jmreed76 Posted August 7, 2015 Share Posted August 7, 2015 Hi guys, Started this project awhile back. I'm using the Tamiya C/J kit as the basis. my subject aircraft is a Block 30 with the NSI "smallmouth intake" the model will be built inflight packing a full load out from its deployment back in 2001 Flying out of Incirlik AB, Turkey in support of Operation Northern Watch Youngtiger1, andromeda673 and ghatherly 3 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 7, 2015 Author Share Posted August 7, 2015 Work began attaching the top toward and aft fuselage sections. I used the screw provided by Tamiya but also used the method that I do when I build the Viper in 48th scale. By drilling the holes, I can add Tamiya extra thin in small amounts until I get the top join perfect andromeda673, Youngtiger1 and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 7, 2015 Author Share Posted August 7, 2015 Begining the intake trunk assy. For a seamless trunk. I normally start with the bottom section of the intake trunk, glue the aft and foward section together and repeat for the top section of the trunk. Clean up the seams and glue the top and bottom sections together fill the seams on the inside of the trunk with Mr. surfacer 500. Once all of the seams have been cleaned up, the intake trunk assy is ready for a dip in paint Girlscanplay2 and jgrease 2 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 7, 2015 Author Share Posted August 7, 2015 Cleaned up and ready for a latex paint pour, Girlscanplay2 and Youngtiger1 2 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 7, 2015 Author Share Posted August 7, 2015 It took seven attempts to get it right but, finally...success! Youngtiger1, Girlscanplay2, jgrease and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted August 8, 2015 Share Posted August 8, 2015 Nice work, Mike! Kev Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 Moving on, My subject has the stiffener plates added to the fuselage and the wings. Awhile back I used a set of the Crossdelta scab plates by themselves and found out that they were way under scale so, I added Vinyl copies of the Photo etch plates first and applied the PE Crossdelta over top of the vinyl. By doing this it really helped with the scale effect! After stacking the plates, I noticed that there was a gap between the vinyl and actual PE scab plate...Err! After several attempts using Mr. Surfacer and a Q-Tip dipped in thinner trying fill the gap, I gave up and had to figure something else out! So, I broke out some Milliput. Don't have much experience using the stuff but, To my surprise it worked really well! Here you can clearly see the gap after the Milliput was applied After a coat of primer, Success! andromeda673, Youngtiger1 and Girlscanplay2 3 Link to comment Share on other sites More sharing options...
Juggernut Posted August 8, 2015 Share Posted August 8, 2015 I was going to do a block 30 aggressor but I won't live long enough to get around to it (read as I had WAY too many models, not that I'm old or in ill health) but my subject had the MCID intake. I'm curious; it looks as though you've gotten the NSI intake from the Thunderbird aircraft kit. Did you also source the lightweight gear and main gear bays without the prebulge? Another question if I may... If you can comment on it, does that latex pour stay put or does it tend to lift/separate over time? I tried to do the same thing when I was a kid (too long ago to mention) and although the initial results were nice, the latex paint began to pull away from the plastic after a few years. Again, that was more than 30 years ago so latex paint technology most probably has evolved since and may not be an issue any longer. Nice start by the way. I always like watching peeps build these hair dryers.... Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 Thanks Kevin! Since I'm building this jet inflight, I just decided to use the kit's cockpit. I added Eduard's color photo etch to the IP. And just painted the side consoles by hand. It's still a Work in Progress but, it's coming along! Made a lense out of clear sprue and added a piece of colored confetti to the combiner glass. Not really to scale but, I really like the look of it! Besides, once the HUD glass is in place chances are, it'll hide the lense! Zero77, Girlscanplay2 and andromeda673 3 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 Juggernut, The NSI intake is from the 32nd T-Bird kit, awhile back I contacted Tamiya USA and was able to purchase five complete intake sprues!....Glad I did cause now the kit is out of production. Lucky enough, the Non bulged doors are included on that same sprue! Regarding the latex paint, I found that Glidden High Endurance works best! andromeda673 1 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 I haven't had any issues with the latex lifting/separating but, I go a step further. After the intake has been dipped in latex, I also give the intake a dip in Future. I feel that this will help in sealing the paint. Since I've been doing this, I've no issues! In case some are wondering, the label has changed again for this stuff! andromeda673 1 Link to comment Share on other sites More sharing options...
Juggernut Posted August 8, 2015 Share Posted August 8, 2015 Hey thanks for that information. If I ever decide to build another hair dryer (which I might) I'll definitely consider using the latex method of that smooth, white finish inside the intakes. Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 the mount for posing the model inflight, nothing neat about this work! But, I'm pretty sure there is enough 5 min. Epoxy there to hold it in place! andromeda673 1 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 Just a little mockup to show the pose! Work begins on the ACES II ejection seat, Not all that crazy about the seat having so much black on it but, my reference shots of the 181st show mainly black on the seat. If I were doing this open canopy, I would've made the cushions to resemble sheepskin. Being that there will be a pilot in seat I figured all of the added detail would be lost. Girlscanplay2, jgrease and andromeda673 3 Link to comment Share on other sites More sharing options...
jmreed76 Posted August 8, 2015 Author Share Posted August 8, 2015 I'm at a little standstill at the moment awaiting some supplies still need to do some drybrushing on the seat, paint up the little details, gloss and apply the decals to the seat wash and flat coat but hopefully here soon I'll be able to close up the fuselage! Link to comment Share on other sites More sharing options...
