Hardcore Posted February 19, 2023 Share Posted February 19, 2023 This was claimed in a post commenting a review. I don't know if that is true, but if it is then it will help buying thinners more cheaply, and availability. etc. Btw, is the polyurethane mix smelly? Link to comment Share on other sites More sharing options...
denders Posted February 19, 2023 Share Posted February 19, 2023 I don't know for sure whether they're rebranded of just manufactured by Createx to MM specifications. I had some problems with some of the MM paints sort of curdling when I added MM thinner from one of the bottles that I had. I've used Createx 4011 to thin my MM paints and had no problems since. And no, the Polyurethane isn't 'smelly'. You're only using 1 or 2 drops per 10 drops of paint. Make sure to follow the instructions and keep it out of sunlight and if you have more than one bottle, keep it in the fridge. I have a bottle hidden in a corner of my paint booth that I've had for probably 3 1/2 years now and it still is okay. Hardcore 1 Link to comment Share on other sites More sharing options...
Dave Williams Posted February 19, 2023 Share Posted February 19, 2023 I’m not sure how true it is, but the poly intermix is the same as the Createx Reducer. Looks the same in bottle and the ingredients on the label are exactly the same as on the MMP poly mix. It doesn’t smell. Hardcore 1 Link to comment Share on other sites More sharing options...
Hardcore Posted February 20, 2023 Author Share Posted February 20, 2023 Great! Link to comment Share on other sites More sharing options...
Hardcore Posted February 20, 2023 Author Share Posted February 20, 2023 4 hours ago, denders said: I don't know for sure whether they're rebranded of just manufactured by Createx to MM specifications. I had some problems with some of the MM paints sort of curdling when I added MM thinner from one of the bottles that I had. I've used Createx 4011 to thin my MM paints and had no problems since. And no, the Polyurethane isn't 'smelly'. You're only using 1 or 2 drops per 10 drops of paint. Make sure to follow the instructions and keep it out of sunlight and if you have more than one bottle, keep it in the fridge. I have a bottle hidden in a corner of my paint booth that I've had for probably 3 1/2 years now and it still is okay. Thank you! Also would you say MMP Polyurethane Intermix and Createx 4030 Balancing Clear are the same thing? Link to comment Share on other sites More sharing options...
Woody V Posted February 20, 2023 Share Posted February 20, 2023 (edited) I tried MM as my last ditch effort to find a water based paint that didn't hate me. Among my more "interesting" experiences are: 1. Certain colors remained water soluble after drying for days. I used a wet cotton bud and the paint wiped right off. 2. The black formed crystals in my paint cup that completely clogged my airbrush. 3. When I sent the paint and the mixing cup with crystals to MM, I was told there was nothing wrong with the paint and it's my fault. I dumped the whole lot on Ebay to some poor unsuspecting soul, switched to Gunze Mr. Color lacquer and could not be happier. My advice to anyone interested in MM paints is: Edited February 20, 2023 by Woody V Greif8, themongoose, Fanes and 1 other 4 Link to comment Share on other sites More sharing options...
denders Posted February 20, 2023 Share Posted February 20, 2023 (edited) 11 hours ago, Hardcore said: Thank you! Also would you say MMP Polyurethane Intermix and Createx 4030 Balancing Clear are the same thing? I have not used 4030, so I can't comment. EDIT: Perhaps the next time I'm at Hobby Lobby I'll see if they have 4030 and check it out. Edited February 20, 2023 by denders Link to comment Share on other sites More sharing options...
D.B. Andrus Posted February 20, 2023 Share Posted February 20, 2023 In MM's favor they brush very well for cockpit detail work. Haven't tried spraying. Cheers, Damian Link to comment Share on other sites More sharing options...
denders Posted February 20, 2023 Share Posted February 20, 2023 Woody, I've no idea why you got the sort of response that you received. I still think it's a thinner chemistry problem. I've found that if I use Createx 4011 to thin the paints, it works okay. So, I think I had a bad container of thinner. I have another bottle of thinner from the same time period that I haven't opened. I guess I should mix a little and see how it works. I usually mix the paints in a 1 oz mixing cup and I can see if there are problems before I put it in the airbrush. Quite a few years ago, I had a similar reaction while mixing Testor's Acryl paints. I found their website and sent an email about it. I received a very prompt replay telling me that it was a bad batch of thinner and they thought they had gotten all of that thinner batch. I was asked how much thinner I had on hand and for my mailing address. I then promptly received replacement thinner. Link to comment Share on other sites More sharing options...
Woody V Posted February 20, 2023 Share Posted February 20, 2023 1 hour ago, denders said: I still think it's a thinner chemistry problem Exactly! I just want to paint my model, not engage in a chemistry project. If it wasn't for the fumes lacquer paints would be perfect. But that's just my opinion. Link to comment Share on other sites More sharing options...
Dave Williams Posted February 20, 2023 Share Posted February 20, 2023 13 hours ago, Hardcore said: Thank you! Also would you say MMP Polyurethane Intermix and Createx 4030 Balancing Clear are the same thing? Looking at my bottles, 4030 Balancing Clear is what I have. Looks the same as the MMP poly intermix, and lists the same ingredients in the same order on the label. I’ve never tried alternate thinners to the MMP own thinner. I guess the Createx thinners for their paints are 4011 and 4012? But don’t know the difference. Link to comment Share on other sites More sharing options...
Hardcore Posted February 20, 2023 Author Share Posted February 20, 2023 3 hours ago, Dave Williams said: Looking at my bottles, 4030 Balancing Clear is what I have. Looks the same as the MMP poly intermix, and lists the same ingredients in the same order on the label. I’ve never tried alternate thinners to the MMP own thinner. I guess the Createx thinners for their paints are 4011 and 4012? But don’t know the difference. Then I know what to try. Thanks! Link to comment Share on other sites More sharing options...
Greif8 Posted February 21, 2023 Share Posted February 21, 2023 I had very similar experience to Woody's when I contacted the owner of Mission Models (MM) about two seperate bottles of the Poly mix that has hardened. I was told that I was storing it wrong and needed to pay better attention to the instructions about using MM products. I was also told that I should store the poly mix in the refridgerator. For what it is worth, all my paints, thinners, etc., are stored in drawers in a climate controlled room, and the MM poly mix is the only item ever to go bad - twice. I decided after that exchange that I would move on and got rid of a lot of the MM products I owned. That was a bit sad as I had pretty much mastered the thinning ratios and was airbrushing the paint very well; but I can do without being indirectly told I'm an idiot when I bring up a legitimate issue. Keeping painting items in the fridge so that they don't go bad is also a bit rich IMHO. I still have several bottles of thinner, primer, Luftwaffe and USN colors, as well as a few other colors. Maybe I'll use it to paint the next several builds of those two air force type aircraft to use up the remaining stock, though that would be a lot of builds. Ernest Woody V 1 Link to comment Share on other sites More sharing options...
