Revell 1/32 Mirage IIIRS
Supermario
Great start! Looking good........
I also have this original boxed kit at home and am planning on doing the Swiss Mirage IIIR foiled in natural metal and will be using the fisher cockpit as well...
Man, I picked up that Matterhorn Circle Atar 9C resin engine kit too, and WOOOOHOOO! Man is that this sweeet!
Good luck and keep the pics comin!
Cheers,
Brian
:clap2:
Oups! I did not expect that much replies in one night !
Thank you all a lot for your kind words !!!
Is that a new Revell Germany release?
In fact it was a limited edition (as several others) from Revell's Swiss distibutor. Just the old box wraped in new printed paper, as avro683 said, with a "little goodie".
This make me think I build once the "Papyrus Hunter" from the same distribution. I shoud post some pics once...
C'était il ya longtemps, bon de vous voir créer à nouveau!
Vous avez les doigts magiques, tout a l'air très bon!
Joyeux Noël et bonne année à vous souhaitez
lars henry
Very good start on a thread I just know I must follow!
Hi Lars !
Whow ! and in french !
I will not start with my poor swedisch even more as I learned it form a girlfriend… the few I know is some how only "+18"... :m0152:
Thanks!
Great start and I love the pit, just one question the resin I understand but etched Bras? I don't think the wife has any of those! :)
Bwahhh! I did not notice that ! … Luckily they don't wear such things !
(...) Good luck (...) !
Cheers,
Brian
It looks like I will need some... those who have the kit know what I'm talking about hi hi hi :lol:
And just about Fischer's cockpit, I think it is the only cure !!! The kit's parts are hopeless IMO. There would would be no hesitation if mine wasn't nearly ready !
Thank you guys !
Yes, I know it has been a long time, but an absolut lack of motivation. I really don't know why there was just no will to modelling...
plus a lot of work, a lot of mountainbike training and it's already the end of the year. . .
Hey Manu ! glad to read you again too !!! :)
Salut Roland...
Enfin un Mirage en construction!!!
Je suis un fanatique du Mirage...kits, livres..etc.
J'ai plusieurs kit 1/48..1/32 di Mirage III et F et des conversion Kfir, Cheetah, Nesher, je vais suivre attentivement l'evolution de construction de ton Mirage!
Joyeux Noel...
Keep on the good work!
A mirage fanatic!!!! :)
Hi ! and Thank you ! :)
A small update
As my cockpit "thing" is making illusion, I placed the side panels and some tabs to hold it
Then I had to extend 8mm the front wheel well opening (an other specification of the swiss Mirages) and build a “wheel well thing” to the right dimentions.
The other side of this “thing”
I just build roughly the main components to make sure about sizes and arrangement, and to see if I was going the right way...
The front leg was a bit tricky to achieve as the one furnished in the kit is really bad. A lot too flimsy, the “fork” (don’t know the right name in english) holding the wheel must be extended anyway (again to match the Swiss execution) and the wheel has to be much more beefy.
So I keep only the top of the leg and quickly rebuild the rest with the correct specs.
A piano wire is running down to the “wheel fork” (sorry again...) all the way through the leg, it keeps (more or less) the alignement and strenght, so even without glue it did not collapse when putting weight on it...
that's it for the moment...
... and still so much more to throw inside ! :BANGHEAD2:
PS @ sukhoï : tu m’a l’air drôlement infecté par les mirages, dis ...?!! :whistle:
Hi Roland..
You can say that again...
http://www.clubhyper.com/reference/mirageiiisrm_1.htm
http://www.clubhyper.com/reference/swissmirageiiirm_2.htm
Thoses are an articles that I putted on Hyperscale...on the swiss Mirage..
Les Mirages Suisses...sont les ..'plus américanisé ' des Mirages!
Je travaille actuellement sur plusieurs kit...dont un Mirage Kfir CE Colombien...au 1/32.
Salutation...
Good work on that Mirage!!
Ah! It was you Sukhoï !!! :bow:
I see it is not the first time you look at a Swiss Mirage !
I hope you will not be angry with me (or help me) if I commit some imperfections... :speak_cool:
Did you carve those nose wheel parts yourself? If so, could you explain in more detail?
Kev
I hope I understand your question right.
In fact me too, I didn’t knew how to start too... I drive myself in front of the wall, took the big hobby knife and removed all the portions I found not to be correct.
When it’s done, you HAVE to find a solution! :party0023:
For the LG I took rectangular Evergreen and bend it to match (the black lines). Then these parts were assembled with two sections of half round profile (the blue) before filling the holes with cyano and microbaloon. The ends of the parts have been shaped by sanding and the edges shaped with the hobby knive.
The other part is only a round profile, plasticard and a small aluminium tube.
The wheel is made with the two kit parts and plasticard.
Regarding the hydraulic pistions, they are made from piano wire, aluminium tube and adhesive foil.
They are very easy to achive, believe me. I’ll will take some step by step pictures when I have to build some more.
The base of the other parts are from the spare box (german bombs, Haseg’ P51 engine and so on )
Thanks guys !
Jerry, wait ‘till I’ll made some mess with that one too, I know far enough what I’m able to commit...! :speak_cool: :lol:
To the fuselage dress :
air intakes were trimmed to the right shape (half round and not a potato look). The the front lip was replaced with thin plasticard as was the back side, so we have something more scale acurate. As I was on the way, the tip of the intake was carved to the sharp point it should to be.
‘rebuild the structure of the secondary intake
Ooups... (not Tamigawa...)
The canon fairings are hopeless, so I build new ones with half round profiles
Now, ‘have to make this stuff look good... :thumbsup:
