9,641 -
Days Won
131
Everything posted by Iain
Order placed - to go with all my other as yet un-built Kotare spits... 🫣 Iain
Happy Birthday Martin! Iain
Lockheed Super Constellation 1049 H - Airfix (Heller) 1/72
Iain replied to Rob K.'s topic in Non-LSP Works
Very nice Rob! Who doesn't like a Connie?! Iain (just over the border in West Oxfordshire) -
Sad news - a really lovely man and a stalwart of the hobby! Heartfelt condolences to your family and all of his friends. Regards, Iain
Impromptu visit to Shuttleworth today.
Iain replied to Shoggz's topic in Aviation Discussion & Research
It's always a fabulous place to visit - looks like a good time was had! Iain -
Boulton Paul Defiant Mk 1 Night-Fighter - 410 Sqn RCAF
Iain replied to Iain's topic in Works in Progress
Thanks Andy - I think you'll enjoy building it... 🙂 BTW - there is absolutely no surface prep under that grey-green - just a little work with a file to clean up print support attachment points. The print resolution really is that good! Iain -
Continuing the 'dry fit' theme - it would be rude to not slot the tailplane in place - that's how good the fit is! I've also reshaped the cross section of the rear fuselage a little so it's a bit flatter on the upper quarters on either side of the opening for the turret fairing: And try out the wings, rudder, rear decking and cockpit canopy - again - all dry fitted! Note that I've also modded the 'ears' on either side of the cowling part - they are now recessed, rather than proud of the surface: Really looking forward to getting the cockpit interior all painted up and assembled - it's going to look quite something... Iain -
Apologies for delay - but a little more progress. Base Interior Grey/Green - in this case MRP. Detail painting and weathering to follow - but the base coat shows up the superb detail... Dry assembled: With a tiny bit of trimming in places, the fit to the fuselage halves is superb! Main panel back and boxes sprayed black - and dry fitted: And the two halves closed up - again - just a dry fit at this stage. I've also softened the transition from the base of the canopy to the fuselage sides with a little Milliput - need to add some detail back. Absolutely loving this kit - the detail and fit of parts is fantastic - and hugely rewarding to work with. Iain -
My journey into the world of 3D-printing as a total novice
Iain replied to Grunticus's topic in 3D Printing
I'll second Dave on this - I've had exactly the same happen to me... Iain -
Looking absolutely fabulous Peter!! Iain
Fab choice - I have one here and it looks like a fabulous kit - so looking forward to seeing what you make of it! Iain
That's absolutely beautiful work Ani - very well done - something to be very proud of! Thank you for sharing 👍. Iain
It's live - try this link: https://www.airscaleprokits.co.uk/#!/1-32-Boulton-Paul-Defiant-Mk-1-Full-Kit/p/734529231 Iain
Welcome aboard! Iain
Happy Birthday Paul! Iain
Looking good John! Iain
Beautifully done! Iain
Quick update - I'll try and do some more over the weekend, but I have a list of non-modelling jobs I need to catch up on. This is a test fit into the centre fuselage sections - again, no glue has been used at all on any of the parts so far... Into starboard side: And it's straight in! There will be some finessing needed to get everything 'home' - as you'll see further down this post. Can't quite get the two halves together - some fettling will be needed to get everything together snugly - but that's not unexpected at this stage, and shoulkd be straightforward. Blue skies, Iain -
Thanks guys - much appreciated... Had to spend the day working with the day job - but did manage to get some Defiant done. Iain
Looks like a gorgeous kit - and agreed on the box art - superb! Iain
And some dry fitting of cockpit components - these are straight off the supports and with no fettling at all at this stage: 5 components in that assembly... Iain -
Tamiya 1/32 De Havilland Mosquito, "Operation Jericho"
Iain replied to Nikola Topalov's topic in Works in Progress
Fab project!! Iain -
Cheers Ron! Iain
Slight Plan B, rather than digging out the paint pots, I needed to free the pilot's set from the box of ABS-like parts - which actually meant release all the parts from that box... So, here they are - cut from their supports - but still needing some fine fettling with blade and file: Seat and control column: Tailwheel: Throttle quadrant: Undercarriage legs: And those Brownings: Another thrilling installment of 'Defiant, a tale in daily parts' coming to a screen near you sometime soon! Have fun. Iain
