dennismcc Posted November 19, 2013 Author Share Posted November 19, 2013 Yes, nice choice.... and good job...; And don't forget if you're some problems... mail Mister Waroff it's Master!!!! Thank you for that, I'm probably too far in the build to make significant changes to this one, but I'll remember Mr Waroff for the next one, the AZUR Caudron C714. Cheers Den Link to comment Share on other sites More sharing options...
dennismcc Posted November 19, 2013 Author Share Posted November 19, 2013 Looks terrific Den! Kev Thanks Kev, it's a shame that there are not more early WW2 kits available in 1/32 scale. Cheers Den Link to comment Share on other sites More sharing options...
dennismcc Posted November 19, 2013 Author Share Posted November 19, 2013 (edited) Time to check the fit of the main components, this was not too bad, pretty normal for this type of kit, I like to do as much at this stage as possible rather than start fettling after I have joined all the parts together. This view reminds me of the Cybermen on Dr Who Not too bad at all Cheers Den Edited October 13, 2019 by dennismcc Replaced blurred Photobucket photos Link to comment Share on other sites More sharing options...
dennismcc Posted November 19, 2013 Author Share Posted November 19, 2013 (edited) A dry fit of the cockpit tub showed the need for some trimming of the front bulkhead to allow the fuselage halves to be closed, this turned out to be quite fiddly as the frame tubes kept popping out. You will also notice the the exhausts have to be fitted prior to joining the fuselage halves which is one of the things that I hate doing, but I could not see a way around it on this kit. The retractable radiator was then assembled, this turned into a tricky process to get it lined up to fit into the lower wing section, some sanding was needed to get a good fit. The assembly was painted with Hu 92 Matt Iron Grey as was the interior section of the lower wing. The upper and lower wing where then cleaned up and after dry fitting to the fuselage (taped up only) they were joined and the seams sanded smooth. The finish of the plastic on the wings and fuselage was not very smooth so they were polished using various grades of sanding sticks and finished off with a nail buffer. More soon Cheers Den Edited October 13, 2019 by dennismcc Replaced blurred Photobucket photos Link to comment Share on other sites More sharing options...
Erwin Posted November 19, 2013 Share Posted November 19, 2013 I made that kit last year. Watch out for the very bad fitting clear parts !! Link to comment Share on other sites More sharing options...
waroff Posted November 19, 2013 Share Posted November 19, 2013 You have reason not to correct the fuselage. It is a lot of work and few person will see the difference Modify the fuselage suppose modify the airframe, then the instrument panel, the floor, the rudder pedal and many trouble... Link to comment Share on other sites More sharing options...
dennismcc Posted November 19, 2013 Author Share Posted November 19, 2013 You have reason not to correct the fuselage. It is a lot of work and few person will see the difference Modify the fuselage suppose modify the airframe, then the instrument panel, the floor, the rudder pedal and many trouble... Sounds eminently sensible to me ! Cheers Den Link to comment Share on other sites More sharing options...
Azgaron Posted November 19, 2013 Share Posted November 19, 2013 Nice work Den! Haha, the front view sure reminds of cybermen. Keep up the good work! HÃ¥kan Link to comment Share on other sites More sharing options...
dennismcc Posted November 20, 2013 Author Share Posted November 20, 2013 (edited) Now it was time to start putting it all together, the cockpit tub was fixed into the right fuselage half after much dry fitting and shaving of parts, the parcel shelf and bulkhead behind the cockpit were fitted, again after some dry fitting and fettling. With the internals in pace the fuselage halves were taped up and CA run into the joints internally, this was left to dry overnight, and then a bead of CA was run along the seams using a cocktail stick. Lots of test fitting and sanding were then the order of the day to get a good fit between the fuselage and wings with as small a gap/mismatch as possible.CA was then applied to the wings ready to fit them to the fuselage, but then the section of cockpit floor holding the control column decided to break away. A hurried blob of CA was used to fix it back in place and the fuselage and wings were joined. There were some small gaps at the wing roots these were filled with scrap plastic and CA, and then the normal sanding and polishing took place, lots of sanding later the joints were finally reduced to thin grey (CA) lines and the lost panel lines was were rescribed, using Dymo tape and my trusty Bare Metal scriber. The tape in this photo is in the wrong place but it gives you an idea of the method Cheers Den Edited October 13, 2019 by dennismcc Replaced blurred Photobucket photos Uilleann 1 Link to comment Share on other sites More sharing options...
dennismcc Posted November 20, 2013 Author Share Posted November 20, 2013 I made that kit last year. Watch out for the very bad fitting clear parts !! Hi Erwin, yep I had some fun with them, more later ! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 21, 2013 Share Posted November 21, 2013 Very nice work Den - looking great! Kev Link to comment Share on other sites More sharing options...
dennismcc Posted November 21, 2013 Author Share Posted November 21, 2013 (edited) Thanks Kev, now on to the tail feathers, as usual I drilled locating holes in these and inserted fuse wire to give me a more positive fit than just blobbing some CA on them. Now on to the part that Erwin was talking about, the clear parts. The windscreen which was very carefully test fitted, this was done because on 2 online builds that I found the screen was cracked when the builder tried to spread it to fit the fuselage, so I did not even attempt this. Instead I positioned the screen slightly higher up the fuselage (toward the nose) to get a better fit. This looked like it would work without me having to modifying the fuselage which is how I intended to overcome any fit problems. The clear parts were then dipped in Klear and place into the lettuce saver, but as I cleaned the screen with a lens cleaner it split just like the 2 screens on my AZUR Hawk 75, so be warned they are rather fragile. So I did the same that the builder did on an online build that I read, I cut out the centre section and replaced it with some clear sheet, not perfect but passable, plus I made it a tad wider. Cheers Den Edited October 13, 2019 by dennismcc Replaced blurred Photobucket photos Jamme 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 21, 2013 Share Posted November 21, 2013 Good work on the canopy Den. From memory, mine is already cracked as it sits in the box! Kev Link to comment Share on other sites More sharing options...
Azgaron Posted November 21, 2013 Share Posted November 21, 2013 Very nice work Den! Canopy looks great! HÃ¥kan Link to comment Share on other sites More sharing options...
Guest Peterpools Posted November 21, 2013 Share Posted November 21, 2013 Den Enjoying your thread and it's so refreshing to see a not so often kit, take center stage. Terrific work on the IP and front office. Keep 'em coming Peter :popcorn: Link to comment Share on other sites More sharing options...
