Hacker Posted September 5, 2010 Author Share Posted September 5, 2010 Looking real good Hacker. I'd paint ignition wires, as they seemed to be black on the original. As to the brass plumbing, I'd paint it also.. Taking typhoon's advice l painted the wires black and for constrast l painted the plumbing gunship grey in order to install the engine l had to cut off the one side of the cowling. l wanted to modify it anyways. Ok here we go HOLY COW BATMAN IT FITS!!!!! That is all for now gang time for a beer and relax later Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 5, 2010 Share Posted September 5, 2010 This is looking so good. I'm trying to wrap up a 1:72 scale version of the D.VII at this time myself, hopefully to be finished by next Saturday. I'd post a pic, but I'm not sure that's appropriate. Link to comment Share on other sites More sharing options...
Hacker Posted September 6, 2010 Author Share Posted September 6, 2010 Thanks for the good words As l move along with finishing off the cockpit details l realize soon l will have to start covering the left side,upper and lower fuselage. The upper is no brainier here as it already half done but the left side and the lower fuselage represents a challenge. One idea is to use the thinnest sheet plastic available to me which would be 5 thou. it is thin enough to let some light through but thick enough not to let too much through. The trick would be to decal both sides. One with the same decal l used on the wings and another decal that is reversed and faded to represent the bleed through of the inks to the other side. The other trick would be to make sure the patterns line up on both sides as any that is out of lineament would should show if light was shone on the decaled plastic. I would be interested in any comments that you should have on this later Link to comment Share on other sites More sharing options...
Dave Pratt Posted September 7, 2010 Share Posted September 7, 2010 Dave,very nice work sir,very nice... Link to comment Share on other sites More sharing options...
LSP_Ron Posted September 7, 2010 Share Posted September 7, 2010 I wonder how well a light tan tissue applied with thinned white glue would work? maybe the tissue used in the old balsa free flight kits (I used to build in the 70's) or tissue used for gifting will work also. Apply in panels (left side, bottom using thinned white glue around the boarders, let dry then mist with water to tighten. Then seal with a water proof clear finish and apply the decal lozenge just to the outside. It would show through into the inside. If it doesn't look good after applying with white glue it can be removed pretty easily. Just an idea Link to comment Share on other sites More sharing options...
LSP_K2 Posted September 7, 2010 Share Posted September 7, 2010 Depending on the opacity of the decal film, it just might behave the way the original fabric did, showing the reversed, lighter lozenge on the interior. If you use .005 thickness clear sheet underneath decal, and on top of frame (held in place with Elmer's or equivalent), you'd kill two birds with one stone; structural rigidity, and avoiding the use of two decals matching one another. Link to comment Share on other sites More sharing options...
