LDSmodeller Posted February 26, 2008 Share Posted February 26, 2008 Hi Perry From the drawings/profiles I have, the windows are both sides. As to what they actually allow the pilot to see ... well I don't know! The cockpit floor slopes away just aft of the rudder bars and the windows are located at the end of the sloping floor. Hope that helps Regards Alan Link to comment Share on other sites More sharing options...
perry Posted February 26, 2008 Author Share Posted February 26, 2008 Thanks Alan, I'll study my photos when i get home from work. P Link to comment Share on other sites More sharing options...
MikeMaben Posted February 26, 2008 Share Posted February 26, 2008 Mike. There's no aversion to commitment. Just that with a vac, one has to think more and plan the build and the stages of each assembly. Sorry, I meant just me. M M ...it's as good an excuse as any Link to comment Share on other sites More sharing options...
Erwin Posted February 27, 2008 Share Posted February 27, 2008 Which kit's prop will you use for this VAC. I recall you had a hard time finding one for the Gladiator. Link to comment Share on other sites More sharing options...
perry Posted February 28, 2008 Author Share Posted February 28, 2008 Hiya everyone. It was poiyned out to me that the interior was the wrong colour. Lower regions weren't green. I've been in contact with my mate Edgar and he has explained this and why. The red dope hand painted on the outside seaped through the linen causing a pinky/reddish brown streaky look to the inside. So, trying to correct this, I've painted the lower regions in humbrol linen and used a wash over it. Also made the rear bulkhead and strengthened it with offcuts of the vac carrier. This will also help when I eventually come to closing the f/large up and strengthen the joint between the 2 halves. The forward firing gun is in place, barrel drilled out and ready to be detailed. The engine is built, spark plug leads added to it and all painted, just a few more details to be added to it now. Okeydokey, next job is to begin building the tubular frame in the cockpit areas Erwin. Not sure yet mate, haven't thought about it yet. I'll overcome that problem when I get to it Link to comment Share on other sites More sharing options...
perry Posted March 31, 2008 Author Share Posted March 31, 2008 Hi guys! Work on the Swordfish has been very slow because of the lack of time on my hands. But, I have managed to do a little more and took these pics to show what I've been up to before I joined the f/large together. There are still a few details to add but they can be done after the f/l is joined up. The Vickers gun and mount are made but aren't attached and won't be till it's finished. Link to comment Share on other sites More sharing options...
perry Posted March 31, 2008 Author Share Posted March 31, 2008 Only problem I found was the left section of f/l was about 4 mm longer than the right I joined the f/l up so that the cockpit areas were aligned but this left a couple of mm each end. I cut out the rudder halves, sanded them down and glued them together. Then I sanded the horizontal stabilzer back till the rudder fitted and glued it in place. The couple of spare mm at the front, I dealt with by careful trimming sanding and filling. It will be hidden under the engine cowling. Managed to trim, fill and sand the left side of the f/l to a decent fit, all seams filled and sanded back.. The Pegasus is now in place. Here's the latest pic, hope you approve, all comments welcome as usual. Thanks for looking in Pez Link to comment Share on other sites More sharing options...
perry Posted March 31, 2008 Author Share Posted March 31, 2008 couple more... Link to comment Share on other sites More sharing options...
perry Posted March 31, 2008 Author Share Posted March 31, 2008 and a blurred one of the Vickers gun and mount (sorry about the quality!) Link to comment Share on other sites More sharing options...
maverick728470 Posted March 31, 2008 Share Posted March 31, 2008 Perry, For someone who has started his second vac and with the detailing u'er doing.U can call u'erself a vac master.And for this question to u.And i know it maybe awhile before u'er next one vac wise.What would be the next one for u to build.Larry Link to comment Share on other sites More sharing options...
perry Posted March 31, 2008 Author Share Posted March 31, 2008 Thanks Larry! But I wouldn't call myself that just yet, I have so much to learn. I would say you are a Vac Master, I am a humble Vac Apprentice ! As for your question, I will build the 1/32 vac Whirlwind next. Cheers P Link to comment Share on other sites More sharing options...
Texas Posted March 31, 2008 Share Posted March 31, 2008 HI Great job yoour doing on that old bird. Looking Good Texas Link to comment Share on other sites More sharing options...
Derek B Posted March 31, 2008 Share Posted March 31, 2008 Perry, So you decided to go for the Swordfish in the end? - Good man (looking very good so far). As long as you are enjoying the build, then all is well. It's nice to see a large scale vacform build in progress. Derek Link to comment Share on other sites More sharing options...
Azgaron Posted April 1, 2008 Share Posted April 1, 2008 Very nice work so far, Pez! Cheers, Azgaron Link to comment Share on other sites More sharing options...
perry Posted April 3, 2008 Author Share Posted April 3, 2008 Thanks everyone for all the positive comments. Dan; the Vickers gun was donated to me from a trashed Lysander. I drilled out the grip area, drilled out the barrel, used stretched sprue for the bead and ring and added a thin strip of photo etch carrier to the top of the drum. For the mount, I used plasti card for the base. I used an office hole punch to make the round wheels on the sides and then lengths of thin wire and tin shaped and soldered for the actual mount. Link to comment Share on other sites More sharing options...
