LSP_Kevin Posted May 12, 2012 Author Share Posted May 12, 2012 Thanks guys. Jerry Crandall confirmed the 'safe to leave them off' approach, so that's what I'll be doing. Kev Link to comment Share on other sites More sharing options...
Cpig Posted May 12, 2012 Share Posted May 12, 2012 Great looking model so far Kev. I like the oversprayed numbers, well done! Link to comment Share on other sites More sharing options...
LSP Dan Posted May 12, 2012 Share Posted May 12, 2012 Excellent job Kevin!! Link to comment Share on other sites More sharing options...
Daywalker Posted May 12, 2012 Share Posted May 12, 2012 I love the painted over numbers, well done Kev! I looked through my JV44 references as well, and couldn't find any on the aircraft. Glad you're leaving them off. Link to comment Share on other sites More sharing options...
LSP_Mike Posted May 12, 2012 Share Posted May 12, 2012 Kev, Thought I'd look in. Good stuff going on there, and I really like your paint. Focke-Wulf mania is hard to overcome sometimes,eh? Link to comment Share on other sites More sharing options...
Guest Posted May 12, 2012 Share Posted May 12, 2012 Wow Kev! That is coming out really nice. I like it! Well done. John Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 12, 2012 Author Share Posted May 12, 2012 Thanks fellas, your kind words are much appreciated - and highly motivational! The last remaining hurdle on this build is to get the main landing gear fitted, which is going to be a challenge for all sorts of reasons. I hope it goes better than it did on my ProModeler 1/48 build! Kev Link to comment Share on other sites More sharing options...
Daywalker Posted May 13, 2012 Share Posted May 13, 2012 What happened on the ProModeller 1/48 build? Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 13, 2012 Author Share Posted May 13, 2012 What happened on the ProModeller 1/48 build? The sloppy fit of the wheel bay part caused by aging moulds allowed me to install it at a slight angle, which totally destroyed any chances I had of getting the landing gear installed correctly. The outcome is obvious in the following photo: They're not just at different angles, but twisted in different directions too. It ruined an otherwise decent build. Next time I'll either build the Eduard D-11 kit or try converting the Tamiya D-9. To be honest, my main concern with this build is achieving adequate strength where the gear legs attach to the wheel bays. Kev Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 14, 2012 Author Share Posted May 14, 2012 So, I managed to get the holes drilled for installing the landing gear:I also managed to reduce and reshape the mounting pegs to fit my new holes:Best of all, I triumphed over success and drilled through the port wing: Kev Link to comment Share on other sites More sharing options...
Kahunaminor Posted May 14, 2012 Share Posted May 14, 2012 Oh the pain...the pain! (in my best Zachary Smith voice with all due respect to Jonathon Harris!) Regards Link to comment Share on other sites More sharing options...
Out2gtcha Posted May 14, 2012 Share Posted May 14, 2012 Its a "magic BB" from ground fire Kev............ Its all part of the fun of modeling............... Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 14, 2012 Author Share Posted May 14, 2012 Its a "magic BB" from ground fire Kev............ Ha! Now that's funny... Repairs are currently in progress. I put a piece of tape over the wound and used a steel ruler to mash down the raised plastic. Then I taped off the area and gave it a going over with with a skinny sanding sponge (available from Flory Models). This left a small crater that looked remarkably like an acne scar, which I filled with a blob of Mr Surfacer. I'll sand that back next modelling session. Kev Link to comment Share on other sites More sharing options...
Daywalker Posted May 15, 2012 Share Posted May 15, 2012 OUCH!!! I did the same thing on a Tamiya 1/48 FW-190 kit. Sounds like you have everything under control! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted May 20, 2012 Author Share Posted May 20, 2012 OK folks, wing puncture dealt with:Clear coats will take care of the noticeable difference in the new and old paint layers. I also managed to get the outside faces of the main gear doors painted:I initially thought that these parts Jerry sent me were copies of the new-tool Hasegawa kit parts, but a direct comparison reveals that they are not:The upper section has an obviously different shape, and the lower section is larger, and with a subtly different shape. I'm guessing that these were designed for a Ta 152, rather than a Dora, but I wasn't aware that they sported differently shaped landing gear doors (and ergo, differently shaped wheel bay openings).As usual, very slow progress!Kev Link to comment Share on other sites More sharing options...
