Shawn M Posted July 25, 2010 Posted July 25, 2010 (edited) OK, since Im taking a looong break from my Bf-110 build I figured I'd show my progress on my latest endeavor. No aftermarket, no cockpit, no engine. Im spending the effort to detail the land gear and their bays so when I get back to the BF-110...Im not learning from the start. So far I've opened up the pilots foot step in the fuse, not pictured is the sheet alum. door itself that will be attached. On either side of the nose I opened up the wing support strut access doors, also made alum. doors for here but they're not pictured. I realized after I spent all the time that I made the shape upside down oh well, they'll be behind the wings and are better then the molded dimple revell gave me. Next I attacked the rear landing gear and bay. If you're at all familiar with this kit you'll notice whats been added. If you're not familiar, assume what you see has been added. This is the first coat of paint only, second coat, pin washes and weathering to go. Finished Pics on last page. Edited January 1, 2011 by Shawn M
Neo Posted July 26, 2010 Posted July 26, 2010 Goood work on the tail gear i build one of these kit for my dad bday this year it came out OK i guess but mine was casted the kinda greenish gray plastic witch was so hold and didnt react too good to the glue. Actually the wing hinges broke and and to fix them (the one up si glued with PL premium construction glue) Can be seen here Good luck Cheers Neo
Shawn M Posted July 26, 2010 Author Posted July 26, 2010 thanks gang! Im going to try my hand at tarps to cover the canopy and motor. Next up is finish painting, wiring (basic) then closing up the fuse. After that its main gear bays and (gasp) wing fold details.
Shawn M Posted July 29, 2010 Author Posted July 29, 2010 slowly building up the flight surfaces and stabilizers. Started work on the wheels..they really suck...no tread, crap detail...oh well. Since Im doing some research on it, Im also having to fill the foot step in the flaps so i got a start on that last night as well. Not having to build,paint and detail the motor/cockpit will help. But man o man, the wing roots where the fold/flap mechanism is will take some time.
Shawn M Posted August 1, 2010 Author Posted August 1, 2010 Update: tail gear bay is done, time to join the fuse halves. Started detailing main gear wheels.
Shawn M Posted August 1, 2010 Author Posted August 1, 2010 Joined the fuse halves, made the engine block off plate/prop shaft holder, added valve stems to the wheels.. Time to start the grill and relax
Allok Posted August 2, 2010 Posted August 2, 2010 There's nothing like chopping up and old Revell Corsair. Lots of lovely scratch details you're adding there, Shawn. Keep up the good work.
Shawn M Posted August 2, 2010 Author Posted August 2, 2010 Thanks Keith! I started sanding the seams after dinner last night. managed to knock of an aerial and part of the tail wheel fork I blame the beer.
Shawn M Posted August 9, 2010 Author Posted August 9, 2010 Fuse is joined, puttied and sanded. Im working on the wings and root ribs right now..may need to build these from scratch Added and sanded the canopy. Still sealing up the vertical and horizontal stabs. Filled some holes in the center wing section, drilled out the carb blow out vents and backed them so I can add some brass tube. Cut out the exhaust port opening and backed it with some tube for depth, still need to add exhaust pipes. Pics to come.
Shawn M Posted August 10, 2010 Author Posted August 10, 2010 Made new oil cooler/intercooler duct doors last night out of a soda can. Look WAY better then the molded closed plastic ridges. Did some more research and found the aircraft I am building didn't have the antenna masts the kit did. Off they came. Glued some PE onto the oil cooler faces and mounted the parts in the wings.
Shawn M Posted August 11, 2010 Author Posted August 11, 2010 Today I bring pictures. The only progress not shown here is the horizontal stabs are now on the fuse. I started boxing in the gear bays as well, but thats not very exciting to see.
timvkampen Posted August 11, 2010 Posted August 11, 2010 This must be a rewarding project!! Nice scratchbuilding work
Shawn M Posted August 11, 2010 Author Posted August 11, 2010 Thank you!! Its a learning process, every build I try to do/learn something new. This build is landing gear and tarps. It'll be great when its done!
