vvwse4 Posted August 7, 2010 Author Share Posted August 7, 2010 Things are getting their shape right now. This is only a mock up ( is this correct English??? ), not everything is in it's correct place but it gives a general idea of how it will look. Vieuw from above The bent props and antenna under the nose. The port prop is feathered so that is why only one blade is curved, the starboard prop was runing when hitting the ground. I hope it is a little bit convincing. The reason why the plane never made it back to base. I did not made too many holes in the wing but I want to give the impression that it caused the port engine too stop runing, mayby catch fire. I asked a question in the discussion forum about how the antenna wires are attached too the tail, and while I am at it I am not quite sure how it was attached to the canopy also. Anyone ??? Rick. Link to comment Share on other sites More sharing options...
WrongWay Posted August 7, 2010 Share Posted August 7, 2010 Wow! That looks amazing. I'll be watching this one. Link to comment Share on other sites More sharing options...
Guest Nigelr32 Posted August 7, 2010 Share Posted August 7, 2010 Wow! That looks amazing. I'll be watching this one. No one else has answered you on the primer question so i thought I'd add some advice. Every US aircraft I've seen that's not been restored has shown signs of Zinc Chromate coloured primer where worn scratched. I'm not sure if EVERY panel or indeed EVERY plane was primed, but it's ust what I've noticed. I guess you could look up some restoration pics from the now flying example. Was it the Warbirds museum in the US that did that one?? I believe that plane was green when they found it, buried in Ice?? Looks like this is gonna be a beautiful model when finished. Link to comment Share on other sites More sharing options...
JRutman Posted August 7, 2010 Share Posted August 7, 2010 Really like this build J Link to comment Share on other sites More sharing options...
LSP_Ron Posted August 8, 2010 Share Posted August 8, 2010 Great props! I really like them A word of caution, careful with the black felt pen your using to mark areas. They tend to bleed through paint regardless of paint type used. I'd suggest switching to pencil. Ron Link to comment Share on other sites More sharing options...
vvwse4 Posted August 8, 2010 Author Share Posted August 8, 2010 Whiped the black marker off, thanks Ron!, and gave it a coat of aluminium. Guess every plane in those days started as a sheet of alu so that will be my first coat. I used Humbrol # 11. Came out quite nice. Leave it to dry now for a couple of days so I can make my next move, zinq chromate yellow of straight OD/NG. Hope you like it. Rick. Link to comment Share on other sites More sharing options...
Texas Posted August 8, 2010 Share Posted August 8, 2010 Really starting to look the part......Great job your doing.... Texas Link to comment Share on other sites More sharing options...
vvwse4 Posted August 9, 2010 Author Share Posted August 9, 2010 Put the primer on, zink chromate type yellow. Also added salt for the chipping, I think I overdone that a little bit but I can always remove some of the salt. Rick. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 9, 2010 Author Share Posted August 9, 2010 WOW Rick! This is looking very good. Great job so far. One little point I want to make, the cutouts on the inner booms, they are for the "mirrors" for landing gear sighting. And they should be oval, not round. Just wanted to point that out. The rest is fantastic. Cant wait to see the salt gone!.....Harv Hi Harv, You're absolutely right about the mirrors. Wonder why Trumpeteer made it round? It was a piece of high polished aluminium right? I think I can make that from a piece of beercan. Thanks, Rick. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 11, 2010 Author Share Posted August 11, 2010 Made some real progress today!! First things first, preshade, like that technique so why not use it. After that OD over NG. Been using quite a lot of yellow in the OD and white in the NG to get various tinges in the clours, just to prevent it from being one big green and gray piece. And offcourse I coul'n't wait to get rid of the salt. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 11, 2010 Author Share Posted August 11, 2010 part 2 It will turn out a bit darker after some future is put on it. Just when I figured not bad I thought about the stars and bars, serial and other codes on the plane. Never thought about those.. So got too figure that out, cannot put brand new markings on a very weathered plane. Hope you like it a bit. Rick. Link to comment Share on other sites More sharing options...
Shawn M Posted August 11, 2010 Share Posted August 11, 2010 LOVE IT! Quick question. You laid down the primer, then silver, then OD. Did you re-salt between the silver and od? I love the exposed primer and silver you achieved and want the same effect on my corsair. EDIT: NM unless my eyes deceive me. It looks like you did re-salt between them. Link to comment Share on other sites More sharing options...
vvwse4 Posted August 11, 2010 Author Share Posted August 11, 2010 LOVE IT! Quick question. You laid down the primer, then silver, then OD. Did you re-salt between the silver and od? I love the exposed primer and silver you achieved and want the same effect on my corsair. EDIT: NM unless my eyes deceive me. It looks like you did re-salt between them. Thanks Shawn, I did silver, Humbrol 11, then salt, then primer, redid the salt so the silver and primer are mixed, then the preshade, OD over NG and after that got rid of the salt. Easy. Rick. Link to comment Share on other sites More sharing options...
Shawn M Posted August 11, 2010 Share Posted August 11, 2010 Thanks Rick! Appreciate the explanation. Link to comment Share on other sites More sharing options...
jeroenpeters Posted August 11, 2010 Share Posted August 11, 2010 Hi Rick, That looks pretty realistic. I guess it's more difficult to make a plane look bad than good, but you're nailing it! And eh... that's a compliment Cheers, (see you friday) Jeroen Link to comment Share on other sites More sharing options...
