Posted May 13, 2017 Hi Mike, Your build is coming along really well !! looking really nice Thanks for sharing with us Thanks/regards Alan Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 13, 2017 Share Posted May 13, 2017 Impressive work, Mike! Kev Link to comment Share on other sites More sharing options...
ZachP319 Posted May 13, 2017 Share Posted May 13, 2017 Looking great!! Always liked the DH9 Zach Link to comment Share on other sites More sharing options...
Anthony in NZ Posted May 14, 2017 Share Posted May 14, 2017 WOW..... Link to comment Share on other sites More sharing options...
seiran01 Posted May 16, 2017 Author Share Posted May 16, 2017 Prop done, minus a fix I need to make to cover up a little stray metallic on a recessed hole of the prop hub. I'm very proud of this thing, by far the nicest wood grain and prop I've done so far Whitey and Anthony in NZ 2 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted May 16, 2017 Share Posted May 16, 2017 That prop really does look stunning...wanna paint mine??LOL Link to comment Share on other sites More sharing options...
