dennismcc Posted September 1, 2015 Share Posted September 1, 2015 (edited) I remember having some fun with the engine installation on mine, but it turned out well in the end, here's my build http://www.britmodeller.com/forums/index.php?/topic/60771-bloch-mb-152/ Cheers Dennis Edited September 1, 2015 by dennismcc Urs 1 Link to comment Share on other sites More sharing options...
Urs Posted September 1, 2015 Author Share Posted September 1, 2015 Nice built of your 152. As I noticed seems there some differnences to my kit as your fully resin capot d'moteur and the wheel bay made out of resine. Mine ist just made with injection moulding parts. Link to comment Share on other sites More sharing options...
waroff Posted September 1, 2015 Share Posted September 1, 2015 Anyway, the resin wheel bay is wrong also Urs 1 Link to comment Share on other sites More sharing options...
Urs Posted September 1, 2015 Author Share Posted September 1, 2015 thats why l'm curious for the release for your Breguet 690. Link to comment Share on other sites More sharing options...
waroff Posted September 1, 2015 Share Posted September 1, 2015 thats why l'm curious for the release for your Breguet 690. Me too!..... wheel wells détails there were three ribs only, and stiffeners. The cylinder strut goes through the ovoid hole in the first rib. Urs and Lars Befring 2 Link to comment Share on other sites More sharing options...
Nanook Posted September 1, 2015 Share Posted September 1, 2015 Looks great! Very nice work on this kit...I know it's been a bit of a struggle. Cheers, Lee Urs 1 Link to comment Share on other sites More sharing options...
Urs Posted September 2, 2015 Author Share Posted September 2, 2015 @Waroff, do you have some close shots of the small 7.5mm gun, where exactly ist placed in the wing? Link to comment Share on other sites More sharing options...
waroff Posted September 2, 2015 Share Posted September 2, 2015 the ejection chute are blue, in red: Holes to allow to pass the ammunition drums and gear boxes of machin guns. Sometimes these holes receive a convex fairing. the distance between 20mm and 7.5mm is near 14mm (1/32) http://lapatrouillesimple.forumgratuit.org/t545-bloch-151-ou-152-pourquoi-1-pourquoi-2 Lars Befring 1 Link to comment Share on other sites More sharing options...
Urs Posted September 2, 2015 Author Share Posted September 2, 2015 thats of big help, thanks, Waroff Link to comment Share on other sites More sharing options...
Urs Posted September 3, 2015 Author Share Posted September 3, 2015 After kit layout the engine cover is glued onto the fuselage on its chin air inlet and cowling flaps. As I decided to spread the flaps a little to compensate the misalignment of fuselage and engine cover the whole thing would hang on the chin inlet. I cut some styrene fingers to glue them to the firewall. The idea is to hold and fix the engine cover from inside. Everything just put together to check. Cylinders are just held by brass rods I drilled for easier handling while painting them. Thing I changed ist he CW-prop turned into a CCW-Prop. Seems everything is to to assemble that was – more or less. Lars Befring 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 3, 2015 Share Posted September 3, 2015 Nice work, Urs! Kev Link to comment Share on other sites More sharing options...
waroff Posted September 3, 2015 Share Posted September 3, 2015 I forgot, the hole of 7.5 machine gun in the LE is above the chord line airfoil. The barrel muzzle exceed a bit the LE Urs 1 Link to comment Share on other sites More sharing options...
Urs Posted September 6, 2015 Author Share Posted September 6, 2015 Guess which is the kit part?😂 Made some Hispano 404 from scratch out of 18Gauge canulas and 2mm brass tubes. Was tricky stuff to do just wirh my weal Dremel and no real milling tools.😆 waroff 1 Link to comment Share on other sites More sharing options...
Urs Posted September 9, 2015 Author Share Posted September 9, 2015 After some tries with results l was not satisfied with here the final position lights, landing lights and the 20mm Hispano 404 guns. After assembly of position light my impression was that they dominate the wing too much so l did smaller their appear with a sheet. The landing light is made of clear sprue of a Mustang l found in the grab box. l drilled the sprue out from its back side and glued a chrome disc from a Tamiya PE-sheet in it as a light reflector part. Pitot is also made of injector needles. [/u mywifehatesmodels and waroff 2 Link to comment Share on other sites More sharing options...
ClumsyDude Posted September 9, 2015 Share Posted September 9, 2015 Cannons and pitot look terrific Urs, really neat work. Jim Link to comment Share on other sites More sharing options...
