Tolga ULGUR Posted March 1 Author Share Posted March 1 Finally the painting has started The first step is the lower surfaces. They were painted with Gunze acrylic RLM65. scvrobeson, Greg W, Sasha As and 11 others 14 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 2 Share Posted March 2 Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Phil88 Posted March 2 Share Posted March 2 Very nice approach to this plane. It's always a good job like everything you do. Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 2 Author Share Posted March 2 3 hours ago, MikeMaben said: 1 hour ago, Phil88 said: Very nice approach to this plane. It's always a good job like everything you do. Thanks Link to comment Share on other sites More sharing options...
J.J. Posted March 3 Share Posted March 3 Don't forget to add the small upper wing root bulges. Dragon tells you to put the underneath the cockpit floor, but that is incorrect. There are small slots for them in the wing roots. Jens Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 3 Author Share Posted March 3 28 minutes ago, J.J. said: Don't forget to add the small upper wing root bulges. Dragon tells you to put the underneath the cockpit floor, but that is incorrect. There are small slots for them in the wing roots. Jens Thanks Jens That's what you're talking about, right? J.J., scvrobeson and HB252 3 Link to comment Share on other sites More sharing options...
PEYSSON Gilles Posted March 3 Share Posted March 3 Hello Tolga Very beautiful Intrados ! Gilles Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 4 Author Share Posted March 4 12 hours ago, PEYSSON Gilles said: Hello Tolga Very beautiful Intrados ! Gilles Thanks Gilles Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 5 Author Share Posted March 5 Upper surfaces; First step RLM71 from Gunze. TankBuster, HB252, scvrobeson and 11 others 14 Link to comment Share on other sites More sharing options...
PEYSSON Gilles Posted March 5 Share Posted March 5 Hello Tolga Com = Gilles Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 7 Author Share Posted March 7 Hello Houston I need to clarify the scheme of this 109. My reference when I started was Eduard. And accordingly the upper surfaces were RLM70/71/02. However, when I researched a little more, I came across different comments. For example Montex recommends RLM 02/71/63. AZ models also recommend the same colors Hussar recommends RLM02/71/65 I'm a little confused in this situation. In the reference picture, the separation line between the upper and lower surfaces is not visible in the light colored part. So it is RLM65? Your opinions and comments are welcome. coogrfan 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 8 Author Share Posted March 8 After some more research, I decided to continue with the colors in this scheme. Those who object to this, please make yourself known before the groom kisses the bride. chrish, Greg W, TankBuster and 7 others 9 1 Link to comment Share on other sites More sharing options...
MikeMaben Posted March 9 Share Posted March 9 Yep ... Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
scvrobeson Posted March 9 Share Posted March 9 I think the 71/02/63 over 65 scheme is going to be your best bet. Either way, you'll pull it off brilliantly Tolga Matt Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted March 10 Author Share Posted March 10 14 hours ago, scvrobeson said: I think the 71/02/63 over 65 scheme is going to be your best bet. Either way, you'll pull it off brilliantly Tolga Matt Thanks a lot Matt, appreciated scvrobeson 1 Link to comment Share on other sites More sharing options...
