16 -
Posts posted by rosariovw
The last 3 days i did the dryfitting, and modding it all for the Zactoman intakes. Its not an easy task, resin wheelbays, resin ecs vents, and the intakes are not intended to be used together.
I thinned the vents side, and made a thin cut in the air bleed compartiment.
On the wheel bay side, and on the air bleed compartiment i had to remove some extra resin, so the compartiment rests on the angled wheel bay part.
Also, i added some strips to make sure the compartiments get on the correct position, and added a cover on the bottom of the vents.
painted the intakes
just an example
yesterdag, i ordered the the Tomato decals (not that i have enough decal sets) but the gilfriend says, it was the best eyepopping bird.
Also, this weekend i won't build much, cause i'm compating in a contest with 1/48 this weekend. Even just invested in the hobby again, and bought just a whopping 300$ worth of building materials.
i'm still in doubt, ATM, i'm thinking for the TOMATO, or Vandy 1
thanks for the support, got some done today.
Started with the HUD, i tried to use some prismatic paint (alclad) but when i spray it, it gets white/flat. So, i used a brush, it worked great on the HUD lens.
i tried it on the glass, and fucked it up, so made new ones.
and sculpted a new wingbladder
- TorbenD, Shawn M, Durangokid and 5 others
- 8
did some work today, (not that much, cause lost my job today) to keep the mind clear.
Added detail to the ventral fin, one done, 1 to go.
And every time, adding panels to the forward fuselage, and let me tell ya, fitting sucks.
On most places i need to add spacers, or the gaps are huge.
Did some windscreen details
And the ECS vents
And re-shaped the ventral fins, and added depth on the NACA vent.
The fins are too thick, so its sanding like hell. Atm i'm thinking casting them in resin, so i have them for future builds.
But they are still in progress.
- johncrow, Squizzy 78, LSP_Kevin and 1 other
- 4
2 hours ago, A-10LOADER said:
Great work so far on everything, looks really good. You need to add the Programmable Tactical Information Display (PTID) control stick to the RIO's left side console.
Steve
"TOMCATS FOREVER, BABY...!"
Yup, i know, but i wait till all the rest is done, cause of i want to put foam in the cockpit for protection there is a chance it gets snagged and lost.
8 hours ago, Squizzy said:
I have pretty much the same bag of resin in the stash for a similar build, I'll enjoy watching this!
Do you have any after market decals in mind?
Well, i think Vandy one, but have 2 VF-101 sets , VF-11 set, and a vf-2 set. At this moment i can still go for a late B model or a D, i have some 6sets for B, so, i think it would be difficult to decide now. more progress pics from the wing.
- LSP_Kevin, Out2gtcha, A-10LOADER and 2 others
- 5
Some progress yesterday, some more scratch building, and modding.
- blackbetty, LSP_Kevin and A-10LOADER
- 3
After some years of small projects, and no inspiration, i found it back.
Last week i started with my 4the F-14 in 1/32. Basicly, it will have most of the available extra's.
-eduard F-14d exteriour set
- eduard F-14d undercarriage
- eduard F-14 set for tamiya
- Aires cockpit set
- Aires wheel bays
- Aires exhaust
- Zactoman intakes
- Ben schumacher's ECS vents
I try to keep this thread going and put as much pics on, if i'm not going to fast.
At this moment the cockpit is done.
and the wheelbays are painted.
I started working at the Wings
All the wrong rivets on the forward fuselage are removed/filled.
At the rear, i filled the wrong rivets, added the actuator cooling vents, andraised the area a little bit with MrSurfacer
1/32 trumpeter F-14D
in Works in Progress
hm, strange this, most of the photobucket pics are gone. Did some more work. Its a bit less productive but i try to do some minor stuff each day. Now at the hobby room its 32°c.
First, exhausts done, did it in 2 tries, but, resin and thinner, works great t get rid of the feiled paint attempt. I softened the details in the burner cans. As most know, there is a little detail on the real feathers, and i find the aires details to hard. Now i'm sure that the sanding gives a good grip for the paint. Sprayed with Mr Surfacer Black, Let dry overnight, and then did some Alclad gloss black over it. Made my own maskings for the black part of the exhaust petals, after one night i maksed them all . Pale burnt metal went over it. I let it dry for a couple of hours, and the Gloss clear over it.
The tube, inserts and fan sprayed with mr surfacer black, overnight drying and then gloss clear, i drybrushed with white, and silver. Some white wash, here the results.
The shrouds are painted with my own blend, some claer gloss, and they look great
The rest of the engine covers are fitted, some sanding, removing the support on the inside helped alot.All is flush now. For the fuselage, and boddy, next is filling and sanding.
Did the horizontal stabilizers, glued them, filled the panel lines, and then masking. Like on some aircraft, there are panel lines, and later moddels have all the lines filled. So, i wanted to get that look. There is the result, after the masking, some layers surfacer, removed the tape, and then the black primer on.
