dutik Posted April 23, 2017 Author Share Posted April 23, 2017 Not a biggie - the outer missle rails were a local modification by just 2 users of the whole F-6 family: Pakistan and Egypt. All the other F-6 aircraft around the globe never had them (and the F-6 is still operational in different air forces). The Russians made one too for the Mig-19, but only a prototype that never made it into production. So it is ok that Trumpeter did not add these pylons. The ORO rocket pods are an omission - they are in the guided missle interceptor kits for aircrafts that never used them, but not in the F-6 variant kit that used them operational. This is a real miss. Especially because nobody else makes these specific pods... Regards - dutik Shaka HI 1 Link to comment Share on other sites More sharing options...
dutik Posted May 21, 2017 Author Share Posted May 21, 2017 Well, as any summer lacking modelling time. At least I added the remaining wiring and plumbing to the other UC bay. More to come with the UC and all actuators in place. There are a lot of thouse inside the Farmers UC bay, because Mikoyan manged to break down the UC cover into 3 different parts; not to forget the actuators for the UC himself, which will be added after painting of the aircraft... The not-so-funny part is to fill and sand all these gaps at the rear fuselage and to re-engrave the lost lines. Time consuming and frustrating work. We shall see. Regards - dutik sandokan, Paul in Napier, Seversky and 1 other 4 Link to comment Share on other sites More sharing options...
dutik Posted June 3, 2017 Author Share Posted June 3, 2017 Finished rescribing of the lost lines as well as a dozen of hatches along the fuselage Pulled off the protective tape from the pit opening and started to build and paint the remaining interior parts: Seat, rear cover, gunsight and stick. Left them off while working at the fuselage to avoid breaking off something. Everything was stored in the right place, but I couldn't find the sprue with the control stick. Looked for the stick a full hour, nothing. Nada. Bad news Finally I managed to find a Fw-190 stick in the stash. Not really a jet stick, but good enough. Checked the pit how to mount it, and well, the original control stick was right in place from the beginning... Check the image at the first page. Oh yeah, I am a genius Regards - dutik Gazzas and sandokan 2 Link to comment Share on other sites More sharing options...
kikka Posted June 3, 2017 Share Posted June 3, 2017 dont worry buddy , happens to me more than i will ever admit . dutik 1 Link to comment Share on other sites More sharing options...
dutik Posted June 4, 2017 Author Share Posted June 4, 2017 Cockpit installed, minus a few small bits around the rim: I am not sure if the seat has to rest completly inside the slot behind it. Fit was very tight. I pressed it into as far as possible without breaking apart the fuselage. There is a banjo-shaped part for the gunsight. The instructions just point into the general direction like a short run kit. There is also no special location point. This must be some kind of data projector or a gun camera. The end of the "arm" has to be in the centerline and roughly at half height of the HUD screen. The same kind of sight was used with the early Mig-21, so in case you have no images of the thing look for the other Mig. Added some details that were omissed by Trumpeter. When adding the front screen (the large clear part of the HUD) dryfit the front canopy to bring the HUD out of the way of the front window. Fit is very tight here. Anything else is easy, if you remove paint and maybe a bit of styrene inside the slot of the sight that meets the dashboard. Up now to a very disliked task: The rear canopy has a large center seam that needs to be removed. Lets hope I do not brake apart or completly scratch the canopy. There is no replacement at hand... Regards - dutik sandokan, Dany Boy, Paul in Napier and 3 others 6 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 10, 2018 Share Posted June 10, 2018 Any more progress on this one, dutik? Kev Link to comment Share on other sites More sharing options...
dutik Posted June 12, 2018 Author Share Posted June 12, 2018 Modelling stalled last summer due to real life workload. Was not able to finish a single build last year... Resumed modelling this year. Want to finish at least the Biafran Texan, so everything else is on the backburner. Regards - dutik Out2gtcha, LSP_Kevin, LSP_K2 and 1 other 4 Link to comment Share on other sites More sharing options...
