Joel_W Posted July 14, 2017 Share Posted July 14, 2017 All of the above. I'm hoping to have a very dirty plane when it's finished! Breaker, Looking forward to seeing pictures as you work through your finishing processes. Joel sandokan 1 Link to comment Share on other sites More sharing options...
Breaker Posted July 18, 2017 Author Share Posted July 18, 2017 Going back and forth with the underside trying to get a staining effect I'm happy with. I can see a lot more work here in the future! Out2gtcha, tomv87, sandokan and 4 others 7 Link to comment Share on other sites More sharing options...
Breaker Posted July 20, 2017 Author Share Posted July 20, 2017 Some of the base tonal work completed. This'll be the backdrop for some chipping and oil work to bring out that dirty skyraider look. Unfortunately I hit a snag. Don't top up your airbrush without the needle cap on gents! Harrison90 1 Link to comment Share on other sites More sharing options...
Joel_W Posted July 20, 2017 Share Posted July 20, 2017 Breaker, I really like the close up of the bottom of the Spad, as it really lets us see the tonal variation achieved via Black Basing, and along with some restrained pre-shading. Is that paint leaking out around the needle or the cone? Joel Link to comment Share on other sites More sharing options...
Breaker Posted July 20, 2017 Author Share Posted July 20, 2017 No Joel, unfortunately that's the needle hanging out the end all bent up! Link to comment Share on other sites More sharing options...
Breaker Posted July 21, 2017 Author Share Posted July 21, 2017 (edited) Whilst my airbrush has been out of action, Harold from AMS has hooked me up with some bombs and the correct fuel tank for the wing pylon so I got them cleaned up and ready to go. Aero-1C 150 gallon wing tank and M-47 WP 100Lb bombs that are a really common addition to the Sandy loadout I want. 4 x CBU-25, 2 x M47A4 WP, 2 x LAU-68s, 2 x LAU-61s, 1x SUU-11, an Aero-1C and an Aero-1D fuel tank. I've also been messing around with some chipping work around the cowl. I'm not too happy with it at the moment as it doesn't match my references that well but it's something I can work from. Edited July 21, 2017 by Breaker phantomdriver, KiwiZac, tomv87 and 5 others 8 Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 21, 2017 Share Posted July 21, 2017 I don't mind the chipping work, I think it looks pretty good ... but then I also know the frustration of not matching references, so good luck with it. Cheers Jim Link to comment Share on other sites More sharing options...
Joel_W Posted July 22, 2017 Share Posted July 22, 2017 Breaker, that really sucks about your airbrush. Another reason to have more then one. I'm about to order my 3rd with a #.5mm needle. So I'm armed with a .3mm, .4mm, and soon a .5mm setup. I gotta agree with ClumsyDude, the chipping looks realistic to me as well. Joel Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 22, 2017 Share Posted July 22, 2017 (edited) One thought on the chipping: there are plenty of lateral scratches running back from the panel line, and they look realistic. I also notice that the wear is not entirely aligned with the panel line - that is, sometimes there is chipping (in your example) away from the panel line, at the same time as there is paint between the chips and the panel line. Is it that one's eye expects to see the wear starting at the panel line and going back from there? Not sure if this makes sense - I might be able to mark up the photos to show what I mean, if it helps? Jim Edit - I should say, I am not trying to imply I have any answers, like I said earlier I think it looks good. Just offering a suggestion in case it helps you get the effect you're after ... for all I know my suggestion would make it worse. Edited July 22, 2017 by ClumsyDude Link to comment Share on other sites More sharing options...
Gazzas Posted July 22, 2017 Share Posted July 22, 2017 (edited) Looks great! Nice chipping on that cowl. Gaz Edited July 22, 2017 by Gazzas Link to comment Share on other sites More sharing options...
Breaker Posted July 23, 2017 Author Share Posted July 23, 2017 (edited) First round of painting completed. All done freehand. Few areas I need to sort out and clean up before I can seal it all and start looking at the decals and weathering. Edited July 23, 2017 by Breaker Joel_W, tomv87, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted July 23, 2017 Share Posted July 23, 2017 Awesome black basing and weathering - looks fantastic. Cammo is right on the money and the weathering even and very realistic. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Durangokid Posted July 23, 2017 Share Posted July 23, 2017 Nice job on the cammo... I dig it! Link to comment Share on other sites More sharing options...
ClumsyDude Posted July 23, 2017 Share Posted July 23, 2017 Terrific work on the camo ... I really like it. Freehand? Jim Joel_W 1 Link to comment Share on other sites More sharing options...
Breaker Posted July 23, 2017 Author Share Posted July 23, 2017 Yeah, Iwata HP-TR1 with a 0.3mm needle. Combination of MRP and MrHobby paints, just the standard SEA colours. Joel_W and ClumsyDude 2 Link to comment Share on other sites More sharing options...
