Stevepd Posted November 26, 2023 Posted November 26, 2023 Hi folks, I have a 1/32 Tamiya F-14 on the next to do list. If I choose to put the crew in, would I bother with a AM resin cockpit, or would it be waisted because you wouldn't see any of it.
alain11 Posted November 26, 2023 Posted November 26, 2023 Hi An expensive resin set, for what!? ( in this present case ) .... At least the F 14 interior photo edched set from Eduard (ref 32529 ), because the decals provided by Tamiya are awful, and aren't of the today's level... that’s my opinion Alain Oldbaldguy 1
thierry laurent Posted November 26, 2023 Posted November 26, 2023 This mainly depends on the canopy: opened or closed? In the second case pilots may be sufficient. geedubelyer 1
BloorwestSiR Posted November 26, 2023 Posted November 26, 2023 4 hours ago, Stevepd said: Hi folks, I have a 1/32 Tamiya F-14 on the next to do list. If I choose to put the crew in, would I bother with a AM resin cockpit, or would it be waisted because you wouldn't see any of it. Having just finished one and partway through a second, I took two different approaches. On the one with the open canopy, I used a Teknics resin cockpit with the Kitsworld 3D decals. The decals were for the IP panels which are completely devoid of detail. I also swapped out the seats for a pair from Aires as this way I could pose the belts in different positions. The second one which is still on my bench will be inflight so I used Red Fox 3D decals for the whole cockpit along with Reedoak crew figures. With the crew in place. The new pilot figures are the biggest and the most visible upgrade. HAD Decals also does helmet decals for some of the squadrons. geedubelyer, Gary Needham, Stevepd and 3 others 6
Oldbaldguy Posted November 26, 2023 Posted November 26, 2023 Wow. Those crew figures are really nice. You say this one will be in flight? BloorwestSiR 1
BloorwestSiR Posted November 26, 2023 Posted November 26, 2023 1 hour ago, Oldbaldguy said: Wow. Those crew figures are really nice. You say this one will be in flight? The figures are really good. They're a perfect fit into the kit cockpit. Yes, it'll be an inflight display. Dragon, Stevepd, GusM and 3 others 6
