LSP_Ray Posted December 11, 2023 Share Posted December 11, 2023 I have an old 3D printed model, a 1/35th Hotchkiss H-39, from about 20 years or more ago. I pulled it out the other day and noticed parts had what looked like some crystalization on one side and a gummy residue on the other side. Any ideas on how I can clean this up? Or am I destined to throwing this one in the trash bin? It was a spendy kit at the time, and includes an interior with many tiny fragile parts. BiggTim 1 Link to comment Share on other sites More sharing options...
CShanne Posted December 11, 2023 Share Posted December 11, 2023 Do you have photos. I would be very concerned that the gummy side is uncured resin, as it can leak if it is not cured properly. I would suggest putting it in the sun for a while and see if it can set. That said, without seeing it, I cannot for sure say that is the issue. The crystallization is hard to say without seeing it. LSP_Ray and BiggTim 2 Link to comment Share on other sites More sharing options...
quang Posted December 11, 2023 Share Posted December 11, 2023 I don’t know about the material they used to print 3D models 20 years ago but nowadays we use a isopropyl alcohol (IPA) bath to clean up 3D prints to remove the uncured resin. You should try on an unused part of your model to see if it works. HTH LSP_Ray and BiggTim 2 Link to comment Share on other sites More sharing options...
BiggTim Posted December 11, 2023 Share Posted December 11, 2023 Keep in mind, if you use alcohol, make sure it's at least 90 percent. Standard 70% won't touch it. LSP_Ray, quang and Out2gtcha 3 Link to comment Share on other sites More sharing options...
LSP_Ray Posted December 11, 2023 Author Share Posted December 11, 2023 Photos: LSP_Kevin, BiggTim and Out2gtcha 3 Link to comment Share on other sites More sharing options...
thierry laurent Posted December 11, 2023 Share Posted December 11, 2023 Hi Ray, This looks like the resin Shapeways used for years. To remove the crystals/dust, simply use a soft glass pen (largely opened). For the gummy side, I'm agreeing with prior comments. I would first try a UV lamp for some hours and then pure alcohol. Good luck. Thierry BiggTim and LSP_Ray 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 11, 2023 Share Posted December 11, 2023 It looks to me like both issues are symptoms of inadequate or improper cleaning. In modern resin 3D printing, it’s common to have white blotches where excess resin wasn’t fully cleaned off the model prior to curing (or the cleaning solution itself was dirty). The sticky residue has a similar cause, and additional cleaning and curing usually takes care of it. Worth trying, anyway! Kev Link to comment Share on other sites More sharing options...
