Juggernut Posted November 5, 2020 Share Posted November 5, 2020 I've heard these paints are decent so I opted to give them a try. Does anybody here use them and if so, do you have any recommendations/observations on their use (i.e., is it imperative to use the AMMO primer and/or the AMMO thinner)? I've purchased a bottle of their grey primer and a few colors to try out. Since my go-to paints (enamels) are fastly disappearing, I thought I'd give these a shot (pun intended). PLEASE NOTE: This isn't a thread asking about recommendations on/for any other paints...I'm specifically asking ONLY about the acrylic AMMO by MiG paints and their use. Out2gtcha 1 Link to comment Share on other sites More sharing options...
Dave Williams Posted November 5, 2020 Share Posted November 5, 2020 (edited) I use them a lot and don’t have any problems. My recommendation is to always use them over a primer. I normally use Badger Stynylrez primer. Some have said that their Ammo One Shot Primer is the same thing repackaged, but I never tried it. I typically use their brand thinner when using their paints to avoid any problems. You don’t need that much and a bottle lasts a while since I only use it for thinning, not for cleaning the airbrush afterwards. Only negative is they recommend letting it dry for 24 hours, so if you want to lay a base coat and then immediately mask and lay down a second color, it may not work out right. HTH. Edited November 5, 2020 by Dave Williams Out2gtcha and Juggernut 1 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted November 5, 2020 Share Posted November 5, 2020 I've never used any of their stuff at all. Sorry. I've heard them mentioned here numerous times though, so I'd imagine you'll get some good feedback. Link to comment Share on other sites More sharing options...
Out2gtcha Posted November 5, 2020 Share Posted November 5, 2020 I have a few of their colors and some of the Mig metal colors. I found they did really look awesome. I had some adhesion issues, but seemed to overcome them for the most part by ensuring primer was used. Juggernut and CANicoll 1 1 Link to comment Share on other sites More sharing options...
GusM Posted November 6, 2020 Share Posted November 6, 2020 I'd second the above. They work best over primer, either their own or Mr Surfacer 1500, but can be a little fragile if you don't let them dry thoroughly. You can increase the robustness by thinning with Mr Levelling rather than their own thinner but l get decent results with both. The transparent primer can also be used as a very nice matte varnish as well. Juggernut and CANicoll 1 1 Link to comment Share on other sites More sharing options...
CANicoll Posted November 10, 2020 Share Posted November 10, 2020 Thanks for asking about the AMMO paints, I was thinking of the same question! Chris Link to comment Share on other sites More sharing options...
