Gazzas Posted April 15, 2018 Share Posted April 15, 2018 Lovelee! Gaz Jan_G 1 Link to comment Share on other sites More sharing options...
Jan_G Posted May 8, 2018 Author Share Posted May 8, 2018 finally back at the bench floats ppainted with white aluminium and dural aluminium from MRP I have tried to depict dried sea water effect. Have masked with sponge Mr. maskol sol in some irregular patterns. After it has completly dried, I have sprayed thin coats of highly diluted medium grey paint. The effect is subtle and visible against the light thanks for looking jan Trak-Tor and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
Jan_G Posted May 8, 2018 Author Share Posted May 8, 2018 If I may, the two-color artificial horizon seems somewhat anachronistic for the era (not that much will be visible, or many will notice, though) I was thinking the same Hubert. I don't have enough references for this plane, but I have seen Yahu panel for Lublin and it looks almost the same. jan Hubert Boillot 1 Link to comment Share on other sites More sharing options...
Artur Posted May 9, 2018 Share Posted May 9, 2018 Lublin panel LSP_Kevin, TorbenD, Jan_G and 2 others 5 Link to comment Share on other sites More sharing options...
Jan_G Posted May 22, 2018 Author Share Posted May 22, 2018 slow progress with Lublin fuselage completed with all the details and ready for painting few shades added to highlight waterline and started to work on trolleys thanks for looking jan chukw, LSP_Kevin, Gazzas and 3 others 6 Link to comment Share on other sites More sharing options...
Jan_G Posted May 22, 2018 Author Share Posted May 22, 2018 Lublin panel Thanks a lot Artur for the pictures! jan Link to comment Share on other sites More sharing options...
Artur Posted May 24, 2018 Share Posted May 24, 2018 He gives the mix to obtain the correct color of Lublin Vallejo 70.990+ 70.942 2: 1. This is how it looks on the model of a colleague. Gazzas, Hubert Boillot, TorbenD and 3 others 6 Link to comment Share on other sites More sharing options...
Jan_G Posted June 5, 2018 Author Share Posted June 5, 2018 He gives the mix to obtain the correct color of Lublin Vallejo 70.990+ 70.942 2: 1. This is how it looks on the model of a colleague. Thanks Artur for the color recommendation. Unfortunately Im not using Vallejo stuff but will try to achieve similar mixture from Tamiya Park Green An that finished Lublin is great work. I saw the photos of it on Lukgraph site jan Link to comment Share on other sites More sharing options...
Jan_G Posted June 5, 2018 Author Share Posted June 5, 2018 small progress with Lublin I was playing with floats struts. It's small challene, typical for resin kits to get them aligned with correct geometry. I have used stainless steel tubes instead of resin ones for 2 struts between both floats, easy and strong solution struts painted with MRP Super Silver thanks for looking jan chukw, LSP_Kevin, Hubert Boillot and 2 others 5 Link to comment Share on other sites More sharing options...
Trak-Tor Posted June 6, 2018 Share Posted June 6, 2018 Wow!Some great looking floats there! Juraj Jan_G 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted June 6, 2018 Share Posted June 6, 2018 Jan Outstanding work and your progress is amazing. Keep'em comin Peter Link to comment Share on other sites More sharing options...
ssculptor Posted June 6, 2018 Share Posted June 6, 2018 A float plane. Wonderful. Jan_G 1 Link to comment Share on other sites More sharing options...
Jan_G Posted June 21, 2018 Author Share Posted June 21, 2018 not so much time at the bench in past days, however I was able to finish basic paint job Cowling painted with the mixture of Mr. Paint light grey and White aluminium, shaded and lighted a little bit underside of the wing and fuselage painted with MRP Super silver and shaded It was tricky to get the right green mixture. I was trying to mix Tamiya X-28 and Hobby Colour H306 (thinned with Tamiya X-20) and my first attempt resulted in this (with some shading applied) However I was not happy with the bright green look. So I sand it down applied white surfacer and used more greyish mixture of the colors mentioned above. This time I have thinned the paints with Mr. Color Levelling thinner to get better surface. Now Im satisfied with the final look Thanks for looking jan Trak-Tor, TorbenD, LSP_Kevin and 3 others 6 Link to comment Share on other sites More sharing options...
Jan_G Posted June 21, 2018 Author Share Posted June 21, 2018 Gorgeous work as normal! It looks like a nice straightforward build. Thanks Ernie! so far its quite straightforward, only all the struts alignment will keep you busy. jan Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 21, 2018 Share Posted June 21, 2018 Terrific work, Jan! Kev Jan_G 1 Link to comment Share on other sites More sharing options...
