geedubelyer Posted February 6, 2016 Share Posted February 6, 2016 Looking forward to seeing how you've been getting on Shoggz. Cheers. mpk 1 Link to comment Share on other sites More sharing options...
Shoggz Posted February 7, 2016 Author Share Posted February 7, 2016 A quick progress report. It feels like I've spent hours this weekend and not achieved a great deal! ..which is probably because I'm using resin add-on pieces for the first time and PE augmentation for the 2nd or 3rd time and I'm feeling my way carefully. Here's what the build looks like now As you can see, I am mixing the Barracuda cockpit upgrade pack with the Eduard PE set for the kit. I'm still not used to the 'brittleness' of the resin parts and have had to make three of four impromptu repairs with CA glue to various levers and protuberances etc. All a learning curve! I now need to paint all the details and get a bit more weathering done.. ..which will prompt another dilemma - dry-brush or wash.. (or both?) geedubelyer, Iain, MikeC and 1 other 4 Link to comment Share on other sites More sharing options...
mozart Posted February 7, 2016 Share Posted February 7, 2016 It's all coming along very nicely Shoggz, quite a learning curve you're on there.....enough to try your patience! Interesting to notice the subtle differences between the IPs: one that I can see is both the oil pressure and temperature gauges being outlined in red on one but the oil pressure being in yellow on the other, which is certainly the case on the Tiger Moths. Max mpk and Shoggz 2 Link to comment Share on other sites More sharing options...
Iain Posted February 10, 2016 Share Posted February 10, 2016 All looks really good - surprising sometimes just how long some of these things take - and always takes me a *lot* longer to do anything than I estimate beforehand... Look forward to seeing these come together! Iain Shoggz and mpk 2 Link to comment Share on other sites More sharing options...
Shoggz Posted February 13, 2016 Author Share Posted February 13, 2016 Progress continues - slowly as is my way! Building two aircraft simultaneously affords the opportunity to try different things on each one.. So.. the seats - I'm using the Barracdua resin seat for one and the CMK Master Kits for the other. The beauty of the latter is that it has seat belts nicely moulded on so I don't have to struggle with fabric or PE ones! I had a lot of fun painting the belts using Tamiya Deck Tan XF-55.. I'm definitely more of an artist than an engineer, so painting and finishing are things I think I'm better at than the actual building, but I digress! Here are both seats: I used Tamiya's matt earth XF-52 for both seats.. It's about the third different colour I've tried for Spitfire seats and I'm yet to find one that I'm 100% satisfied with.... For the black seat back I used Tamiya rubber black XF-85 and I'm really pleased with that! The rest of the cockpit components are pretty much finished too.. The cockpit sides need a bit more work on the weathering before the big moment of pulling the two halves together can occur. As I'm building one as a WWII machine and one as a restored modern warbird, I get to tackle both types of weathering - another interesting twist for a dual build mpk, geedubelyer and MikeC 3 Link to comment Share on other sites More sharing options...
mozart Posted February 13, 2016 Share Posted February 13, 2016 How are you keeping tabs on which part(s) belong to which kit Shoggz, I think I'd get confused!! Max geedubelyer and mpk 2 Link to comment Share on other sites More sharing options...
Shoggz Posted February 13, 2016 Author Share Posted February 13, 2016 That's a good question Max! Up till today I'd just been doing everything the same twice, but from now I'm going to be doing two builds more separately.. So I guess I'll have to physically separate everything into two 'piles'. I shall probably fail miserably.... mpk 1 Link to comment Share on other sites More sharing options...
geedubelyer Posted February 13, 2016 Share Posted February 13, 2016 Neat work Shoggz. You're making great progress. The colour of the seat can differ quite a bit in real life too so it should n't be a concern. I don't think I've seen a tan head rest pad before. Pretty much all of the ones I've seen are black so that's an interesting twist. Keep up the good work. They're coming together nicely. Cheers. mpk 1 Link to comment Share on other sites More sharing options...
Shoggz Posted February 23, 2016 Author Share Posted February 23, 2016 (edited) Managed to get a couple of hours in last night which included the big moment and one that I dread: Zipping up the fuselage halves! How come is it that no matter how many times I dry-fit and all is 'glove-like', when it comes to the crunch and that glue is applied it seems to morph into two halves of different aircraft! Anyway, with copious amounts of Tamiya tape I managed to get two complete airframes by the end of the evening. Next up: wings and tailplanes.. Edited February 23, 2016 by Shoggz MikeC, geedubelyer, mpk and 1 other 4 Link to comment Share on other sites More sharing options...
mozart Posted February 23, 2016 Share Posted February 23, 2016 You're not alone in pondering that question Shoggz, my fingers refuse to obey messages from my tired, confused brain as soon as I put glue on anything, weird isn't it? I'm sure all will be fine though, fingers crossed. Max mpk, Shawn M and Shoggz 3 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 24, 2016 Share Posted February 24, 2016 Good progress, mate. Looking forward to more! Kev mpk and Shoggz 2 Link to comment Share on other sites More sharing options...
Shoggz Posted February 24, 2016 Author Share Posted February 24, 2016 Thanks for your comments fellers! Managed to get the wings sorted last night and the test fit I did with the fuselage seemed relatively good... Of course, that's without glue - the real test will come when I apply the sticky stuff! Shawn M, MikeC and mpk 3 Link to comment Share on other sites More sharing options...
Shawn M Posted February 24, 2016 Share Posted February 24, 2016 so true...always seam that the perfect dry fit vanishes once the glue cap comes off dmthamade and mpk 2 Link to comment Share on other sites More sharing options...
Shoggz Posted February 24, 2016 Author Share Posted February 24, 2016 My pessimism was unfounded (for once.) The wings went on both really well - certainly in comparison to other Spitfires I've assembled. I've been working on cleaning up my AM wheels as the glue dries. One set from Eduard's Brassin range, and one from Barracuda. I'm liking both I have to say. They both knock spots off the kit versions which are a bit squiffy to be honest. So far this has been a fun build. geedubelyer, mpk, MikeC and 1 other 4 Link to comment Share on other sites More sharing options...
mozart Posted February 24, 2016 Share Posted February 24, 2016 Well done Shoggz, it's so much better when a build goes smoothly, I think modelling experience and anticipation of possible difficulties helps a lot as well. Looking very "ship shape and Bristol- fashion"! Max geedubelyer and Shoggz 2 Link to comment Share on other sites More sharing options...
