quang Posted June 5, 2016 Share Posted June 5, 2016 Hello all, I'm currently building the 1/32 Hurricane Mk IIc from FLY Models and will need your help concerning the resin wheels provided with the kit. While by no means an Hurricane expert, they look a little odd to me, especially the wheel centre which is tiny compared to the Pacific Coast Models Hurricane Mk I wheels. Also the FLY diameter ( 21,2 mm) is larger than the PCM (20,0 mm). Are the FLY offerings correct or should I look elsewhere for more accurate parts? Please let me know what you think. Thank you all for your help. Cheers, Quang Harold 1 Link to comment Share on other sites More sharing options...
AEROPOXY Posted June 5, 2016 Share Posted June 5, 2016 http://forum.keypublishing.com/showthread.php?127931-Sitfire-Hurricane-wheel-sizes Link to comment Share on other sites More sharing options...
quang Posted June 5, 2016 Author Share Posted June 5, 2016 Thanks for your link, Aeropoxy but it doesn't explain the tiny wheel center. Regards, Q Harold 1 Link to comment Share on other sites More sharing options...
LSP_Ray Posted June 5, 2016 Share Posted June 5, 2016 Doesn't explain it, but I think the link tells you what the diameter should be: 10 inches, or 0.3125in/8.17mm in 1/32nd scale. What do the Fly wheels measure? And the width of the tire should be 1/4"/6.35mm quang 1 Link to comment Share on other sites More sharing options...
phasephantomphixer Posted June 5, 2016 Share Posted June 5, 2016 When a friend had me cast the Balloon looking tire/wheel assy. from the 1/24 Trumpeter kit (He hates kit rubber), they dwarfed any of the Airfix in the same scale. I just figured the Mk.II had larger tires due to heavier armament and tropical/Desert use. Link to comment Share on other sites More sharing options...
quang Posted June 5, 2016 Author Share Posted June 5, 2016 Doesn't explain it, but I think the link tells you what the diameter should be: 10 inches, or 0.3125in/8.17mm in 1/32nd scale. What do the Fly wheels measure? And the width of the tire should be 1/4"/6.35mm Hello Ray, The diameter of the FLY wheel is 21,20mm (quoted measure of the link: 8,17mm ). Thickness of the FLY tire : 6,50mm (quoted measure: 6,35mm). Anyhow, there's something fishy with the measures on the link: 8,17mm x 6,50mm Link to comment Share on other sites More sharing options...
Chek Posted June 5, 2016 Share Posted June 5, 2016 (edited) As far as I understand, the hub width diameter is 10 or 10.25 inches (two hub rim types), and the wheel diameter 25.4 inches/8 inch width at 35 psi, with a max of 26.0 inches/8.01 inch width at 45 psi. (Edgar Brooks notes ref 4 spoke wheel AH10019 - Hurricane II manual also fitted to Spitfires from 1944) What the 16 refers to in the illustration I'm not sure. And I believe a lot of wheel swapping with block tread Spitfire wheels still goes on in the warbird community. Edited June 5, 2016 by Chek quang and Martinnfb 2 Link to comment Share on other sites More sharing options...
LSP_Ray Posted June 5, 2016 Share Posted June 5, 2016 Hello Ray, The diameter of the FLY wheel is 21,20mm (quoted measure of the link: 8,17mm ). Thickness of the FLY tire : 6,50mm (quoted measure: 6,35mm). Anyhow, there's something fishy with the measures on the link: 8,17mm x 6,50mm I am guessing the 21.20mm measurement is the outer dimension of the tire? The metal wheel rim/hub should be 8.17mm. quang 1 Link to comment Share on other sites More sharing options...
quang Posted June 5, 2016 Author Share Posted June 5, 2016 Hello Ray, Outer dimension of the tire : 21.20mm. Metal hub diameter: 9.3mm (and I thought it was too small!). In fact they tried to reproduce the wheel on the left picture of chek's post albeit a tad oversized. Thank you gents, for your input. Regards, Quang Link to comment Share on other sites More sharing options...
Chek Posted June 5, 2016 Share Posted June 5, 2016 It'll likely look much better once the hub is painted Q. The measurements may be a bit fluid, as they may well refer to tyre bead diameter, and the hub would overlap that slightly - just as the wire reinforced bead on a car tyre has to be levered over the hub. (Why are these things never straightforward and explicit. Don't they realise what modellers have to do?). nmayhew 1 Link to comment Share on other sites More sharing options...
