mustang1989 Posted July 11, 2019 Author Share Posted July 11, 2019 3 hours ago, Gazzas said: That does look very nice, Joe! I prefer to paint mine in the same way. Though....it really erks me when I pull off the mask and see that I've completely missed a spot. Right???!!!! Link to comment Share on other sites More sharing options...
mustang1989 Posted July 11, 2019 Author Share Posted July 11, 2019 5 hours ago, Out2gtcha said: Very nice work! Thanks bud! Link to comment Share on other sites More sharing options...
mustang1989 Posted July 11, 2019 Author Share Posted July 11, 2019 Almost ready for the painting the lighter undersides of her after some more color border touch up: LSP_K2, Kahunaminor and chukw 3 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 12, 2019 Author Share Posted July 12, 2019 Did ALOT of work today on this bird. The friggin' landing gear legs broke loose from their mounting and I had to re-glue those back on. I've pretty much completed the camo scheme for this aircraft and have to say that this one goes down as one of the most difficult paint jobs that I've done yet with all the black basing, marbling and masking. Sheesh!!! With all that being said and aside from needing to paint the back of the engine nacelle a burnt black here's where we are now: and the bottom side. after the burnt black application on the engine nacelle we'll be off to completing the nose section and applying a gloss coat! My FAVORITE part. LSP_K2 and LSP_Kevin 2 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 13, 2019 Author Share Posted July 13, 2019 Ok gang...……..after 3 years the nose assy is installed at last. That part is why I shelved this build 3 years ago. Just couldn't figure out a way to mount all of that up cleanly. It took me a while to get it all sorted out with an approach to this but I think I found one that worked for me. I had glossed the entire aircraft, applied the decals and then adhered the cockpit assy to the front of the aircraft and masked it off. From there I filled the huge lip that was on the top of the fuselage to cockpit join and worked it all in together by sanding and yet more filling. This resulted in the seam not disappearing from the top of the fuselage at the cockpit join so I added a seam in the name of uniformity. It's not "correct" but it looks uniform. After that I black based the entire sanded and filled area, applied the irregular gray pattern and went back over it in RLM 82. Still a little touch up painting to do on the starboard side of the affected area. Here's where we're at so far. Gazzas, LSP_K2, chukw and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 13, 2019 Share Posted July 13, 2019 Looking great, Joe. I really like what I see so far. mustang1989 1 Link to comment Share on other sites More sharing options...
Gazzas Posted July 13, 2019 Share Posted July 13, 2019 sweet, Joe! mustang1989 1 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 14, 2019 Author Share Posted July 14, 2019 5 hours ago, LSP_K2 said: Looking great, Joe. I really like what I see so far. 2 hours ago, Gazzas said: sweet, Joe! Thanks you guys! Link to comment Share on other sites More sharing options...
mustang1989 Posted July 14, 2019 Author Share Posted July 14, 2019 Well.....for what this is worth I got the flat coat applied. No fading on the sides but some on the upper surfaces of the bird. I'm hoping I didn't go too far. LSP_K2, Gazzas, chukw and 1 other 4 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 15, 2019 Author Share Posted July 15, 2019 Well.....I finished the screw head application but still need to weather the framing somewhat to tone the brightness of the screw detail down. They pop just a little too loudly. Tnarg, LSP_K2, Gazzas and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_K2 Posted July 15, 2019 Share Posted July 15, 2019 Looks just great, Joe. mustang1989 1 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 16, 2019 Author Share Posted July 16, 2019 23 hours ago, LSP_K2 said: Looks just great, Joe. Thanks Kevin and the rest of the gang for the "likes". I'll be starting on the engine assembly and painting next. I've been doing my research so as to build as accurate of a 004 as possible. Stay tuned: Here's where the completed main part of the build is as of now.... LSP_Kevin, Gazzas and LSP_K2 3 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 17, 2019 Author Share Posted July 17, 2019 I started up on the engine paint up this morning. I have really come to like these macro shots as I use them as a tool to go back and fix certain things that either I miss or made a mistake on. Found a couple of areas that need some attention in the shot below. Anyways....after a base coat, a very light wash just to bring the details out and a little bit of detail painting this is the latest progress: LSP_Kevin and LSP_K2 2 Link to comment Share on other sites More sharing options...
dmthamade Posted July 17, 2019 Share Posted July 17, 2019 I remember this kit back in the day. Never did buy it, too intimidated by the canopy work. Are you going to mount the engine on the model or have it separate? Don mustang1989 1 Link to comment Share on other sites More sharing options...
mustang1989 Posted July 17, 2019 Author Share Posted July 17, 2019 1 hour ago, dmthamade said: I remember this kit back in the day. Never did buy it, too intimidated by the canopy work. Are you going to mount the engine on the model or have it separate? Don Don, when I bought the kit initially I merely wanted to build this aircraft as I've always thought a lot of it. What I found out along the way is exactly what you're describing with not only the amount of canopy work that was needed but the entire nose construction (at least getting the whole front section onto the fuselage and make it look like it belonged there without any botches) onto the fuselage. That, at least for me, was a daunting task just by looking at it and a real PIA to carry out and get to look at least half right. It was hard work but it paid off for me. I don't think I've built the best 234 ever but I do feel pretty good about it. LSP_K2 1 Link to comment Share on other sites More sharing options...
