1:32 Spitfire MkVIII "Fargo Express" (Tamiya)
Guest Vincent
The landing flaps retraction/deployement pneumatic ram :
The line guards are being redone - the waffle pattern wasn't defined enough for my taste
:ph34r:
Edited by Vincent/MDC
Guest Vincent
And here are the new line guards, much much better !
Guest Vincent
Got a bit more done.
I finished rear frames and glued them in place to make detailling the left side an easier task. You will note the crash pylon reworked as the VIII had a different arrangement. In particular the beam between the frames was replaced by a steel tube :
I also redid the heel board frame as i found that my first attempt wasn't good and symetrical enough
more soon
wow
you should have done this when they brought the VIII kit out and sold it all in resin
not sure it's worth it now - don't see too many VIIIs built
fwiw I'd still buy a set ;)
Guest Vincent
1 hour ago, nmayhew said:
wow
Hi
This is not for a set. I'm not doing pattern work anymore. I'm building it for myself. It's a one off
V
Guest Vincent
Now that i'm starting to add the electrical wiring on the left side, the need of the various modifications i did becomes more evident :
Next will be the pneumatic system or the throttle block, not sure which one first
Guest Vincent
A world of spaghettis :
Lol
I added the gun camera mount and the TR1133 frequency selector. It is predrilled and will get its loom as well
Guest Vincent
2 steps forward, one back
Had to revise the wiring routing. Added the cockpit left light and the dust filter control. The command cable is only there for the pic. It will be added after i have painted the sidewalls
But this part is now more less done.
I'll now take care of the the instrument panel support frame with its fuel tank selectors  levers (once again different compared to the IX)
V
Guest Vincent
And here are the tank selectors
On the right, lever for the main tanks and on the left lever for the wing tanks
I'm redoing the brake relay valves - i did the wrong version. It should be the Dunlop MKII. Hopefully tomorrow i'll have it done as well
V
Guest Vincent
And here we have the new Dunlop valves and the start of the pneumatic system, namely the pressure equalizer
The real valves :
Guest Vincent
And the parts in place.
Starting to look good !
I also corrected the electrical fuel pump filter box
