Crossofiron Posted February 8 Share Posted February 8 Hello All, Got a question regarding some pipework on the Instrument Panel Bulkhead on my ML407; Can anyone tell me where these pipes go from and too or what they are? Many thanks Steve Link to comment Share on other sites More sharing options...
19squadron Posted February 9 Share Posted February 9 They are pneumatic airlines, going to the port guns, from the instrument panel gauge and then the cylinders behind the seat. thierry laurent, dennismcc and Uncarina 3 Link to comment Share on other sites More sharing options...
DonH Posted February 11 Share Posted February 11 One line is from the engine driven compressor to the two air tanks on the port wall I think, two lines are from the brake pressure gauge to the brakes, via a load of other junction boxes (see caveat below) One is for auto-cocking(?) the guns (if that is the right term) I think the auto-cocking is for cannons only, which is why there are only three air lines on the early marks. Also, please note the "I think" in this post. It is a while since I researched the pneumatic system on the Spitfire. It is possible that one of the lines I said was from the brake pressure gauge is actually from the flap lever. I will dig some more later. Anthony in NZ and MikeC 2 Link to comment Share on other sites More sharing options...
Crossofiron Posted February 11 Author Share Posted February 11 Many thanks! Cheers Steve Link to comment Share on other sites More sharing options...
thierry laurent Posted February 11 Share Posted February 11 Out of my memory, if you look at the Recce versions you will just see two lines (for the LG brakes). Link to comment Share on other sites More sharing options...
19squadron Posted February 11 Share Posted February 11 (edited) Spitfire Mk I II and Vb have 5 pneumatic airlines running down frame 8 on the port side [as per original post question] . Aircraft with C wings initially had 5 lines, but reverted to 4 when they lost their landing lights. I have never seen a Spitfire with just three lines on frame 8. Edited February 11 by 19squadron addition of pic geedubelyer and Anthony in NZ 1 1 Link to comment Share on other sites More sharing options...
DonH Posted February 12 Share Posted February 12 (edited) 13 hours ago, 19squadron said: I have never seen a Spitfire with just three lines on frame 8. You may well be correct, I have looked at schematics for so long, that I have confused myself! One minor point, I believe the yellow labels are possibly swapped between browning lines and brake pneumatic lines. The thick pipes on the control stick are gun lines. I also agree that there were five lines on frame 8, my focus was on the ones coming through the hole from behind the instrument panel. If the landing lights were removed, that takes away two lines, leaving three. Edited February 12 by DonH Total lack of useful knowledge Link to comment Share on other sites More sharing options...
DonH Posted February 12 Share Posted February 12 OK, back to the photograph posted by Crossofiron. This is a MkIX with four pipes running down frame 8. My comments are: 1) I was totally wrong about auto-cocking. The pipes for those were on the floor and none of them ran up frame 8 (I believe) 2) I was totally wrong about the Heywood compressor - I am pretty sure the line from this stayed low and went over or through Frame 8 at floor level 3) Two pipes are definitely from the brake pressure gauge. 4) I simply don't know about the other two. They could be two from the flap lever or one from the flap lever and another from the brake pressure gauge. However, I have a MkI drawing that clearly shows one of the brake gauge pipes running down the back of frame 8. Maybe this was moved for some reason on later marks? On early marks, I expect the three lines were one flaps and two brakes. I can't figure out why this changed later on. Anyhoo, here is the schematic, hopefully someone will know for sure, cos I don't.. (image posted for research purposes, I will delete it if this offends copyright,etc.) Link to comment Share on other sites More sharing options...
19squadron Posted February 12 Share Posted February 12 9 hours ago, DonH said: You may well be correct, I have looked at schematics for so long, that I have confused myself! One minor point, I believe the yellow labels are possibly swapped between browning lines and brake pneumatic lines. The thick pipes on the control stick are gun lines. I also agree that there were five lines on frame 8, my focus was on the ones coming through the hole from behind the instrument panel. If the landing lights were removed, that takes away two lines, leaving three. The brake line is behind the control stick, actuated by the long brake actuator in the middle of the stick hand hold, so that is my mistake, it's a single line that goes to a 5 way connector and a relay valve. The two lines on the front of the stick are one guns, and the second is camera [if fitted] but always plumbed. On frame 8 as marked. Link to comment Share on other sites More sharing options...
Crossofiron Posted February 12 Author Share Posted February 12 Thanks guys Link to comment Share on other sites More sharing options...
