LSP_Kevin Posted May 8, 2014 Share Posted May 8, 2014 Both your English and your model are fine Philippos! But your model is definitely better... Kev Volture 1 Link to comment Share on other sites More sharing options...
Vitali Posted May 9, 2014 Share Posted May 9, 2014 (edited) Great job, you got all closed up! Coming along nicely. I have only just started on the engine on mine but I have closed up and sanded the outer gun panels off as the Sktraider I am doing only had the two 20mm guns. Trying to decide to go wtith wings up or down. Your english is fine. It took me many years to learn english correctly and it gets easier with time. Edited May 9, 2014 by Vitali Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted May 9, 2014 Author Share Posted May 9, 2014 Great job, you got all closed up! Coming along nicely. I have only just started on the engine on mine but I have closed up and sanded the outer gun panels off as the Sktraider I am doing only had the two 20mm guns. Trying to decide to go wtith wings up or down. Your english is fine. It took me many years to learn english correctly and it gets easier with time. Keep the good job you too mister, and thanks for your comments!! My decision is to do it with 2 guns per wings (is it 100% wrong??), and not folded wings!If you do the same thing, becarefull because a mate here warn me at the beginning of my thread for the dangerous fitting!!! (oh my ohh my…..i have to go to school again to learn English haha) Link to comment Share on other sites More sharing options...
Vitali Posted May 9, 2014 Share Posted May 9, 2014 Are you using the kit decals? If so that AD-4 I think had only 2 20mm guns in the wings also but I can check my photos if you like?. I am doing an early AD-4 and this machine only had the two 20mm guns. Here is a photo of the AD-4 I am building: http://www.johnfry.com/Media/BennettBobA.jpg VA-195 USS Princeton. Link to comment Share on other sites More sharing options...
Volture Posted May 9, 2014 Author Share Posted May 9, 2014 Yes i will use the kit decals. I have no reference at all for that (only random photos from the web ), and if you can check your photos you will help me a lot!!!!!!!!! Awesome photo, beautyfull!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
Vitali Posted May 9, 2014 Share Posted May 9, 2014 If you are building the Navy version with the tail code N -515, AD-4NA 127003 it should only have the two inner wing 20mm guns only. If you are building the Marine version with the tail code LX 132364 AD-4B it should have all 4 20mm guns. I hope that helps you out some. Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted May 9, 2014 Author Share Posted May 9, 2014 If you are building the Navy version with the tail code N -515, AD-4NA 127003 it should only have the two inner wing 20mm guns only. If you are building the Marine version with the tail code LX 132364 AD-4B it should have all 4 20mm guns. I hope that helps you out some. Well...the truth is that i like it with the 4 20mm guns...so i think i will do the marines version!! Help me some?...nah..It was awesome and critical info for me and help me a lot!! I am really thank you for your advice! Philippos Link to comment Share on other sites More sharing options...
Volture Posted May 19, 2014 Author Share Posted May 19, 2014 hi to all, Here i go again with an update of my effort to that beautifull and wild plane In summury : The four guns is painted and ready Test fit of the fuselage with the centre part of the wings Test fit of the cowl with the fuselage The gun bulges on the wings is ready I add platstic rulers on the wings to ensure the stability of the wing structure (not folded wings) I am trying hard to make this out, and its very difficult to me regards to all Link to comment Share on other sites More sharing options...
Vitali Posted May 19, 2014 Share Posted May 19, 2014 Nice work and it's good to see you have been busy! The wings are tricky but line up pretty well it's just a matter of holding them in the correct postion while you glue them. Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted May 19, 2014 Author Share Posted May 19, 2014 Nice work and it's good to see you have been busy! The wings are tricky but line up pretty well it's just a matter of holding them in the correct postion while you glue them. thanks mister...you are absolutely right...!! Link to comment Share on other sites More sharing options...
Volture Posted May 19, 2014 Author Share Posted May 19, 2014 i love this plane!!! Link to comment Share on other sites More sharing options...
Volture Posted May 20, 2014 Author Share Posted May 20, 2014 Hi, This is a small update of the progress that shows the work on the first half of the wings in one piece.I think the angle is right.What do you think? Daniel Leduc 1 Link to comment Share on other sites More sharing options...
David Hansen Posted May 21, 2014 Share Posted May 21, 2014 Looks good to me. Nice to see a Skyraider wing with some actual dihedral. PS: Actually, EVERYBODY expects the IPMS Inquisition, ha ha. Am following this build closely. The AD is not my favourite choice of subject but i've seen one of these completed so far and its a very impressive plane when finished and probably has less parts than a Trumpeter Avenger. david Volture 1 Link to comment Share on other sites More sharing options...
Volture Posted May 22, 2014 Author Share Posted May 22, 2014 Looks good to me. Nice to see a Skyraider wing with some actual dihedral. PS: Actually, EVERYBODY expects the IPMS Inquisition, ha ha. Am following this build closely. The AD is not my favourite choice of subject but i've seen one of these completed so far and its a very impressive plane when finished and probably has less parts than a Trumpeter Avenger. david Thanks a lot mr David, As about the IPMS Inquisition..you are absolutely right..EVERYBODY expects that....and then they will burn me like a bad heretic wizard!!!(not folded wings)hahahah Daniel Leduc 1 Link to comment Share on other sites More sharing options...
David Hansen Posted May 24, 2014 Share Posted May 24, 2014 Well, it could be worse. You could be building an Eduard BF-109G kit. Seriously though, the wing fix on the Skyraider looks good. Just promise me you will NOT put that stupid bumblebee on the tail. david Link to comment Share on other sites More sharing options...
