MikeMaben Posted September 16, 2017 Share Posted September 16, 2017 ... nightly modelling insomnia ... You 'knew' that was part of the hobby ... Gazzas and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted September 17, 2017 Share Posted September 17, 2017 The Aviattic pilot with 5 heads... Some of those heads look unnecessarily S&M-ish. Thankfully two of them look acceptable. Cheers, Gaz Those S&M masks are WW1 German cold weather masks. Very legit, but scary looking. Link to comment Share on other sites More sharing options...
Gazzas Posted September 17, 2017 Author Share Posted September 17, 2017 Well, real or not, I'm not gonna be using it. I was thinking that the flight helmet was more of a bomber/gunner item till I found this: The future Reichmarschall wearing one.... in an Albatross D.III no less. Hey, I have another question. The windshield as supplied by Roden is a flexible cellophane type stuff. What glue should I use for that? Thanks. Gaz Link to comment Share on other sites More sharing options...
thierry laurent Posted September 17, 2017 Share Posted September 17, 2017 CA glue. Link to comment Share on other sites More sharing options...
ZachP319 Posted September 17, 2017 Share Posted September 17, 2017 Yes CA but carefully lol Zach Link to comment Share on other sites More sharing options...
Gazzas Posted September 17, 2017 Author Share Posted September 17, 2017 (edited) Thanks guys. No idea where it's get watch crystal cement. But I'm always looking for better ways to improve my clear parts. Right now I'm imagining trying to hold a spring-loaded loaded piece of cello in place while waiting for the glue to dry. CA and I have a strange relationship. Sometimes it works great, and at other times it's as capricious as a recalcitrant thirteen year old. Edited September 17, 2017 by Gazzas Link to comment Share on other sites More sharing options...
RLWP Posted September 17, 2017 Share Posted September 17, 2017 I would rather use something like UHU for that job Richard Link to comment Share on other sites More sharing options...
Gazzas Posted September 17, 2017 Author Share Posted September 17, 2017 Thank you for the Uhu recommendation. I've never heard of, not seen a bottle with that label. One of the joys of communicating with people from the other side of the world is wondering about, and trying to find recommended products that may or might not be in your corner of the globe, or sold under a different name. Or, in many Australian cases, the cost is ten times what it costs elsewhere. I'm at work using my phone, and I hate searching for things on its diminutive screen. I'll have a look-see when I get home. Cheers, Gaz Link to comment Share on other sites More sharing options...
RLWP Posted September 17, 2017 Share Posted September 17, 2017 https://www.officeworks.com.au/shop/officeworks/p/uhu-all-purpose-power-glue-33ml-uh3337655 Richard Gazzas and LSP_K2 2 Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 17, 2017 Share Posted September 17, 2017 Slimy stuff, but I've actually used clear silicone before, with very good results; Elmer's white glue too. Gazzas 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 18, 2017 Share Posted September 18, 2017 Well you may indeed use any glue that is compatible with the material: epoxy glue, contact glue, improved white glue, acrylic glue or whatever one rather than CA but do not forget two main features: the stuff is very thin and flimsy. So you need a glue that has no thickness and gives instant grip. As far as I know CA stays the best option for that. Link to comment Share on other sites More sharing options...
RLWP Posted September 18, 2017 Share Posted September 18, 2017 It doesn't need to be 'instant grip', and UHU has the advantage that it is easily removable, doesn't fog the transparency and has a reasonable amount of elasticity. This is one of those 'it works for me' arguments where there is no single solution. UHU works for me, I'm offering it as an alternative. If CA works for you, great! Use CA Richard Gazzas and thierry laurent 2 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 18, 2017 Share Posted September 18, 2017 I agree that Uhu is less risky. To use CA, I put first a drop on waxed paper to let the fogging fumes go away. In any case, for people who are not confident in gluing such parts, keep in mind doing copies is very easy. It may be clever to do copies first! Gazzas 1 Link to comment Share on other sites More sharing options...
thierry laurent Posted September 18, 2017 Share Posted September 18, 2017 Another important point to mention: do not try to glue the part as such on the fuselage. This will be messy!!! Build first a base out of plastic strip. Glue the strip on the fuselage and then the windshield on that base. This will be far easier! RLWP and Gazzas 2 Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted September 18, 2017 Share Posted September 18, 2017 And acetate, when done correctly, looks bunch better than the thick clear plastic that WnW uses. Link to comment Share on other sites More sharing options...
