CANicoll Posted February 6, 2017 Author Share Posted February 6, 2017 Yep, same angle, slanting from right, down and left. Since your ailerons will be red on top, streaking them is of course, irrelevant. One thing though, there was always a thin strip of the bottom turquoise, that lapped over and onto the fuselage sides. That thin strip of turquoise would have got me. Thanks for the heads up! I was literally days away from making that mistake. So is the bottom turquoise or light blue? (or is there a difference? LOL) LSP_K2 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 6, 2017 Share Posted February 6, 2017 That thin strip of turquoise would have got me. Thanks for the heads up! I was literally days away from making that mistake. So is the bottom turquoise or light blue? (or is there a difference? LOL) It's generally referred to as turquoise, and I really see that as a light greenish blue. I'll see if I can dig up a good photo of the typical blue/turquoise overlap. Of course the aft area that's red, will have no such overlap, being over-painted as it was. CANicoll 1 Link to comment Share on other sites More sharing options...
petrov27 Posted February 6, 2017 Share Posted February 6, 2017 yeah - I have always understood it as a turquoise A suggested match I heard in the past was RLM 78 but not tried it myself CANicoll 1 Link to comment Share on other sites More sharing options...
CANicoll Posted February 7, 2017 Author Share Posted February 7, 2017 Thanks Kevin and Patrick a- appreciate the help very much. Chris Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 7, 2017 Share Posted February 7, 2017 Here's a pretty decent shot of the overlap (404/17). It's about 1" wide, would be my best guess. Scan from this Albatros Productions book. I'll look and see what blue I used on mine and get back to you. MikeMaben and CANicoll 2 Link to comment Share on other sites More sharing options...
CANicoll Posted February 7, 2017 Author Share Posted February 7, 2017 So here is my first shot at blending the camo pattern. A few takeaways: 1. I'm using water colors and they are drying too quickly. 2. The water colors also blend too quickly as well I think. 3.The burnt umber is not blending on the aircraft to darken the green. But the white blends pretty well. A few others, but here are the pics... But it all does wipe away quite nicely! So the Mustang above is my paint mule. Same base and gloss coat as on the Fokker. Here I lay out the lines with the #2 thin brush: And blended using the fan brush (maybe not the best choice): First try, so wiped that off and tried again: And third try: Clearly a little Burnt Umber goes a LONG way!! and another try: Which is looking a bit more promising, I do admit, but not there yet But trending in the right direction, as they say... Ok, so lesson's learned, part 2: I think mixing the paint on the plane is a non-starter for water colors. Better to mix three colors on the palette, apply, then blend on the plane as appropriate. Will try that probably tomorrow. Oils probably work a lot better than the water colors (but can't find the fast drying ones so have to mail order ugh). A narrower brush to blend may help too. The good news is that trial and error is very easy. Water wash-up so wiping off and trying again is a piece of cake. More tomorrow! Chris MikeC 1 Link to comment Share on other sites More sharing options...
CANicoll Posted February 7, 2017 Author Share Posted February 7, 2017 Here's a pretty decent shot of the overlap (404/17). It's about 1" wide, would be my best guess. Scan from this Albatros Productions book. I'll look and see what blue I used on mine and get back to you. Actually looking at these pics, the wing streaks are parallel to the fuselage, but on mine I'll be streaking at an angle. CN Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 7, 2017 Share Posted February 7, 2017 SOk, so lesson's learned, part 2: I think mixing the paint on the plane is a non-starter for water colors. Better to mix three colors on the palette, apply, then blend on the plane as appropriate. Will try that probably tomorrow. Chris Why three different colors? Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 7, 2017 Share Posted February 7, 2017 Actually looking at these pics, the wing streaks are parallel to the fuselage, but on mine I'll be streaking at an angle. CN Yes, fuselage sides had the streaking running perpendicular to the aircraft centerline, always. It goes roughly like this; all three wings, streaking at 15°-30°, ailerons, fuselage spine and horizontal tail surfaces at roughly 45°, fuselage sides perpendicular to aircraft centerline. Shawn M and CANicoll 2 Link to comment Share on other sites More sharing options...
CANicoll Posted February 7, 2017 Author Share Posted February 7, 2017 Why three different colors? I was thinking dark olive, olive and light olive.... Maybe just olive and dark will do it over a light base? Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 7, 2017 Share Posted February 7, 2017 Here's a photo that better illustrates what's what. This particular photo is also handy, in that it depicts the typical horizontal tail and elevator overlap of the turquoise. On your particular scheme, this doesn't really matter, and in fact tail surfaces were routinely over-painted, but just thrown in for informational purposes. MikeC and CANicoll 2 Link to comment Share on other sites More sharing options...
CANicoll Posted February 7, 2017 Author Share Posted February 7, 2017 Kevin, Thanks - this actually gives me an idea for tomorrow to try. Stay tuned, and I really do appreciate your help and suggestions! Chris Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 7, 2017 Share Posted February 7, 2017 I was thinking dark olive, olive and light olive.... Maybe just olive and dark will do it over a light base? More or less standard procedure, is to use one color, and paint until the brush is almost dry, then repeat, just like they painted (doped) the real aircraft. CANicoll 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted February 7, 2017 Share Posted February 7, 2017 I checked my thread(s) on the Dr.I, and don't see any mention of what blue I'd used for the bottom. Link to comment Share on other sites More sharing options...
CANicoll Posted February 7, 2017 Author Share Posted February 7, 2017 Kevin, thanks a million, again! Will be giving it a go again tonight so this should be good. Link to comment Share on other sites More sharing options...
