BloorwestSiR Posted January 12, 2016 Share Posted January 12, 2016 Hey Don, If you can get the cannon bay panels off, I can swap upper wings with you. At least those are accessible from the underside. I need the MLG bulges on my build of a MKIX but not the cannon bay ones. I also seen that your LHS is mine too. Let me know. Carl dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted January 12, 2016 Author Share Posted January 12, 2016 Hello Carl!! Thanks for the kind offer!! I'm going to leave them alone, there is just no way the parts are coming apart. I was going to go with an inaccurate camo job but i can't do it. I'll be doing a silver bird. It'll be a colorful build and accurate with the bulges. I'll probably do another one of these and i'll PAY ATTENTION to what i'm doing. Don geedubelyer 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 12, 2016 Share Posted January 12, 2016 No problem Don. Nice choice on the NMF. I have a XVI in the stash that I'll be doing in high speed silver with a red stripe and spinner. I hear you on the paying attention bit. One of my Merlins has a part in backwards. So guess which one will have a closed cowl? Carl dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted January 17, 2016 Author Share Posted January 17, 2016 Hey Don, I also seen that your LHS is mine too. Carl Not local, as i'm in Pickering. I have to say, they have most anything you could need!! I get there once every two months, always a treat. I also hit Daleys hobbies in Whitby. Have some more aftermarket to add Some progress on the build, added the gunports to the wing assembly. Fit on these parts needed filling with Mr Surfacer, also took the opportunity to sand the surfaces in front of the main spar to take away the rivet detail. Added some reinforcement to the wing flap joint, it came apart on me a couple of times. Don geedubelyer 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 17, 2016 Share Posted January 17, 2016 Nice bit of progress Don. The gun ports have to be the worst fitting parts in the entire kit. I'm on the west side of Toronto but I guess it's still closer to Wheels and Wings for me. And you're right, they have just about everything including stuff that's OOP. Carl dmthamade 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted January 23, 2016 Share Posted January 23, 2016 just for inspiration. Cheers M. Link to comment Share on other sites More sharing options...
geedubelyer Posted January 24, 2016 Share Posted January 24, 2016 It makes me smile hearing about Pickering and Whitby. Both of these Yorkshire towns are joined by the North York Moors steam railway here in the UK. Some of the fit issues on these Tamiya Spits come as a surprise to me. I'm grateful to you for pointing tem out Don. I know to look out for them when I get that far. Cheers. dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted January 24, 2016 Author Share Posted January 24, 2016 Nice bit of progress Don. The gun ports have to be the worst fitting parts in the entire kit. I'm on the west side of Toronto but I guess it's still closer to Wheels and Wings for me. And you're right, they have just about everything including stuff that's OOP. Carl The gunports were a surprise after all i've heard and read about the kit. Really wasn't bad at all (try building the ESCI Tornado or Alpha jet, THAT'S bad fit!!) After those i tackled the engine assembly. I have to say the fit of all those parts is amazing, i get what everyone says about the fit, truly Leggo like. I assembled all parts to see how it was, but i will be doing a closed cowl build, i want to see the Spitfire in its clean beauty. Do you remember Keith's Hobbies on Yonge St? That was a fantastic shop, too just for inspiration. Cheers M. That's a great pic, to me it shows a dirty aircraft. The rear lower fuselage looks very grimy. I may not be doing this scheme after all. Dropped the wing assembly with no damage done other than one of the larger bulges fell off!! Other side i just pried off easily. Seems like gluing from the bottom through the holes isn't as solid as i thought. I filled the holes with Evergreen round stock, will trim and finish. Hope i don't lose too much detail, if i do, i still have the intact bulges. It makes me smile hearing about Pickering and Whitby. Both of these Yorkshire towns are joined by the North York Moors steam railway here in the UK. Some of the fit issues on these Tamiya Spits come as a surprise to me. I'm grateful to you for pointing tem out Don. I know to look out for them when I get that far. Cheers. Pickering and Whitby are two towns in southern Ontario separated by, well, a distance of a short train ride, what a coincidence. I have a feeling there won't be many more fit issues unless i cause them. The engine assembly was such a breeze, yet very complex. Don geedubelyer 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 24, 2016 Share Posted January 24, 2016 Don, nice and fortuitous on dropping your wing and having the unnecessary bulges come off. Glad to see that was the only damage. The gun ports really are the worst of it on the kit so I imagine that's good to know. Keith's was my go to hobby shop from the early 80's until their lease ran out and they moved somewhere in the suburbs. Rigby's in the west end was only 15 minutes by bicycle from my parents' house but he only carried kits and paint, no AM of any kind. There was also Leisure World downtown and Gameways Ark too. Both of those are going way back though. Carl Link to comment Share on other sites More sharing options...
dmthamade Posted January 25, 2016 Author Share Posted January 25, 2016 Really lucked out on the bulges, i glued these in from the bottom through the holes drilled for the bulges, never did hit them on top. The small ones are permanent, those i hit top and bottom. Hopefully will be able to clean up the fill and do the camo'ed Canadian bird!! One seam on the leading edge did open a bit but is a real quick repair. Keiths hobbies ended north Whitby, up the street from Daileys hobbies. Just a small store, shell of what it was. Didn't last long.... Don geedubelyer 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted January 25, 2016 Share Posted January 25, 2016 I was going to forgo painting the Engine as well, but with such nice detail, it's hard to resist. I hope the panels fit as well as all the other parts so far. I thought long and hard about the flaps -- I know they're usually up when this aircraft is parked on the ground, but to lose such nice detail had me pondering for a bit... Nice to see another Tamiya Spitfire virgin... dmthamade and geedubelyer 2 Link to comment Share on other sites More sharing options...
geedubelyer Posted February 3, 2016 Share Posted February 3, 2016 Glad the accident had unforseen but happy consequences Don. Sometimes these things happen for a reason. I spotted the Kagero book on a recent trip to a model shop but got carried away and forgot to pick it up.... No matter as I think I shall try to replicate the version out of the box when it comes to that time. Have you got any further this week? Cheers. dmthamade 1 Link to comment Share on other sites More sharing options...
dmthamade Posted February 5, 2016 Author Share Posted February 5, 2016 Thanks for the encouragement, guys. I've made some progress, did some work on the pit, gluing and painting my way along. The kit pit is well detailed, more than good enough for me. The barracuda Resin lower pit wall goes in trouble free, just follow instructions. I found when dryfitting the fit of all the parts was great. Dryfitting the pit into the fuselage shows that very little of all this goodness can be seen. I'm gluing the door shut as i really like the looks of a clean, closed up aircraft, especially a sleek Spitfire. Next i'll be working on the Barracuda Resin seat, i got the seat for the Revell kit as i couldn't find the Tamiya seat. May have to modify it a bit. Don geedubelyer 1 Link to comment Share on other sites More sharing options...
Guest Posted February 5, 2016 Share Posted February 5, 2016 GO Don !.......Harv Link to comment Share on other sites More sharing options...
mozart Posted February 5, 2016 Share Posted February 5, 2016 Beautifully neat and precise work Don, love it. Max dmthamade 1 Link to comment Share on other sites More sharing options...
