Shaka HI Posted July 28, 2016 Share Posted July 28, 2016 OK - after a loooong delay - and given that a few other projects are being spat out of the model bench hangar - I'm on the Sea Hornet (and Hornet!). Been prepping the fuselages on both kits - and working out a plan of attack - to include some subtle correction work to the nose area and wing inner sections - amongst others. Photos at the weekend - or it didn't happen, right? Iain I have heard this before.... Link to comment Share on other sites More sharing options...
Iain Posted July 29, 2016 Author Share Posted July 29, 2016 Things I have discovered #1 - now the fuselages have been prepped it appears that HpH have corrected the front screen/upper nose positioning on the Sea Hornet - as positioning the Hornet and Sea Hornet halves together with each other, that on the Hornet is higher. This means this is one area I won't have to address on the Sea Hornet. Iain Out2gtcha and mikeblack 2 Link to comment Share on other sites More sharing options...
Iain Posted July 30, 2016 Author Share Posted July 30, 2016 OK - some photos of where we're at - this will be a slow build as I have other projects in parallel - but aim to get something done each week. Won't be as detailed as Peter's amazing build - but will be making some corrections. Moulding stubbs/flashed over areas removed and the mating surfaces prepped like a vacform - dressed off on a sheet of flat wet and dry: Comparison with the single-seat Hornet fuselage - you can see that the area below the windshield is lower compared to the same area on the single-seater: And the two Sea Hornet fuselage halves offered up: Now - do I run a separate thread for the Hornet, which is being built in parallel, or include here? Iain dutik, Azgaron, TorbenD and 3 others 6 Link to comment Share on other sites More sharing options...
Shaka HI Posted July 30, 2016 Share Posted July 30, 2016 I say separate them. Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 31, 2016 Share Posted July 31, 2016 I say separate them. Yep, separate! Kev Link to comment Share on other sites More sharing options...
Hubert Boillot Posted July 31, 2016 Share Posted July 31, 2016 Good to see HPH apparently took-on the accuracy remarks on the first kit, and reworked the front for the Sea Hornet. It's got to be a British idiosyncrasy to take a beautiful airframe and graft it some appendages that turn it into an ugly duckling Good work on this one. Will follow with interest Hubert Iain 1 Link to comment Share on other sites More sharing options...
antonlemmy@yahoo.com Posted November 24, 2018 Share Posted November 24, 2018 Definitely going to be following along on this one. I was lucky enough to get this kit plus the HpH Tigercat too. I think the Sea Hornet will be cracked first though as it will only be my second all-resin kit. Link to comment Share on other sites More sharing options...
