alaninaustria Posted April 22, 2017 Author Share Posted April 22, 2017 Thanks Pete!! I have so many birds just inches away from the finish line... I have managed one promise - no new kits bought/started until these are all done!! Cheers Alan Link to comment Share on other sites More sharing options...
alaninaustria Posted April 23, 2017 Author Share Posted April 23, 2017 Another small step in the right direction: General purpose bombs - fuses painted!! Tomorrow the rest of the olive green and yellow stripes to follow!! Cheers and thanks for droping by! Alan sandokan and Jan_G 2 Link to comment Share on other sites More sharing options...
Guest Posted April 23, 2017 Share Posted April 23, 2017 Munitions look great ! Are you gonna put arming wires on them ?....Harv Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 Unmasked!! 3x thin striped and 3x thick stiped! Now, just a few steps away from getting these complete! Harvey, I'm not sure how to simulate the wiring? Were they also not carrying flags (red) prior to launch? Cheers Alan sandokan and Jan_G 2 Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 (edited) Pull'in some overtime on this one..... Almost going blind and getting the shakes from positioning, painting and 'weeding' the masks!! She's starting to look the part!! And up close: Cheers Time for a break!! Alan Edited April 24, 2017 by alaninaustria sandokan, stusbke, blackbetty and 1 other 4 Link to comment Share on other sites More sharing options...
dodgem37 Posted April 24, 2017 Share Posted April 24, 2017 You do some nice work Alan in Austria! Sincerely, Mark alaninaustria 1 Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 And a short update on the new general purpose bombs: all stenciled up! Cheers Alan Jan_G and sandokan 2 Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 Thanks Mark, much appreciated! Cheers Alan Link to comment Share on other sites More sharing options...
Guest Posted April 24, 2017 Share Posted April 24, 2017 Alan , very thin copper wire from middle of pylon "through" the nose fuse. It might be a little late but almost all munitions were well weatherd except for the tail fin assembly. Reaso is bombs were treated fairly ruff and stored outdoors mostly. The tail fins were usually new and crated. I'll see if I can find pics latter if you wish.....Harv Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 Thanks Harvey! I would really apprciate that! Cheers Alan Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 (edited) Last update for today! Finished up the other side - and I'm not even half finished with the masks Up close: Well, tedious but enjoyable work! Am getting closer to the finishline with this bird!! Cheers Alan Edited April 24, 2017 by alaninaustria HerculesPA_2, MikeMaben, blackbetty and 1 other 4 Link to comment Share on other sites More sharing options...
Guest Posted April 24, 2017 Share Posted April 24, 2017 Try this video Alan. It will explain a lot. I used to drive the Jammed loading bombs........Harv Link to comment Share on other sites More sharing options...
alaninaustria Posted April 24, 2017 Author Share Posted April 24, 2017 Thanks Harv! I think I understand the wire concept now... so when the pilot pulled the drop trigger to deliver some *freedom* the bombs dropped and the wires pulled a pin and armed the detonator? I am going to investigate this more before commiting to the build!! I appreciate your help!! Cheers Alan Link to comment Share on other sites More sharing options...
Guest Posted April 24, 2017 Share Posted April 24, 2017 Your welcome Alan and you are correct. The wire keeps the fuse from turning( the little props on them) the fuse needs to turn so many revolutions before it is armed. You can knock the fuse of the bomb with a baseball bat and it wont explode. Don't ask how I know .........Harv Link to comment Share on other sites More sharing options...
Finn Posted April 24, 2017 Share Posted April 24, 2017 (edited) Here is a A-4 getting it's arming wires installed on it's bombs: http://www.gstatic.com/hostedimg/22da6cc1e04e4401_large if you look between the swaybraces (just below the 12 on the bottom rack) you'll see the end of the wire hooked up to the rack, that is a swivel shaped sort of like this 0 with the wire attached to the bottom of it. The swivel is hooked up to the arming solenoid, when the pilot selects Master Arm and Nose Arming, the solenoid is energized holding the swivel, along with the arming wire, so when the bomb drops the arming wire is pulled out and the bomb can arm. If the pilot wants to drop the bomb safe then, depending on the a/c type, Master or Nose/Tail Arming is not selected, so the solenoid is not energized and swivel and arming wire stay with bomb when it falls safe. Although having several hundred pounds falling to earth does make a thud, and sometimes a boom. Also note the bombs are slightly weathered and the difference between the yellow stripes, freehand on one and masking on the other. Jari Edited April 24, 2017 by Finn sandokan 1 Link to comment Share on other sites More sharing options...
