Guest Posted May 30, 2014 Share Posted May 30, 2014 I would of left it, but your work paid off. Looks much better. Good clean work !........Harv Link to comment Share on other sites More sharing options...
Lee White Posted May 30, 2014 Share Posted May 30, 2014 Very nice work! Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted June 1, 2014 Author Share Posted June 1, 2014 i dont want to be monotonus, but honestly i want to thank you all for your comments....this is your help & encourage to me for that project!! Mr David...your last phrase about the repairman ....is the unseen truth of the modelling....the magic of what we do!! I am now in the very difficult procedure to fill the gup between the wing and fuselage, and my effort is beyond of my skill and model experience!! I hope the result of this procedure will be ....acceptable!!!! Soon i will update with photos ps: dont hesitate... I need your bad comments...your creative and fixing comments....bad or good...this is the reason i exposing my work to this amazing site!!!! Philippos Link to comment Share on other sites More sharing options...
Azgaron Posted June 1, 2014 Share Posted June 1, 2014 Very nice work so far Philippos! HÃ¥kan Volture 1 Link to comment Share on other sites More sharing options...
Vitali Posted June 1, 2014 Share Posted June 1, 2014 Great save ! Well done my friend. Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted June 1, 2014 Author Share Posted June 1, 2014 Thanks mate!! Link to comment Share on other sites More sharing options...
Volture Posted June 5, 2014 Author Share Posted June 5, 2014 Hi to all of you, I present to you my progress of my effort to fix and fill the large gup of 1mm between the fuselage & wings!!I am trying hard to fix it with putty (gunze mr surfacer 1000). The problem is big for me i am trying to do all the best. Any advice is needed and wellcome!!!! ps -->i made test fit with the ailerons (last foto) Regards Philippos Link to comment Share on other sites More sharing options...
Guest Posted June 5, 2014 Share Posted June 5, 2014 Still cool ! Good work,,,,,,,,Harv Link to comment Share on other sites More sharing options...
Vitali Posted June 5, 2014 Share Posted June 5, 2014 I would run a very thin bead of thin superglue over the putty to seal it and then paint over it. Sand it with some sandpaper used wet, wrapped around something very flat. When the paint is all gone you have a nice flat surface. Don't worry the paint will keep the superglue from going really hard and you will be able to see your progress by the amount opf paint remaining. The paint will also show up any low lying spots. I hope that helps you solve your problem. Your build looks nice and your nearly there! Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted June 5, 2014 Author Share Posted June 5, 2014 I would run a very thin bead of thin superglue over the putty to seal it and then paint over it. Sand it with some sandpaper used wet, wrapped around something very flat. When the paint is all gone you have a nice flat surface. Don't worry the paint will keep the superglue from going really hard and you will be able to see your progress by the amount opf paint remaining. The paint will also show up any low lying spots. I hope that helps you solve your problem. Your build looks nice and your nearly there! Helps me a lot...i will try it! I am really thank you Vitaly...i ll do my best!!!! Link to comment Share on other sites More sharing options...
Volture Posted June 6, 2014 Author Share Posted June 6, 2014 Hi a minor-micro update of my effort!! Remain the cleannig of the wing Link to comment Share on other sites More sharing options...
Guest Posted June 6, 2014 Share Posted June 6, 2014 Great job !! I'm liking it quite a bit.....Harv Link to comment Share on other sites More sharing options...
LSP_Kevin Posted June 6, 2014 Share Posted June 6, 2014 Nice seam work Philippos! Kev Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted June 10, 2014 Author Share Posted June 10, 2014 Hi to all, This my little progrees on my project! In summury......17 parts in....2 photos!! Pylons and ailerons. Regards Philippos Girlscanplay2 1 Link to comment Share on other sites More sharing options...
Guest Posted June 10, 2014 Share Posted June 10, 2014 Looks good !........Harv Link to comment Share on other sites More sharing options...
