mozart Posted January 17, 2020 Author Posted January 17, 2020 OK, with the Gladiator pretty much finished apart from the aerials, the Bucker is calling to me, another ICM kit. I really enjoyed the start of this but got seriously bogged down with the rigging. Quite honestly I didn't know which type of line to use - I don't like EZ line because it's so inconsistent so on this one I used Uschi van Rosten's stuff, but it really is far too thin for this scale in my opinion and an absolute nightmare to use, hence the nearly two years on the SOD. BUT!....renewed and re-invigorated....she will be completed, the rigging being the now tried and tested Prym. I've a little remedial work to do from when I hacked out the previous attempt at rigging, and I need to reconsider moulding the strut "boots", but the Stieglitz should soon have a stable mate on the training field. Trak-Tor 1
Wackyracer Posted January 17, 2020 Posted January 17, 2020 I've used the largest Uschi rigging without issue on 32nd builds. do you have the 2 other sizes? The nice thing about it is it doesn't tend to have flat spots or twist. I've just got a couple of reels of Prym to use on the Gladiators as per your excellent build.
mozart Posted January 17, 2020 Author Posted January 17, 2020 1 hour ago, Wackyracer said: I've used the largest Uschi rigging without issue on 32nd builds. do you have the 2 other sizes? The nice thing about it is it doesn't tend to have flat spots or twist. I've just got a couple of reels of Prym to use on the Gladiators as per your excellent build. That's interesting, what size is that please? I have 0.030 and 0.050, those are the only ones I've ever been able to find and both are too small in my opinion. I agree about the flat spot or twisting, but Prym behaves itself if you do!! Good luck with the Glad. Out2gtcha 1
Out2gtcha Posted January 17, 2020 Posted January 17, 2020 3 hours ago, mozart said: That's interesting, what size is that please? I have 0.030 and 0.050, those are the only ones I've ever been able to find and both are too small in my opinion. I agree about the flat spot or twisting, but Prym behaves itself if you do!! Good luck with the Glad. Standard: 0,03mm Fine: 0,02mm Superfine: 0,01mm Those are the only ones listed on Uschis site. Ive got the standard and have to agree with Max, its a bit small even with the largest "Standard" size. The Uschi rigging is also actually flat in profile just like EZ Line, but its A. far thinner, and B. much more consistent in profile.
Wackyracer Posted January 18, 2020 Posted January 18, 2020 Standard rigging 0.03 Gazzas and Landrotten Highlander 2
Chek Posted January 18, 2020 Posted January 18, 2020 In the intervening period you may be interested to learn that Quickboost now do a resin set of rigging leather 'boots' (QB32206) .
mozart Posted January 18, 2020 Author Posted January 18, 2020 1 hour ago, Wackyracer said: Standard rigging 0.03 Well that certainly looks right, assuming this is a 1/32 scale model, but on the much smaller Jungmann it was still too thin for me. I’ll do a further check later today, very happy to be proved wrong! Thanks Chek, I have bought those but they are a bit underwhelming and disappointing to be honest. When I’m checking the rigging material later I’ll have a closer look to see how useable they may be.
Wackyracer Posted January 19, 2020 Posted January 19, 2020 22 hours ago, mozart said: Well that certainly looks right, assuming this is a 1/32 scale model, but on the much smaller Jungmann it was still too thin for me. I’ll do a further check later today, very happy to be proved wrong! Thanks Chek, I have bought those but they are a bit underwhelming and disappointing to be honest. When I’m checking the rigging material later I’ll have a closer look to see how useable they may be. yes Max WNW AEG mozart 1
