Hacker Posted April 8, 2010 Share Posted April 8, 2010 Link to comment Share on other sites More sharing options...
LSP_Paul Posted April 8, 2010 Share Posted April 8, 2010 Now that's a cool little Fokker right there! Some day when that Fokker is done its gonna be the best Fokker on the shelf at your house! I've been meaning to get me one of those Fokkers myself! OK enough with the fokker jokes..Seriously, Nice work on the frame cant wait to see more! ok one more... If you took it to a contest and others like it were present.. they could have thier own catagory at the event called "meet the Fokkers!" Paul Link to comment Share on other sites More sharing options...
Hacker Posted April 8, 2010 Author Share Posted April 8, 2010 My whole aim here is to do the right side exposed and do the other side covered and or painted (depending where the build takes me. Link to comment Share on other sites More sharing options...
LSP_Paul Posted April 8, 2010 Share Posted April 8, 2010 Hacker, Lining up all that rod or tube plastic has to have been a to be a pain in the butt but you seem to have it all squared up and straight! Looks great! I have had to do a few tube frame type projects on large scale model ships and they about drove me off the deep end.. I ended up making a jig to hold it all while I carefully glued things. Keep goin cant wait to see what she turns into! Paul Link to comment Share on other sites More sharing options...
LSP_Ron Posted April 9, 2010 Share Posted April 9, 2010 That's some fine scratch work. Looks to be very straight and true. Link to comment Share on other sites More sharing options...
Hacker Posted April 11, 2010 Author Share Posted April 11, 2010 Well progress has been slow due to other matters that need my attention. So far here is what l have done l have cut the right upper wing off at the third rib from the center in preparation for building the wing structure in its place At the same time l cut of the right lower wing off as well for the same treatment later here is how far l have gotten so far with it l also cut off the right side of the horizontal stabilizer and build the structure for it as well as a new rudder and vertical stabilizer The wings will be the most hardest part as there is a lot of trail and error with this as each rib is different even though the width remains constant that is all for now have to get back at it soon. Link to comment Share on other sites More sharing options...
Shawn M Posted April 12, 2010 Share Posted April 12, 2010 Wow.... Link to comment Share on other sites More sharing options...
Spads57 Posted April 29, 2010 Share Posted April 29, 2010 So Hacker how's the Fokker coming along? Link to comment Share on other sites More sharing options...
Hacker Posted May 7, 2010 Author Share Posted May 7, 2010 So Hacker how's the Fokker coming along? Well between working and a dying from a nasty cold l managed to get some work done on the Fokker. My computer is not too good at the moment and is destined to be replaced but l will try to show you what l have been doing l managed to get the upper wings done they just need some tweaking to finish them off l also using the same construction methods to build the lower wings using the lower part of the landing gear l attached the struts to the fuselage the final work done was to attach the fuselage struts for the upper wing. and so this is where it stands at the moment. l just have to make the right aileron for the upper wing and we can start dong some painting. The first paint to go on will be primer to check for errors and blimishes and correct them before l apply the aluminum paint and the wood colors on it. well that is all for now later Link to comment Share on other sites More sharing options...
bcauchi Posted May 7, 2010 Share Posted May 7, 2010 Brilliant work, looking really nice!! Link to comment Share on other sites More sharing options...
LSP_Paul Posted May 7, 2010 Share Posted May 7, 2010 I was wondering what happend to this project! I cant wait to see some paint on that Fokker! Looking way to cool!, Im glad to see you didnt give up and very impressed with what youve acomplished so far. Keep up the Fanstastic work! Paul Link to comment Share on other sites More sharing options...
LSP_K2 Posted May 7, 2010 Share Posted May 7, 2010 My whole aim here is to do the right side exposed and do the other side covered and or painted (depending where the build takes me. So you have not yet picked a scheme? Link to comment Share on other sites More sharing options...
LSP_Ron Posted May 7, 2010 Share Posted May 7, 2010 Some real tedious work there. looks really good Link to comment Share on other sites More sharing options...
Hacker Posted May 7, 2010 Author Share Posted May 7, 2010 So you have not yet picked a scheme? l was going to do just a generic factory scheme. The plane would be as if it had not yet been assigned to a squadron Link to comment Share on other sites More sharing options...
Spads57 Posted May 7, 2010 Share Posted May 7, 2010 Hacker, Amazing work my friend.Looks as if the bad cold hasn't dulled your talent in the least.Keep us updated as to your progress. Regards, Gregory Jouette Link to comment Share on other sites More sharing options...
