CANicoll Posted January 22, 2017 Share Posted January 22, 2017 More building to support the WWI anniversary. Beginning to love these 1/72 kits as they are quick builds and I like the wide range of colors to play with. I am a LITTLE over the top on the colors but hey, why not! I'm already pretty well started but here is the update. Fuselage decals tomorrow I hope. These are fun kits. Chris LSP_K2, Vandy 1 VX 4, Joe66 and 1 other 4 Link to comment Share on other sites More sharing options...
spacewolf Posted January 22, 2017 Share Posted January 22, 2017 Looks very good ! Vaughn CANicoll 1 Link to comment Share on other sites More sharing options...
CANicoll Posted January 22, 2017 Author Share Posted January 22, 2017 Vaughn, Thanks! Link to comment Share on other sites More sharing options...
Joe66 Posted January 22, 2017 Share Posted January 22, 2017 Looking really good ! Many years ago I used to build a bunch of these 1/72 WWI a/c....they are fun and allow for all those wild paint schemes to be done for less $$ and less shelf space ! Joe CANicoll 1 Link to comment Share on other sites More sharing options...
CANicoll Posted January 22, 2017 Author Share Posted January 22, 2017 (edited) Having some fit issues which are probably my own doing - due to a lack of familiarity with the planes and the kits and what to be looking out for. Oh well, its a learning experience! Here are the multi-part decals: And on the plane (but I'm not showing you the other side! It a 'little' off. Still fun, but the rear elevators are mis aligned to the front wing. The connection is far too strong for me to try and separate. Oh well! Pictures later. Chris Edited January 22, 2017 by CANicoll Zero77 and Shawn M 2 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 22, 2017 Share Posted January 22, 2017 Chris Geez, I never saw this beauty coming. Looking really good Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Joe66 Posted January 22, 2017 Share Posted January 22, 2017 Even in 1/72 scale, I find that making an alignment jig is quite useful. Joe CANicoll 1 Link to comment Share on other sites More sharing options...
CANicoll Posted January 23, 2017 Author Share Posted January 23, 2017 Even in 1/72 scale, I find that making an alignment jig is quite useful. Joe Joe, You know, I've rarely had the need for one, so it did not even cross my mind. This is only the second WWI plane I've made and the first was a Revell 1:28 Triplane and despite its age, it was a straight forward build. THIS I should have known about. Lesson learned. Next time I'll tack on the lower wing then set the elevators and rudder if nothing else. I do like these little kits I must say.. Plus they are pretty cheap. Joe66 1 Link to comment Share on other sites More sharing options...
Javlin1 Posted January 26, 2017 Share Posted January 26, 2017 Nice!! Link to comment Share on other sites More sharing options...
Joe66 Posted January 26, 2017 Share Posted January 26, 2017 I don't always use a jig, but with some of the old kits I have run into some warpage problems, and a jig certainly is useful in straightening out those issues. Especially when you start going to longer wing/multi-strut bombers. I also use CA glue most of the time, so by setting everything up with a jig, you know it is right and once you apply the glue, there is little time for "tweaking"... Another method I use a lot (mainly because I like to scratchbuild ) is small brass rod locating pins. Even for kits, I will often cut off the molded pins, drill holes exactly where they need to be and insert small brass pins. Then I can dry fit the pieces and know they are right before applying glue. One benefit I have found with biplanes, is that once they are rigged they are quite strong ! Joe CANicoll 1 Link to comment Share on other sites More sharing options...
CANicoll Posted January 27, 2017 Author Share Posted January 27, 2017 Joe, So it vexed me so much I worked the tail to come off and reset it. Funny thing is that I usually use CA for things like that but I didn't this time and I was able to work it free undamaged. Whew! Actually, as you pointed out, the fuselage is warped just a bit but it is far less noticeable now than it was. Lesson learned for next time! Working on the Revell Spad XIII right. Whole different level of things to deal with! Chris Link to comment Share on other sites More sharing options...
CANicoll Posted January 28, 2017 Author Share Posted January 28, 2017 Just about finished. Have a few detail items to paint on the fuselage mostly (and that I had completely forgotten about). I just had no way of doing even the limited rigging on this plane, so small! Fun build! But I need to really get better at doing WWI 1/72 planes. So freaking small!! But I love the colors. Chris Link to comment Share on other sites More sharing options...
LSP_Kevin Posted January 28, 2017 Share Posted January 28, 2017 Nice work, Chris. Kev CANicoll 1 Link to comment Share on other sites More sharing options...
