Zero77 Posted January 17, 2017 Share Posted January 17, 2017 Building PE up with paint is something I've never tried, I usually just use appropriately sized soldering wire & PE ignition harness wires go in the spares bin. I'll have to give it a go. Biggish airbrush needle & not too thinned paint should help? I meant to build up the wires with a paintbrush, and several coats. I dont think it would work with an airbrush. That's the surface tension of the paint on the PE part that makes the tridimentional effect. Shawn M and David66 2 Link to comment Share on other sites More sharing options...
Ryan Posted January 17, 2017 Author Share Posted January 17, 2017 (edited) Zero, Did you attach the PE to a painted engine or did to fix in place before you painted the whole thing? (and then touched up the PE wiring) For example did you glue the PE wiring to the collector ring, paint that assembly and then thread the wiring through push rods etc and glue them on a painted engine? Edited January 17, 2017 by Ryan David66 and Zero77 2 Link to comment Share on other sites More sharing options...
LSP_Mike Posted January 17, 2017 Share Posted January 17, 2017 I'd not thought to use an airbrush needle as an applicator. May be suited to even out the paint thickness for a more uniform look. David66 1 Link to comment Share on other sites More sharing options...
Zero77 Posted January 17, 2017 Share Posted January 17, 2017 Zero, Did you attach the PE to a painted engine or did to fix in place before you painted the whole thing? (and then touched up the PE wiring) For example did you glue the PE wiring to the collector ring, paint that assembly and then thread the wiring through push rods etc and glue them on a painted engine? I dont remember exactly. But as i have some pictures of the engine painted but without the wiring, i'm pretty sure i painted it before gluing it. David66 1 Link to comment Share on other sites More sharing options...
Juggernut Posted January 17, 2017 Share Posted January 17, 2017 Agreed, Peter. I rolled solder under a file at 45 degrees to get these... What an ingenious idea! I'm gonna file that one (no pun intended) and use it later! David66 1 Link to comment Share on other sites More sharing options...
Juggernut Posted January 17, 2017 Share Posted January 17, 2017 (edited) If I were going to use PE for the igntion harness and wanted to build up layers with paint, I'd surely glue it in place first as any bending after the fact will surely flake the paint right off. Edited January 17, 2017 by Juggernut David66 1 Link to comment Share on other sites More sharing options...
Ryan Posted January 18, 2017 Author Share Posted January 18, 2017 It becomes a masking issue for sure when trying to paint the crankase and cylinder heads different colors if the PE is attached ahead of time. But it is a glue issue if they are stuck on afterwards. At least when they are glued on to the assembly at large before paint you can sand out any glue mistakes. Nice discussion btw, thanks for all of the input. Ryan Link to comment Share on other sites More sharing options...
LSP_Mike Posted January 18, 2017 Share Posted January 18, 2017 That is why my first thought was to try to place it, shape it, remove, and then paint it. Sounds like a "good thing I have a few ideas, let's see which one works" sort of gig. Ryan 1 Link to comment Share on other sites More sharing options...
Ryan Posted January 18, 2017 Author Share Posted January 18, 2017 Your right Mike, you could glue to the connector ring and then bend the wires into shape, paint the collector ring with leads attached then glue the pre-bent brass down on the painted engine. Might go this rout, will post pics. Ryan Link to comment Share on other sites More sharing options...
Bill_S Posted January 18, 2017 Share Posted January 18, 2017 What an ingenious idea! I'm gonna file that one (no pun intended) and use it later! It's actually a three step process; when I get a chance, I'll put it in the "Tips, Techniques and Photography" section. Link to comment Share on other sites More sharing options...
