Christian Posted February 11, 2012 Share Posted February 11, 2012 Hi Cees, Looks fuselage looks great. Nice to see the dry fit has come out so well. What is your next part of this build? Christian PS thanks for the tells us what used to make the sit. Link to comment Share on other sites More sharing options...
Cees Broere Posted February 11, 2012 Author Share Posted February 11, 2012 Christian, Well, fitting out the interior and those dreaded bombcells. Something I am not looking forward to, but I will have to make them to be able to close the fuselage. Today I bought some albion brass tubing that will be used as the rigging cables in the fuselage, the stretched sprue routine didn't work. i might be tempted to make the centre section wings and tail surfaces in between to keep my sanity. Cees Link to comment Share on other sites More sharing options...
Ripaman Posted February 12, 2012 Share Posted February 12, 2012 Hi Cees, have been watching your WIP and just wanted to say what brilliant workmanship, the attention to detail is second to none. Will be looking forward to your next post Regards Richard Link to comment Share on other sites More sharing options...
Cees Broere Posted February 12, 2012 Author Share Posted February 12, 2012 Thanks Richard, This build is really sucking me into some more progress. I fitted the rudder pedals. Fit was a bit tight so the pedals are displaced a bit to the right and as a result the rudders will be off set, giving a bit more "life" in the tail. The compass shelf has been fitted above the rudder pedals. Earlier this afternoon I had sprayed the albion tubing black. I couldn't wait and fitted some panels already after which the boards on top of which wiring will be fitted. Next will be the control wheel and column assembly hopefully soon. The seat has already been finished and will have Eduard seat belts to top it off. Am I enjoying this? Man, that's the understatement of the year. Hope you like the progress Cees Link to comment Share on other sites More sharing options...
jeroenpeters Posted February 12, 2012 Share Posted February 12, 2012 Hi Cees, It's getting cosier in there by the day!! Safe me a window seat! The bomb cells will really make it busy in there. Great work my friend! Cheers, Jeroen Link to comment Share on other sites More sharing options...
Cees Broere Posted February 19, 2012 Author Share Posted February 19, 2012 Ok some more progress, The fuselage rigging cables are finished, the control column and wheel is now fitted, as is the seat. This has an Eduard set of seat belts fitted which gives it a better look. Apart from some details the cockpit is almost finished. The instrument panel will be fitted later as part of the top decking of the front fuselage. Not sure yet to make the top decking from very thin plasticard I got from jeroen, or use soda can aluminium, as it will have some structural details scribed into it to give that stretched linen look, still thinking about that. Both top and bottom fuselage pieces have been temporarily fitted with some tape to see if they fit (they do, yeey) and the top one will be shortened a bit to enable the fitting of the aft tail decking to have more glueing area. Everything so far is dry fitted. The dreaded bombcells are approaching..... Hope you like it so far. Cees Link to comment Share on other sites More sharing options...
jeroenpeters Posted February 19, 2012 Share Posted February 19, 2012 I'm lovin it Cees! The different shades of wood really bing it to life! Nice. Very nice! Link to comment Share on other sites More sharing options...
Hogzilla Posted February 19, 2012 Share Posted February 19, 2012 Cees, I really enjoy your scratch-build project. Always such clean workmanship on the fuselage assembly and painting, keep up the good work! Remember: patience + persistence = progress Link to comment Share on other sites More sharing options...
Thomas Lund Posted February 19, 2012 Share Posted February 19, 2012 Fantastic - I had to go back to earlier in the post to check that I remembered correctly - that thing was built in sheet styrene. That 'wood' looks absolutely stunning - looks like it was built from wood strips... Amazing effort Link to comment Share on other sites More sharing options...
Cees Broere Posted February 21, 2012 Author Share Posted February 21, 2012 (edited) Thanks chaps, Not bad for a first time I think...... But that shows that sometimes you have to experiment to see if an idea works. I wasn't sure about the oil into paint thing that everybody seems to be doing. This is just plain drybrushing and slushing paint all over a cleanly drybrushed interior (causing much horror). Hey Jeroen!, I saved you that window seat, I had to make it first though. Cees Edited February 21, 2012 by Cees Broere Link to comment Share on other sites More sharing options...
Christian Posted February 21, 2012 Share Posted February 21, 2012 Dear Cees, The internior looks fantastic, so much detail. Keep up the great job. Christian Link to comment Share on other sites More sharing options...
A.Wolf Grant Posted February 21, 2012 Share Posted February 21, 2012 Phenomenal work Cees, just make sure Jeroen's seat is right at the back by the galley Grant. Link to comment Share on other sites More sharing options...
Marek Posted February 21, 2012 Share Posted February 21, 2012 With Christian and Grant here Link to comment Share on other sites More sharing options...
Cees Broere Posted February 23, 2012 Author Share Posted February 23, 2012 Jeroen, Your seat has been painted and dryfitted. Smoking or non-smoking Next seatbelts... Cees HerculesPA_2 1 Link to comment Share on other sites More sharing options...
jeroenpeters Posted February 23, 2012 Share Posted February 23, 2012 Jeroen, Your seat has been painted and dryfitted. Smoking or non-smoking Next seatbelts... Cees Woohooo! Great! Why are my magazine pouches empty?? I need ammo! Link to comment Share on other sites More sharing options...
